The A10s Olinuxino has an HDMI connector. Make sure we can use it.
Acked-by: Chen-Yu Tsai <wens@csie.org>
Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
Signed-off-by: Chen-Yu Tsai <wens@csie.org>
As part of our effort to move pinctrl/GPIO interlocking into the
driver where it belongs, this patch drops the definition and usage
of the pinmux settings for the common regulators defined in
sunxi-common-regulators.dtsi.
All dts files for the sunxi platform have been switched to the generic
pinconf bindings. As a result, the sunxi specific pinctrl macros are
no longer used.
Remove the #include entry with the following command:
sed --follow-symlinks -i -e '/pinctrl\/sun4i-a10.h/D' \
arch/arm/boot/dts/sun?i*.*
arch/arm/boot/dts/sun9i-a80.dtsi was then edited to remove the extra
empty line.
There's one UART2 pin group that can be used across all sun5i SoCs.
However, the A10s already has one pin group for that controller.
Change the index of the one in the A10s DTSI, and add the common one to
sun5i.dtsi
One of the pins group for the EMAC can be used by all the SoCs of the sun5i
family, and as such can be moved to the common DTSI.
Unfortunately, this group is the second one we declare in our DT for now.
Make it the first one so that it's more logical and consistent with the
rest of our DTs before moving it.
Now that we can handle the generic pinctrl bindings, convert our DT to it.
The allwinner,pull property set to NO_PULL was really considered our
default (and wasn't even changing the default value in the code).
Remove these properties to make it obvious that we do not set anything in
such a case.
The allwinner,drive property set to 10mA was really considered as our
default. Remove all those properties entirely to make that obvious.
The SPI2 pins on the sun5i PB bank are only available on the A10s. Rename
the A10s only bank so that it doesn't confuse people on the other SoCs
whose indexing would start at b.
spi2 is available on the UEXT connector
Signed-off-by: Michal Suchanek <hramrach@gmail.com>
[Maxime: Fixed the node order]
The OLinuXino A10S micro features an eeprom. According to the eeprom.txt
binding document, we should use the manufacturer and 'at' is not the
proper manufacturer id according to the vendor-prefixes.
This patch takes the proper vendor-prefix and uses it for the eeprom
node.
Signed-off-by: Olliver Schinagl <oliver@schinagl.nl>
Enable the otg/drc usb controller on the A10s OLinuxIno Micro.
Note the A10s OlinuxIno Micro always has some voltage on its otg power
pin, even if the usb-vbus0-regulator is disabled, the leaked voltage is
enough to make vbus-det always report 1, so we do not use vbus-det on
this board.
Add a node for axp152 pmic used on the A10s-OLinuxIno SBC.
The A10s and A13 have a few SRAM that can be mapped either to a device or
to the CPU, with the mapping being controlled by a SRAM controller.
Add the SRAM controller, the SRAM that it drives and the section that can
be used by the various devices.
Acked-by: Hans de Goede <hdegoede@redhat.com>
Tested-by: Hans de Goede <hdegoede@redhat.com>
The FSF address triggers a warning on checkpatch, saying that the FSF
license is already present in the Linux source code, and that it has
already changed in the past.
Remove it from our DT, as suggested.
Add UART aliases and stdout-path property for all the Allwinner boards so that
we won't have to rely on the bootargs' console= value, while working with
legacy bootloaders.
While we're at it, also remove the mentions of earlyprintk in the bootargs,
that will remove our default bootargs entirely, and allow the kernel to boot on
a system even if DEBUG_LL is configured for another system.
In order to lessen the amount of duplication of the DT tree, ease the
new and follow the trend that prefers to use label based references
when overriding DTSI nodes, convert the board to this syntax
Pull ARM SoC DT updates from Olof Johansson:
"DT changes continue to be the bulk of our merge window contents.
We continue to have a large set of changes across the board as new
platforms and drivers are added.
Some of the new platforms are:
- Alphascale ASM9260
- Marvell Armada 388
- CSR Atlas7
- TI Davinci DM816x
- Hisilicon HiP01
- ST STiH418
There have also been some sweeping changes, including relicensing of
DTS contents from GPL to GPLv2+/X11 so that the same files can be
reused in other non-GPL projects more easily. There's also been
changes to the DT Makefile to make it a little less conflict-ridden
and churny down the road"
* tag 'dt-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (330 commits)
ARM: dts: Add PPMU node for exynos4412-trats2
ARM: dts: Add PPMU node for exynos3250-monk and exynos3250-rinato
ARM: dts: Add PPMU dt node for exynos4 and exynos4210
ARM: dts: Add PPMU dt node for exynos3250
ARM: dts: add mipi dsi device node for exynos4415
ARM: dts: add fimd device node for exynos4415
ARM: dts: Add syscon phandle to the video-phy node for Exynos4
ARM: dts: Add sound nodes for exynos4412-trats2
ARM: dts: Fix CLK_MOUT_CAMn parent clocks assignment for exynos4412-trats2
ARM: dts: Fix CLK_UART_ISP_SCLK clock assignment in exynos4x12.dtsi
ARM: dts: Add max77693 charger node for exynos4412-trats2
ARM: dts: Switch max77686 regulators to GPIO control for exynos4412-trats2
ARM: dts: Add suspend configuration for max77686 regulators for exynos4412-trats2
ARM: dts: Add Maxim 77693 fuel gauge node for exynos4412-trats2
ARM: dts: am57xx-beagle-x15: Fix USB2 mode
ARM: dts: am57xx-beagle-x15: Add extcon nodes for USB
ARM: dts: dra72-evm: Add extcon nodes for USB
ARM: dts: dra7-evm: Add extcon nodes for USB
ARM: dts: rockchip: move the hdmi ddc-i2c-bus property to the actual boards
ARM: dts: rockchip: enable vops and hdmi output on rk3288-firefly and -evb
Commit f77d55a3b56a ("serial: 8250_dw: get index of serial line from DT
aliases") made the serial driver now use the serial aliases to get the tty
number, pointing out that our aliases have been wrong all along.
Remove them from the DTSI and add custom ones in the relevant boards.
The pinctrl nodes require some extra opaque arguments for the pull up and drive
strength values.
Introduce a new header file and convert the device trees to replace these
opaque numbers by defines.
Replace the various raw GPIO flags by their definition in the common
dt-bindings header.
The current GPL only licensing on the DTSI makes it very impractical for other
software components licensed under another license.
In order to make it easier for them to reuse our device trees, relicense our
device trees under a GPL/X11 dual-license.
Acked-by: Emilio López <emilio@elopez.com.ar>
The cd pin settings have been taken from the original firmware fex files,
and have been confirmed to work on the actual boards.
Add nodes for the usb-phy and ehci- and ohci-usb-host controllers.
There was a typo in the base address used for the soc node in the A10s
device tree. Fix it with the proper base address.
This OLIMEX board has a AT24C16BN-SH EEPROM holding the MAC address.
This patch adds the corresponding device tree node to reflect this.
Signed-off-by: Emilio López <emilio@elopez.com.ar>
This board from OLIMEX is using the three I2C controllers present on A10S:
* I2C-0 connects to the AXP152 PMU
* I2C-1 holds an AT24C16BN-SH EEPROM with the MAC address for ethernet
* I2C-2 is used for UEXT modules.
Tested-by: Emilio López <emilio@elopez.com.ar>
