path: root/arch/arm/boot/dts/sun4i-a10-olinuxino-lime.dts
2015-09-27dts: sunxi: add eeprom to A10 OLinuXino Lime boardOlliver Schinagl
The Olimex A10 OLinuXino Lime features an eeprom that is always on the board. This patch adds it to the dts. Signed-off-by: Olliver Schinagl <oliver@schinagl.nl> Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
2015-07-31ARM: dts: sun4i: Enable USB DRC on A10 OLinuxIno LimeRemy van Elst
Enable the otg/drc usb controller on the A10 OLinuxIno Lime. Signed-off-by: Remy van Elst <relst@relst.nl> Signed-off-by: Hans de Goede <hdegoede@redhat.com> Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
2015-06-01ARM: dts: sun4i: Add A10 SRAM and SRAM controllerMaxime Ripard
The A10 has a few SRAM that can be mapped either to a device or to the CPU, with the mapping being controlled by a SRAM controller. Add the SRAM controller, the SRAM that it drives and the section that can be used by the various devices. Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com> Acked-by: Arnd Bergmann <arnd@arndb.de> Acked-by: Hans de Goede <hdegoede@redhat.com> Tested-by: Hans de Goede <hdegoede@redhat.com>
2015-05-10ARM: sunxi: dt: Remove the FSF addressMaxime Ripard
The FSF address triggers a warning on checkpatch, saying that the FSF license is already present in the Linux source code, and that it has already changed in the past. Remove it from our DT, as suggested. Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
2015-04-27ARM: sunxi: DT: Add stdout-path propertyMaxime Ripard
Add UART aliases and stdout-path property for all the Allwinner boards so that we won't have to rely on the bootargs' console= value, while working with legacy bootloaders. While we're at it, also remove the mentions of earlyprintk in the bootargs, that will remove our default bootargs entirely, and allow the kernel to boot on a system even if DEBUG_LL is configured for another system. Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
2015-04-27ARM: sun4i: olinuxino lime: Convert to DT label based syntaxMaxime Ripard
In order to lessen the amount of duplication of the DT tree, ease the new and follow the trend that prefers to use label based references when overriding DTSI nodes, convert the board to this syntax Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
2015-03-24ARM: dts: sun4i: a10-lime: Override and remove 1008MHz OPP settingChen-Yu Tsai
The Olimex A10-Lime is known to be unstable when running at 1008MHz. Signed-off-by: Chen-Yu Tsai <wens@csie.org> Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
2015-01-21ARM: sunxi: DT: Convert the DTs to use a header for the pinctrl nodesMaxime Ripard
The pinctrl nodes require some extra opaque arguments for the pull up and drive strength values. Introduce a new header file and convert the device trees to replace these opaque numbers by defines. Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
2015-01-21ARM: sunxi: DT: convert DTs to use common GPIOs includesMaxime Ripard
Replace the various raw GPIO flags by their definition in the common dt-bindings header. Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
2015-01-21ARM: sunxi: DT: Convert to device tree includesMaxime Ripard
Prepare the device trees to use the C preprocessor. Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
2014-10-21ARM: sun4i: olinuxino lime: Relicense the device tree under GPLv2/X11Maxime Ripard
The current GPL only licensing on the DTSI makes it very impractical for other software components licensed under another license. In order to make it easier for them to reuse our device trees, relicense our device trees under a GPL/X11 dual-license. Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com> Acked-by: Carlo Caione <carlo@caione.org> Acked-by: Hans de Goede <hdegoede@redhat.com>
2014-07-01ARM: dts: sun4i: Add AXP209 support to various boardsCarlo Caione
At a node for the axp209, and where necessary the i2c controller to the dts for various boards. Note the axp209 regulators are omitted as we don't have any use for them yet, and on some boards were not sure how exactly they are wired up. Adding support for just the axp209 without the regulators is still useful, as it will give us power-button and poweroff support. Signed-off-by: Carlo Caione <carlo@caione.org> [hdegoede@redhat.com: Drop the regulator bits for now] Signed-off-by: Hans de Goede <hdegoede@redhat.com> Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
2014-05-11ARM: dts: sun4i: Add reg_vcc3v3 to sun4i board mmc nodesHans de Goede
2014-05-04ARM: dts: sun4i: Enable mmc controller on various A10 boardsHans de Goede
Tested on a subset of these boards, for the others boards the settings match the ones of the tested boards according to the original firmware fex files. Signed-off-by: Hans de Goede <hdegoede@redhat.com> Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
2014-03-04ARM: sun4i: dt: Add support for the A10-OLinuXino-LIME boardHans de Goede
This add support for the A10-OLinuXino-LIME: https://www.olimex.com/Products/OLinuXino/A10/A10-OLinuXino-LIME A low cost Allwinner A10 based dev-board, with sata, ethernet, hdmi and 2x USB. Signed-off-by: Hans de Goede <hdegoede@redhat.com> Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
