As part of our effort to move pinctrl/GPIO interlocking into the
driver where it belongs, this patch drops the definition and usage
of the pinmux settings for the common regulators defined in
sunxi-common-regulators.dtsi.
Signed-off-by: Chen-Yu Tsai <wens@csie.org>
Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
All dts files for the sunxi platform have been switched to the generic
pinconf bindings. As a result, the sunxi specific pinctrl macros are
no longer used.
Remove the #include entry with the following command:
sed --follow-symlinks -i -e '/pinctrl\/sun4i-a10.h/D' \
arch/arm/boot/dts/sun?i*.*
arch/arm/boot/dts/sun9i-a80.dtsi was then edited to remove the extra
empty line.
Now that we can handle the generic pinctrl bindings, convert our DT to it.
Acked-by: Chen-Yu Tsai <wens@csie.org>
The allwinner,pull property set to NO_PULL was really considered our
default (and wasn't even changing the default value in the code).
Remove these properties to make it obvious that we do not set anything in
such a case.
The allwinner,drive property set to 10mA was really considered as our
default. Remove all those properties entirely to make that obvious.
The auxtek t004 has its otg usb vbus hardwired to 5v (likely in case
people use it to power the board instead of the dedicated power micro
usb connector), it does have an id pin, so it allows full otg
functionality.
Add a node describing the AXP152 pmic used on Auxtek T004 boards.
Signed-off-by: Michael van Slingerland <michael@deviousops.nl>
The FSF address triggers a warning on checkpatch, saying that the FSF
license is already present in the Linux source code, and that it has
already changed in the past.
Remove it from our DT, as suggested.
Add UART aliases and stdout-path property for all the Allwinner boards so that
we won't have to rely on the bootargs' console= value, while working with
legacy bootloaders.
While we're at it, also remove the mentions of earlyprintk in the bootargs,
that will remove our default bootargs entirely, and allow the kernel to boot on
a system even if DEBUG_LL is configured for another system.
The auxtek-t004:
http://www.fasttech.com/products/1110/10004200/1318603-auxtek-t004-allwinner-a10s-single-core-android-ics
Is an Allwinner A10s based hdmi tv stick with with 512M RAM, 4G nand flash,
toc9002 (bcm43362) sdio wifi, 1 USB host ports using an USB-A receptacle and
a 2 micro-usb receptacles, one for power and one for USB OTG.
The sdio wifi appears to not have an oob irq hooked up, so we rely on sdio-irq
support for it.
