path: root/arch/arm/boot/dts/sun5i-a10s.dtsi
2015-10-12ARM: dts: sun5i: Add PWM controller node for A13 / A10sHans de Goede
Add dts nodes for the PWM controller on the A13 / A10s. Signed-off-by: Hans de Goede <hdegoede@redhat.com> Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
2015-10-11ARM: sun5i: dt: Move uart3 pinctrl node to common DTSIMaxime Ripard
The uart3 pins are shared between the A10s and A13, move the pinctrl node to the common DTSI to avoid duplication. Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com> Reviewed-by: Hans de Goede <hdegoede@redhat.com> Reviewed-by: Chen-Yu Tsai <wens@csie.org>
2015-09-27ARM: dts: sun5i: Add emac_pins_b definitionJelle van der Waa
The emac pins on an A10s can also be routed to the outside through PORTD rather then through PORTA, add a pinctrl node for this. Signed-off-by: Jelle van der Waa <jelle@vdwaa.nl> Signed-off-by: Hans de Goede <hdegoede@redhat.com> Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
2015-09-27ARM: dts: sun5i: Add simplefb node for tvencoder outputHans de Goede
Add a simplefb node for tvencoder / composite-video output, such as found on the Auxtek-T003 and the CHIP. Signed-off-by: Hans de Goede <hdegoede@redhat.com> Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
2015-08-12ARM: sun5i: Add clock indicesMaxime Ripard
The A10s and A13 gates have a non continuous set of clock IDs that are valid. Add the clock-indices property to the DT to express this. Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com> Signed-off-by: Michael Turquette <mturquette@baylibre.com>
2015-06-01ARM: dts: sun5i: Add A10s and A13 SRAM and SRAM controllerMaxime Ripard
The A10s and A13 have a few SRAM that can be mapped either to a device or to the CPU, with the mapping being controlled by a SRAM controller. Add the SRAM controller, the SRAM that it drives and the section that can be used by the various devices. Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com> Acked-by: Arnd Bergmann <arnd@arndb.de> Acked-by: Hans de Goede <hdegoede@redhat.com> Tested-by: Hans de Goede <hdegoede@redhat.com>
2015-05-10ARM: sunxi: DT: Fix lines over 80 charactersMaxime Ripard
A few lines in our DTSIs are over the 80 characters limit, making checkpatch complain about that. If possible (and relevant), wrap these lines to 80 characters. Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
2015-05-10ARM: sunxi: dt: Remove the FSF addressMaxime Ripard
The FSF address triggers a warning on checkpatch, saying that the FSF license is already present in the Linux source code, and that it has already changed in the past. Remove it from our DT, as suggested. Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
2015-04-27ARM: dts: sun5i: Stop using different compatibles for ehci/ohci on a13 vs a10sHans de Goede
The A13 and the A10s use the same die (this has been confirmed by Allwinner), as such there is no need to differentiate between the ehci/ohci parts of both, the only reasons there were different allwinner,sun5i-a*-foo compatible between these 2 parts is costemetically and because we could when we still had 2 completely different dtsi files. The allwinner,sun5i-a*-foo compatible strings are not used for binding at all, the actual driver binds to the generic-?hci compatible, so we can safely remove this cosmetical difference and simplify the dtsi files. Signed-off-by: Hans de Goede <hdegoede@redhat.com> Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
2015-04-27ARM: sun5i: a10s: Move to the common sun5i DTSIMaxime Ripard
Now that we have a common DTSI for the sun5i family, move the A10s to use it. Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
2015-04-27ARM: sun5i: Relicense the A10s/A13 DTSI under GPLv2/X11Maxime Ripard
The current GPL only licensing on the DTSI makes it very impractical for other software components licensed under another license. In order to make it easier for them to reuse our device trees, relicense our DTSI first under a GPL/X11 dual-license. Hopefully, the DTS will follow soon. Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com> Acked-by: Arnd Bergmann <arnd@arndb.de> Acked-by: Chen-Yu Tsai <wens@csie.org> Acked-by: David Lanzendörfer <david.lanzendoerfer@o2s.ch> Acked-by: Emilio López <emilio@elopez.com.ar> Acked-by: Hans de Goede <hdegoede@redhat.com> Acked-by: Lorenzo Pieralisi <lorenzo.pieralisi@arm.com> Acked-by: Oliver Schinagl <oliver@schinagl.nl> Acked-by: Roman Byshko <rbyshko@gmail.com>
2015-02-21Merge tag 'clk-for-linus-3.20' of ↵Linus Torvalds
git://git.linaro.org/people/mike.turquette/linux Pull clock framework updates from Mike Turquette: "The clock framework changes contain the usual driver additions, enhancements and fixes mostly for ARM32, ARM64, MIPS and Power-based devices. Additionally the framework core underwent a bit of surgery with two major changes: - The boundary between the clock core and clock providers (e.g clock drivers) is now more well defined with dedicated provider helper functions. struct clk no longer maps 1:1 with the hardware clock but is a true per-user cookie which helps us tracker users of hardware clocks and debug bad behavior. - The addition of rate constraints for clocks. Rate ranges are now supported which are analogous to the voltage ranges in the regulator framework. Unfortunately these changes to the core created some breakeage. We think we fixed it all up but for this reason there are lots of last minute commits trying to undo the damage" * tag 'clk-for-linus-3.20' of git://git.linaro.org/people/mike.turquette/linux: (113 commits) clk: Only recalculate the rate if needed Revert "clk: mxs: Fix invalid 32-bit access to frac registers" clk: qoriq: Add support for the platform PLL powerpc/corenet: Enable CLK_QORIQ clk: Replace explicit clk assignment with __clk_hw_set_clk clk: Add __clk_hw_set_clk helper function clk: Don't dereference parent clock if is NULL MIPS: Alchemy: Remove bogus args from alchemy_clk_fgcs_detr clkdev: Always allocate a struct clk and call __clk_get() w/ CCF clk: shmobile: div6: Avoid division by zero in .round_rate() clk: mxs: Fix invalid 32-bit access to frac registers clk: omap: compile legacy omap3 clocks conditionally clkdev: Export clk_register_clkdev clk: Add rate constraints to clocks clk: remove clk-private.h pci: xgene: do not use clk-private.h arm: omap2+ remove dead clock code clk: Make clk API return per-user struct clk instances clk: tegra: Define PLLD_DSI and remove dsia(b)_mux clk: tegra: Add support for the Tegra132 CAR IP block ...
2015-02-17Merge tag 'dt-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull ARM SoC DT updates from Olof Johansson: "DT changes continue to be the bulk of our merge window contents. We continue to have a large set of changes across the board as new platforms and drivers are added. Some of the new platforms are: - Alphascale ASM9260 - Marvell Armada 388 - CSR Atlas7 - TI Davinci DM816x - Hisilicon HiP01 - ST STiH418 There have also been some sweeping changes, including relicensing of DTS contents from GPL to GPLv2+/X11 so that the same files can be reused in other non-GPL projects more easily. There's also been changes to the DT Makefile to make it a little less conflict-ridden and churny down the road" * tag 'dt-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (330 commits) ARM: dts: Add PPMU node for exynos4412-trats2 ARM: dts: Add PPMU node for exynos3250-monk and exynos3250-rinato ARM: dts: Add PPMU dt node for exynos4 and exynos4210 ARM: dts: Add PPMU dt node for exynos3250 ARM: dts: add mipi dsi device node for exynos4415 ARM: dts: add fimd device node for exynos4415 ARM: dts: Add syscon phandle to the video-phy node for Exynos4 ARM: dts: Add sound nodes for exynos4412-trats2 ARM: dts: Fix CLK_MOUT_CAMn parent clocks assignment for exynos4412-trats2 ARM: dts: Fix CLK_UART_ISP_SCLK clock assignment in exynos4x12.dtsi ARM: dts: Add max77693 charger node for exynos4412-trats2 ARM: dts: Switch max77686 regulators to GPIO control for exynos4412-trats2 ARM: dts: Add suspend configuration for max77686 regulators for exynos4412-trats2 ARM: dts: Add Maxim 77693 fuel gauge node for exynos4412-trats2 ARM: dts: am57xx-beagle-x15: Fix USB2 mode ARM: dts: am57xx-beagle-x15: Add extcon nodes for USB ARM: dts: dra72-evm: Add extcon nodes for USB ARM: dts: dra7-evm: Add extcon nodes for USB ARM: dts: rockchip: move the hdmi ddc-i2c-bus property to the actual boards ARM: dts: rockchip: enable vops and hdmi output on rk3288-firefly and -evb ...
2015-02-02Merge branch 'clk-next' into v3.19-rc7Michael Turquette
2015-01-25ARM: sunxi: dt: Fix aliasesMaxime Ripard
Commit f77d55a3b56a ("serial: 8250_dw: get index of serial line from DT aliases") made the serial driver now use the serial aliases to get the tty number, pointing out that our aliases have been wrong all along. Remove them from the DTSI and add custom ones in the relevant boards. Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
2015-01-21ARM: dts: sunxi: Add missing mdio labelAleksei Mamlin
This patch add missing mdio label for sun[457]i. Signed-off-by: Aleksei Mamlin <mamlinav@gmail.com> Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
2015-01-21ARM: dts: sunxi: Add simplefb nodes for de_be0-lcd0, de_be0-lcd0-tve0 pipelinesHans de Goede
Add simplefb nodes for "[de_fe0-]de_be0-lcd0" and "[de_fe0-]de_be0-lcd0-tve0" display pipelines for when u-boot has set up a pipeline to drive a LCD panel / VGA output rather then the HDMI output. Signed-off-by: Hans de Goede <hdegoede@redhat.com> Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
2015-01-21ARM: dts: sunxi: Enable thermal sensor support for RTP on sun[457]iChen-Yu Tsai
Now that the resistive touchpanel driver supports thermal sensors, add the "#thermal-sensor-cells" property as required by the thermal framework. Signed-off-by: Chen-Yu Tsai <wens@csie.org> Acked-by: Eduardo Valentin <edubezval@gmail.com> Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
2015-01-21ARM: sunxi: DT: Convert the DTs to use a header for the pinctrl nodesMaxime Ripard
The pinctrl nodes require some extra opaque arguments for the pull up and drive strength values. Introduce a new header file and convert the device trees to replace these opaque numbers by defines. Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
2015-01-21ARM: sunxi: DT: Convert the DTs to use a header for the DMA argumentsMaxime Ripard
The DMA engine for the A10/A20 and derivatives require an opaque extra argument. Add a dt-bindings header, and convert the device trees to it. Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
2015-01-21ARM: sunxi: DT: Convert to device tree includesMaxime Ripard
Prepare the device trees to use the C preprocessor. Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
2015-01-21ARM: dts: sun5i: Add lradc nodeHans de Goede
2015-01-14ARM: sunxi: dt: Add sample and output mmc clocksMaxime Ripard
Add the sample and output clocks for the MMC phase support. Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com> Reviewed-by: Chen-Yu Tsai <wens@csie.org> Tested-by: Chen-Yu Tsai <wens@csie.org>
2014-12-21ARM: dts: sunxi: Fix usb-phy support for sun4i/sun5iChen-Yu Tsai
usbphy0 support in the sunxi usb-phy driver has been merged, but the dtsi's for sun4i/sun5i haven't been updated. This results in the phy driver failing to load, breaking usb support. Fixes: 6827a46f5994 ('phy: sun4i: add support for USB phy0') Signed-off-by: Chen-Yu Tsai <wens@csie.org> Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
2014-12-20Merge tag 'clk-for-linus-3.19' of ↵Linus Torvalds
git://git.linaro.org/people/mike.turquette/linux Pull clk framework updates from Mike Turquette: "This is much later than usual due to several last minute bugs that had to be addressed. As usual the majority of changes are new drivers and modifications to existing drivers. The core recieved many fixes along with the groundwork for several large changes coming in the future which will better parition clock providers from clock consumers" * tag 'clk-for-linus-3.19' of git://git.linaro.org/people/mike.turquette/linux: (86 commits) clk: samsung: Fix Exynos 5420 pinctrl setup and clock disable failure due to domain being gated ARM: OMAP3: clock: fix boot breakage in legacy mode ARM: OMAP2+: clock: fix DPLL code to use new determine rate APIs clk: Really fix deadlock with mmap_sem clk: mmp: fix sparse non static symbol warning clk: Change clk_ops->determine_rate to return a clk_hw as the best parent clk: change clk_debugfs_add_file to take a struct clk_hw clk: Don't expose __clk_get_accuracy clk: Don't try to use a struct clk* after it could have been freed clk: Remove unused function __clk_get_prepare_count clk: samsung: Fix double add of syscore ops after driver rebind clk: samsung: exynos4: set parent of sclk_hdmiphy to hdmi clk: samsung: exynos4415: Fix build with PM_SLEEP disabled clk: samsung: remove unnecessary inclusion of header files from clk.h clk: samsung: remove unnecessary CONFIG_OF from clk.c clk: samsung: Spelling s/bwtween/between/ clk: rockchip: Add support for the mmc clock phases using the framework clk: rockchip: add bindings for the mmc clocks clk: rockchip: rk3288 export i2s0_clkout for use in DT clk: rockchip: use clock ID for DMC (memory controller) on rk3288 ...
2014-11-23ARM: dts: sunxi: Update simplefb nodes so that u-boot can find themHans de Goede
Review of the u-boot sunxi simplefb patches has led to the decision that u-boot should not use a specific path to find the nodes as this goes contrary to how devicetree usually works. Instead a platform specific compatible + properties should be used for this. The simplefb bindings have already been updated to reflect this, this patch brings the sunxi devicetree files in line with the new binding, and the actual u-boot implementation as it is going upstream. Signed-off-by: Hans de Goede <hdegoede@redhat.com> Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
2014-11-23ARM: dts: sunxi: Add de_be0 clk parent pll to simplefb nodeHans de Goede
Avoid the parent pll for the mod-clk for de_be0 getting disabled when non of the other users are enabled (which can happen when none of i2c, spi and mmc are in use). Note for now we point directly to the parent rather then to the de_be0 mod-clk as that is not modelled in our devicetree yet. Signed-off-by: Hans de Goede <hdegoede@redhat.com> Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
2014-11-23ARM: dts: sun5i: Add simplefb nodeHans de Goede
Add a simplefb template node for u-boot to further fill and activate. Signed-off-by: Hans de Goede <hdegoede@redhat.com> Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
2014-11-23ARM: dts: sunxi: unify APB1 clockEmilio López
With the new factors infrastructure in place, we can unify apb1 and apb1_mux as a single clock now. Signed-off-by: Emilio López <emilio@elopez.com.ar> [wens@csie.org: Change apb1 node label to "apb1"; reword commit title] Signed-off-by: Chen-Yu Tsai <wens@csie.org> Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
2014-10-15Merge tag 'clk-for-linus-3.18' of ↵Linus Torvalds
git://git.linaro.org/people/mike.turquette/linux Pull clock tree updates from Mike Turquette: "The clk tree changes for 3.18 are dominated by clock drivers. Mostly fixes and enhancements to existing drivers as well as new drivers. This tag contains a bit more arch code than I usually take due to some OMAP2+ changes. Additionally it contains the restart notifier handlers which are merged as a dependency into several trees. The PXA changes are the only messy part. Due to having a stable tree I had to revert one patch and follow up with one more fix near the tip of this tag. Some dead code is introduced but it will soon become live code after 3.18-rc1 is released as the rest of the PXA family is converted over to the common clock framework. Another trend in this tag is that multiple vendors have started to push the complexity of changing their CPU frequency into the clock driver, whereas this used to be done in CPUfreq drivers. Changes to the clk core include a generic gpio-clock type and a clk_set_phase() function added to the top-level clk.h api. Due to some confusion on the fbdev mailing list the kernel boot parameters documentation was updated to further explain the clk_ignore_unused parameter, which is often required by users of the simplefb driver. Finally some fixes to the locking around the clock debugfs stuff was done to prevent deadlocks when interacting with other subsystems." * tag 'clk-for-linus-3.18' of git://git.linaro.org/people/mike.turquette/linux: (99 commits) clk: pxa clocks build system fix Revert "arm: pxa: Transition pxa27x to clk framework" clk: samsung: register restart handlers for s3c2412 and s3c2443 clk: rockchip: add restart handler clk: rockchip: rk3288: i2s_frac adds flag to set parent's rate doc/kernel-parameters.txt: clarify clk_ignore_unused arm: pxa: Transition pxa27x to clk framework dts: add devicetree bindings for pxa27x clocks clk: add pxa27x clock drivers arm: pxa: add clock pll selection bits clk: dts: document pxa clock binding clk: add pxa clocks infrastructure clk: gpio-gate: Ensure gpiod_ APIs are prototyped clk: ti: dra7-atl-clock: Mark the device as pm_runtime_irq_safe clk: ti: LLVMLinux: Move __init outside of type definition clk: ti: consider the fact that of_clk_get() might return an error clk: ti: dra7-atl-clock: fix a memory leak clk: ti: change clock init to use generic of_clk_init clk: hix5hd2: add I2C clocks clk: hix5hd2: add watchdog0 clocks ...
2014-09-27ARM: sunxi: dt: Switch to the new mbus compatibleMaxime Ripard
Now that we have a compatible of its own for the mbus clock, switch to it. Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com> Acked-by: Hans de Goede <hdegoede@redhat.com>
2014-08-18ARM: dt: sunxi: Remove i2c controller clock-frequency that matches defaultChen-Yu Tsai
The clock-frequency values of the i2c controller nodes match the defaults of the driver. Remove the properties to use the defaults, and be consistent with sun8i. Signed-off-by: Chen-Yu Tsai <wens@csie.org> Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
2014-08-17ARM: sun5i: dt: enable DMA on SPIEmilio López
All of our SPI controllers support DMA transfers, so let's add the properties here so they can be used when it's best to do so. Signed-off-by: Emilio López <emilio@elopez.com.ar> Reviewed-by: Chen-Yu Tsai <wens@csie.org> Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
2014-08-17ARM: sun5i: dt: Add nodes to represent the DMA controllersEmilio López
The A10S and A13 SoCs have sun4i-compatible DMA controllers. Let's add the corresponding nodes to represent them on the device tree. Signed-off-by: Emilio López <emilio@elopez.com.ar> Reviewed-by: Chen-Yu Tsai <wens@csie.org> Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
2014-07-01ARM: dts: sunxi: Add #interrupt-cells to pinctrl nodesChen-Yu Tsai
The pinctrl device is also an interrupt controller for external interrupts. Add the missing #interrupt-cells property. Also remove the unused #address-cells property. Signed-off-by: Chen-Yu Tsai <wens@csie.org> [hdegoede@redhat.com: make the same change for sun4i, sun5i and sun6i] Signed-off-by: Hans de Goede <hdegoede@redhat.com> Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
2014-06-06Merge branch 'i2c/for-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/wsa/linux into next Pull i2c updates from Wolfram Sang: "I2C has the following updates for 3.16: - major cleanups to the rcar and sh_mobile drivers - removal of nuc900 driver which had a compile error for years - usual bunch of driver updates, bugfixes and cleanups" * 'i2c/for-next' of git://git.kernel.org/pub/scm/linux/kernel/git/wsa/linux: (44 commits) i2c: pca954x: Fix compilation without CONFIG_GPIOLIB i2c: mux: pca954x: Use the descriptor-based GPIO API i2c: mpc: insert DR read in i2c_fixup() i2c: bfin: turn to Resource-managed API in probe function i2c: Make of_device_id array const i2c: remove unnecessary OOM messages i2c: designware-pci: Add Haswell PCI IDs i2c: designware: Add runtime PM hooks i2c: designware: Disable device on system suspend i2c: nuc900: remove driver i2c: imx: update i2c clock divider for each transaction i2c: imx: fix the i2c bus hang issue when do repeat restart i2c: rcar: update copyright and license information i2c: rcar: janitorial cleanup after refactoring i2c: rcar: reuse status bits as enable bits i2c: rcar: remove spinlock i2c: rcar: refactor status bit handling i2c: rcar: refactor setting up msg i2c: rcar: check bus free before first message i2c: rcar: refactor irq state machine ...
2014-05-22ARM: sunxi: dt: Convert to the new i2c compatiblesMaxime Ripard
Switch the device tree to the new compatibles introduced in the i2c drivers to have a common pattern accross all Allwinner SoCs. Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com> Signed-off-by: Wolfram Sang <wsa@the-dreams.de>
2014-05-04ARM: dts: sun5i: Add mmc controller nodesDavid Lanzendörfer
Add nodes for the 3 mmc controllers found on A10s SoCs and for the 2 mmc controllers found on A13 SoCs. Signed-off-by: David Lanzendörfer <david.lanzendoerfer@o2s.ch> Signed-off-by: Hans de Goede <hdegoede@redhat.com> Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
2014-04-28ARM: dts: sun5i: Add pin-muxing info for the mmc controllersHans de Goede
This adds pin-muxing info for the mmc controller / port combinations which are known to be used on actual boards. Signed-off-by: Hans de Goede <hdegoede@redhat.com> Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
2014-04-05Merge tag 'dt-3.15' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-socLinus Torvalds
Pull ARM SoC device tree changes from Arnd Bergmann: "A large part of the arm-soc patches are nowadays DT changes, adding support for new SoCs, boards and devices without changing kernel source. The plan is still to move the devicetree files out of the kernel tree and reduce the amount of churn going on here, but we keep finding reasons to delay doing that. Changes are really all over the place, with little sticking out particularly. We have contributions from a total of 116 people in this branch. Unfortunately, the size of this branch also causes a significant number of conflicts at the moment, typically when subsystem maintainers merge patches that change the driver at the same time as the dts files. In most cases this could be avoided because the dts changes are supposed to be compatible in both ways, and we are asking everyone to send ARM dts changes through our tree only" * tag 'dt-3.15' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (541 commits) dts: stmmac: Document the clocks property in the stmmac base document dts: socfpga: Add DTS entry for adding the stmmac glue layer for stmmac. ARM: STi: stih41x: Add support for the FSM Serial Flash Controller ARM: STi: stih416: Add support for the FSM Serial Flash Controller ARM: tegra: fix Dalmore pinctrl configuration ARM: dts: keystone: use common "ti,keystone" compatible instead of -evm ARM: dts: k2hk-evm: set ubifs partition size for 512M NAND ARM: dts: Build all keystone dt blobs ARM: dts: keystone: Fix control register range for clktsip ARM: dts: keystone: Fix domain register range for clkfftc1 ARM: dts: bcm28155-ap: leave camldo1 on to fix reboot ARM: dts: add bcm590xx pmu support and enable for bcm28155-ap ARM: dts: bcm21664: Add device tree files. ARM: DT: bcm21664: Device tree bindings ARM: efm32: properly namespace i2c location property ARM: efm32: fix unit address part in USART2 device nodes' names ARM: mvebu: Enable NAND controller in Armada 385-DB ARM: mvebu: Add support for NAND controller in Armada 38x SoC ARM: mvebu: Add the Core Divider clock to Armada 38x SoCs ARM: mvebu: Add a 2 GHz fixed-clock on Armada 38x SoCs ...
2014-04-01Merge tag 'char-misc-3.15-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/char-misc Pull char/misc driver patches from Greg KH: "Here's the big char/misc driver updates for 3.15-rc1. Lots of various things here, including the new mcb driver subsystem. All of these have been in linux-next for a while" * tag 'char-misc-3.15-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/char-misc: (118 commits) extcon: Move OF helper function to extcon core and change function name extcon: of: Remove unnecessary function call by using the name of device_node extcon: gpio: Use SIMPLE_DEV_PM_OPS macro extcon: palmas: Use SIMPLE_DEV_PM_OPS macro mei: don't use deprecated DEFINE_PCI_DEVICE_TABLE macro mei: amthif: fix checkpatch error mei: client.h fix checkpatch errors mei: use cl_dbg where appropriate mei: fix Unnecessary space after function pointer name mei: report consistently copy_from/to_user failures mei: drop pr_fmt macros mei: make me hw headers private to me hw. mei: fix memory leak of pending write cb objects mei: me: do not reset when less than expected data is received drivers: mcb: Fix build error discovered by 0-day bot cs5535-mfgpt: Simplify dependencies spmi: pm: drop bus-level PM suspend/resume routines spmi: pmic_arb: make selectable on ARCH_QCOM Drivers: hv: vmbus: Increase the limit on the number of pfns we can handle pch_phub: Report error writing MAC back to user ...
2014-04-01Merge branch 'irq-core-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull irq code updates from Thomas Gleixner: "The irq department proudly presents: - Another tree wide sweep of irq infrastructure abuse. Clear winner of the trainwreck engineering contest was: #include "../../../kernel/irq/settings.h" - Tree wide update of irq_set_affinity() callbacks which miss a cpu online check when picking a single cpu out of the affinity mask. - Tree wide consolidation of interrupt statistics. - Updates to the threaded interrupt infrastructure to allow explicit wakeup of the interrupt thread and a variant of synchronize_irq() which synchronizes only the hard interrupt handler. Both are needed to replace the homebrewn thread handling in the mmc/sdhci code. - New irq chip callbacks to allow proper support for GPIO based irqs. The GPIO based interrupts need to request/release GPIO resources from request/free_irq. - A few new ARM interrupt chips. No revolutionary new hardware, just differently wreckaged variations of the scheme. - Small improvments, cleanups and updates all over the place" I was hoping that that trainwreck engineering contest was a April Fools' joke. But no. * 'irq-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (68 commits) irqchip: sun7i/sun6i: Disable NMI before registering the handler ARM: sun7i/sun6i: dts: Fix IRQ number for sun6i NMI controller ARM: sun7i/sun6i: irqchip: Update the documentation ARM: sun7i/sun6i: dts: Add NMI irqchip support ARM: sun7i/sun6i: irqchip: Add irqchip driver for NMI controller genirq: Export symbol no_action() arm: omap: Fix typo in ams-delta-fiq.c m68k: atari: Fix the last kernel_stat.h fallout irqchip: sun4i: Simplify sun4i_irq_ack irqchip: sun4i: Use handle_fasteoi_irq for all interrupts genirq: procfs: Make smp_affinity values go+r softirq: Add linux/irq.h to make it compile again m68k: amiga: Add linux/irq.h to make it compile again irqchip: sun4i: Don't ack IRQs > 0, fix acking of IRQ 0 irqchip: sun4i: Fix a comment about mask register initialization irqchip: sun4i: Fix irq 0 not working genirq: Add a new IRQCHIP_EOI_THREADED flag genirq: Document IRQCHIP_ONESHOT_SAFE flag ARM: sunxi: dt: Convert to the new irq controller compatibles irqchip: sunxi: Change compatibles ...
2014-04-01Merge branch 'timers-core-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull timer changes from Thomas Gleixner: "This assorted collection provides: - A new timer based timer broadcast feature for systems which do not provide a global accessible timer device. That allows those systems to put CPUs into deep idle states where the per cpu timer device stops. - A few NOHZ_FULL related improvements to the timer wheel - The usual updates to timer devices found in ARM SoCs - Small improvements and updates all over the place" * 'timers-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (44 commits) tick: Remove code duplication in tick_handle_periodic() tick: Fix spelling mistake in tick_handle_periodic() x86: hpet: Use proper destructor for delayed work workqueue: Provide destroy_delayed_work_on_stack() clocksource: CMT, MTU2, TMU and STI should depend on GENERIC_CLOCKEVENTS timer: Remove code redundancy while calling get_nohz_timer_target() hrtimer: Rearrange comments in the order struct members are declared timer: Use variable head instead of &work_list in __run_timers() clocksource: exynos_mct: silence a static checker warning arm: zynq: Add support for cpufreq arm: zynq: Don't use arm_global_timer with cpufreq clocksource/cadence_ttc: Overhaul clocksource frequency adjustment clocksource/cadence_ttc: Call clockevents_update_freq() with IRQs enabled clocksource: Add Kconfig entries for CMT, MTU2, TMU and STI sh: Remove Kconfig entries for TMU, CMT and MTU2 ARM: shmobile: Remove CMT, TMU and STI Kconfig entries clocksource: armada-370-xp: Use atomic access for shared registers clocksource: orion: Use atomic access for shared registers clocksource: timer-keystone: Delete unnecessary variable clocksource: timer-keystone: introduce clocksource driver for Keystone ...
2014-03-17Merge tag 'sunxi-dt-for-3.15-2' of https://github.com/mripard/linux into next/dtArnd Bergmann
Pull "Allwinner DT additions for 3.15, take 2" from Maxime Ripard: - Two new boards: INet 97F Rev 02 and A10-OLinuXino-LIME - Addition of the I2C for the A31 - Addition USB Host mode for the A10, A10s, A13 and A20 - Addition of SATA support for the A10 and A20 - Change of compatible for the watchdog * tag 'sunxi-dt-for-3.15-2' of https://github.com/mripard/linux: (23 commits) ARM: sunxi: dt: Update the watchdog compatibles ARM: sun6i: colombus: Enable the I2C controllers ARM: sun6i: Enable the I2C muxing options ARM: sun6i: Enable the I2C controllers ARM: sun4i: dt: Add support for the INet-97F_Rev_02 board ARM: sun4i: dt: Add support for the A10-OLinuXino-LIME board ARM: sun7i: dt: Add USB host nodes to a20-olinuxino-micro dts ARM: sun7i: dt: Add USB host nodes to cubieboard2 dts ARM: sun7i: dt: Add USB host nodes to cubietruck dts ARM: sun5i: dt: Add USB host nodes to a13-olinuxino-micro ARM: sun5i: dt: Add USB host nodes to a10s-olinuxino-micro ARM: sun5i: dt: Add USB host nodes to A13-Olinuxino ARM: sun4i: dt: Add USB host nodes to pcduino.dts ARM: sun4i: dt: Add USB host nodes to mini-xplus dts ARM: sun4i: dt: Add USB host nodes to hackberry dts ARM: sun4i: dt: Add USB host nodes to cubieboard dts ARM: sun4i: dt: Add USB host nodes to Mele A1000 dts ARM: sun7i: dt: Add USB host bindings ARM: sun5i: dt: Add USB host bindings ARM: sun4i: dt: Add USB host bindings ... Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2014-03-14ARM: sunxi: dt: Convert to the new irq controller compatiblesMaxime Ripard
Switch the device tree to the new compatibles introduced in the irqchip drivers to have a common pattern accross all Allwinner SoCs. Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com> Cc: linux-arm-kernel@lists.infradead.org Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2014-03-13ARM: sunxi: dt: Update the watchdog compatiblesMaxime Ripard
The watchdog compatibles were following a different pattern than the one found in the other devices. Now that the driver supports the right pattern, switch to it in the DT. Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
2014-03-11ARM: sunxi: dt: Convert to the new clocksource compatibleMaxime Ripard
Switch the device tree to the new compatibles introduced in the timer driver to have a common pattern accross all Allwinner SoCs. Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com> Signed-off-by: Daniel Lezcano <daniel.lezcano@linaro.org>
2014-03-09Merge tag 'sunxi-dt-for-3.15' of https://github.com/mripard/linux into next/dtOlof Johansson
Allwinner DT patches for 3.15, take 1 from Maxime Ripard: - Add SPI controllers for all the SoCs - Add various missing aliases - Add USB clocks nodes - Addition of the GMAC support - Introduction of the pcDuino board - A few DT cleanup patches: change of compatibles, * tag 'sunxi-dt-for-3.15' of https://github.com/mripard/linux: (33 commits) ARM: sun6i: dt: Fix mod0 compatible ARM: dts: sun7i: Enable the SPI controllers of the A20-olinuxino-micro ARM: dt: sun7i: Add SPI muxing options ARM: dt: sun5i: Add A13 SPI controller nodes ARM: dt: sun5i: Add A10s SPI controller nodes ARM: dt: sun4i: Add A10 SPI controller nodes ARM: dt: sun7i: Add A20 SPI controller nodes ARM: sun4i: dt: Remove grouping + simple-bus compatible for regulators ARM: sunxi: dt: Convert to the new clock compatibles ARM: sun7i: add arch timer node ARM: sun7i: dt: Add bindings for USB clocks ARM: sun5i: dt: Add bindings for USB clocks ARM: sun4i: dt: Add bindings for USB clocks ARM: dts: sun7i: Add ethernet alias for GMAC ARM: dts: sun7i: a20-olinuxino-micro: Enable GMAC instead of EMAC ARM: dts: sun7i: cubieboard2: Enable GMAC instead of EMAC ARM: dts: sun7i: cubietruck: Enable the GMAC ARM: dts: sun7i: Add pin muxing options for the GMAC ARM: dts: sun7i: Add GMAC controller node to sun7i DTSI ARM: dts: sun7i: Add GMAC clock node to sun7i DTSI ... Signed-off-by: Olof Johansson <olof@lixom.net>
2014-03-08Merge tag 'sunxi-fixes-for-3.14' of https://github.com/mripard/linux into fixesOlof Johansson
Allwinner fixes from Maxime Ripard: Two fixes for device trees additions that got added in 3.14. One fixes the interrupt types of some IPs, the other fixes up a compatible that got introduced during 3.14 * tag 'sunxi-fixes-for-3.14' of https://github.com/mripard/linux: ARM: sunxi: dt: Change the touchscreen compatibles ARM: sun7i: dt: Fix interrupt trigger types Signed-off-by: Olof Johansson <olof@lixom.net>
2014-03-04ARM: sun5i: dt: Add USB host bindingsRoman Byshko
Add nodes for the usb-phy and ehci- and ohci-usb-host controllers. Signed-off-by: Roman Byshko <rbyshko@gmail.com> Signed-off-by: Hans de Goede <hdegoede@redhat.com> Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
