[ Upstream commit ed5fc60b909427be6ca93d3e07a0a5f296d7000a ]
Our HDMI output endpoint on the A10s DTSI has a warning under DTC: "graph
node has single child node 'endpoint', #address-cells/#size-cells are not
necessary". Fix this by removing those properties.
Signed-off-by: Maxime Ripard <maxime.ripard@bootlin.com>
Acked-by: Chen-Yu Tsai <wens@csie.org>
The A10s has an HDMI controller connected to the second TCON channel. Add
it to our DT.
Since the TV Encoder was the only channel 1 user so far, also add the
property now that we have several users.
Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
[wens@csie.org: Replaced CLK_PLL_VIDEO[01]_2X with raw numbers for now
Signed-off-by: Chen-Yu Tsai <wens@csie.org>
All dts files for the sunxi platform have been switched to the generic
pinconf bindings. As a result, the sunxi specific pinctrl macros are
no longer used.
Remove the #include entry with the following command:
sed --follow-symlinks -i -e '/pinctrl\/sun4i-a10.h/D' \
arch/arm/boot/dts/sun?i*.*
arch/arm/boot/dts/sun9i-a80.dtsi was then edited to remove the extra
empty line.
Some controllers found in the A10s DTSI actually apply to all of the sun5i
family. Move those into the common DTSI so that all SoCs can benefit from
it.
There's one UART2 pin group that can be used across all sun5i SoCs.
However, the A10s already has one pin group for that controller.
Change the index of the one in the A10s DTSI, and add the common one to
sun5i.dtsi
Of the three simple framebuffer setups we have in the A10s, two of them can
be shared with the other SoCs from the sun5i family (LCD panel and
composite output).
However, the only one we cannot share is the HDMI, which is the first
listed in the A10s DTSI. In order to make it more logical and so that we
can share the framebuffer nodes in the common DTSI, reorder those nodes.
One of the pins group for the EMAC can be used by all the SoCs of the sun5i
family, and as such can be moved to the common DTSI.
Unfortunately, this group is the second one we declare in our DT for now.
Make it the first one so that it's more logical and consistent with the
rest of our DTs before moving it.
git://git.kernel.org/pub/scm/linux/kernel/git/clk/linux
Pull clk updates from Stephen Boyd:
"The usual collection of new drivers, non-critical fixes, and updates
to existing clk drivers. The bulk of the work is on Allwinner and
Rockchip SoCs, but there's also an Intel Atom driver in here too.
New Drivers:
- Tegra BPMP firmware
- Hisilicon hi3660 SoCs
- Rockchip rk3328 SoCs
- Intel Atom PMC
- STM32F746
- IDT VersaClock 5P49V5923 and 5P49V5933
- Marvell mv98dx3236 SoCs
- Allwinner V3s SoCs
Removed Drivers:
- Samsung Exynos4415 SoCs
Updates:
- Migrate ABx500 to OF
- Qualcomm IPQ4019 CPU clks and general PLL support
- Qualcomm MSM8974 RPM
- Rockchip non-critical fixes and clk id additions
- Samsung Exynos4412 CPUs
- Socionext UniPhier NAND and eMMC support
- ZTE zx296718 i2s and other audio clks
- Renesas CAN and MSIOF clks for R-Car M3-W
- Renesas resets for R-Car Gen2 and Gen3 and RZ/G1
- TI CDCE913, CDCE937, and CDCE949 clk generators
- Marvell Armada ap806 CPU frequencies
- STM32F4* I2S/SAI support
- Broadcom BCM2835 DSI support
- Allwinner sun5i and A80 conversion to new style clk bindings"
* tag 'clk-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/clk/linux: (130 commits)
clk: renesas: mstp: ensure register writes complete
clk: qcom: Do not drop device node twice
clk: mvebu: adjust clock handling for the CP110 system controller
clk: mvebu: Expand mv98dx3236-core-clock support
clk: zte: add i2s clocks for zx296718
clk: sunxi-ng: sun9i-a80: Fix wrong pointer passed to PTR_ERR()
clk: sunxi-ng: select SUNXI_CCU_MULT for sun5i
clk: sunxi-ng: Check kzalloc() for errors and cleanup error path
clk: tegra: Add BPMP clock driver
clk: uniphier: add eMMC clock for LD11 and LD20 SoCs
clk: uniphier: add NAND clock for all UniPhier SoCs
ARM: dts: sun9i: Switch to new clock bindings
clk: sunxi-ng: Add A80 Display Engine CCU
clk: sunxi-ng: Add A80 USB CCU
clk: sunxi-ng: Add A80 CCU
clk: sunxi-ng: Support separately grouped PLL lock status register
clk: sunxi-ng: mux: Get closest parent rate possible with CLK_SET_RATE_PARENT
clk: sunxi-ng: mux: honor CLK_SET_RATE_NO_REPARENT flag
clk: sunxi-ng: mux: Fix determine_rate for mux clocks with pre-dividers
clk: qcom: SDHCI enablement on Nexus 5X / 6P
Now that we have drivers for all of them, convert all the SoCs that share
the sun5i DTSI to the new CCU driver.
Now that we can handle the generic pinctrl bindings, convert our DT to it.
The allwinner,pull property set to NO_PULL was really considered our
default (and wasn't even changing the default value in the code).
Remove these properties to make it obvious that we do not set anything in
such a case.
The allwinner,drive property set to 10mA was really considered as our
default. Remove all those properties entirely to make that obvious.
The SPI2 pins on the sun5i PB bank are only available on the A10s. Rename
the A10s only bank so that it doesn't confuse people on the other SoCs
whose indexing would start at b.
Used on A10s Olinuxino.
Signed-off-by: Michal Suchanek <hramrach@gmail.com>
Now that we've a clock node describing pll3 we must add it to the
simplefb nodes clocks lists to avoid it getting turned off when
simplefb is used.
This fixes the screen going black when using simplefb.
Add dts nodes for the PWM controller on the A13 / A10s.
The uart3 pins are shared between the A10s and A13, move the pinctrl node
to the common DTSI to avoid duplication.
Reviewed-by: Hans de Goede <hdegoede@redhat.com>
Reviewed-by: Chen-Yu Tsai <wens@csie.org>
The emac pins on an A10s can also be routed to the outside through
PORTD rather then through PORTA, add a pinctrl node for this.
Signed-off-by: Jelle van der Waa <jelle@vdwaa.nl>
Add a simplefb node for tvencoder / composite-video output, such as found
on the Auxtek-T003 and the CHIP.
The A10s and A13 gates have a non continuous set of clock IDs that are
valid. Add the clock-indices property to the DT to express this.
Signed-off-by: Michael Turquette <mturquette@baylibre.com>
The A10s and A13 have a few SRAM that can be mapped either to a device or
to the CPU, with the mapping being controlled by a SRAM controller.
Add the SRAM controller, the SRAM that it drives and the section that can
be used by the various devices.
Acked-by: Hans de Goede <hdegoede@redhat.com>
Tested-by: Hans de Goede <hdegoede@redhat.com>
A few lines in our DTSIs are over the 80 characters limit, making
checkpatch complain about that.
If possible (and relevant), wrap these lines to 80 characters.
The FSF address triggers a warning on checkpatch, saying that the FSF
license is already present in the Linux source code, and that it has
already changed in the past.
Remove it from our DT, as suggested.
The A13 and the A10s use the same die (this has been confirmed by Allwinner),
as such there is no need to differentiate between the ehci/ohci parts of both,
the only reasons there were different allwinner,sun5i-a*-foo compatible
between these 2 parts is costemetically and because we could when we still
had 2 completely different dtsi files.
The allwinner,sun5i-a*-foo compatible strings are not used for binding at all,
the actual driver binds to the generic-?hci compatible, so we can safely remove
this cosmetical difference and simplify the dtsi files.
Now that we have a common DTSI for the sun5i family, move the A10s to use it.
The current GPL only licensing on the DTSI makes it very impractical for other
software components licensed under another license.
In order to make it easier for them to reuse our device trees, relicense our
DTSI first under a GPL/X11 dual-license. Hopefully, the DTS will follow soon.
Acked-by: David Lanzendörfer <david.lanzendoerfer@o2s.ch>
Acked-by: Emilio López <emilio@elopez.com.ar>
Acked-by: Lorenzo Pieralisi <lorenzo.pieralisi@arm.com>
Acked-by: Oliver Schinagl <oliver@schinagl.nl>
Acked-by: Roman Byshko <rbyshko@gmail.com>
git://git.linaro.org/people/mike.turquette/linux
Pull clock framework updates from Mike Turquette:
"The clock framework changes contain the usual driver additions,
enhancements and fixes mostly for ARM32, ARM64, MIPS and Power-based
devices.
Additionally the framework core underwent a bit of surgery with two
major changes:
- The boundary between the clock core and clock providers (e.g clock
drivers) is now more well defined with dedicated provider helper
functions. struct clk no longer maps 1:1 with the hardware clock
but is a true per-user cookie which helps us tracker users of
hardware clocks and debug bad behavior.
- The addition of rate constraints for clocks. Rate ranges are now
supported which are analogous to the voltage ranges in the
regulator framework.
Unfortunately these changes to the core created some breakeage. We
think we fixed it all up but for this reason there are lots of last
minute commits trying to undo the damage"
* tag 'clk-for-linus-3.20' of git://git.linaro.org/people/mike.turquette/linux: (113 commits)
clk: Only recalculate the rate if needed
Revert "clk: mxs: Fix invalid 32-bit access to frac registers"
clk: qoriq: Add support for the platform PLL
powerpc/corenet: Enable CLK_QORIQ
clk: Replace explicit clk assignment with __clk_hw_set_clk
clk: Add __clk_hw_set_clk helper function
clk: Don't dereference parent clock if is NULL
MIPS: Alchemy: Remove bogus args from alchemy_clk_fgcs_detr
clkdev: Always allocate a struct clk and call __clk_get() w/ CCF
clk: shmobile: div6: Avoid division by zero in .round_rate()
clk: omap: compile legacy omap3 clocks conditionally
clkdev: Export clk_register_clkdev
clk: Add rate constraints to clocks
clk: remove clk-private.h
pci: xgene: do not use clk-private.h
arm: omap2+ remove dead clock code
clk: Make clk API return per-user struct clk instances
clk: tegra: Define PLLD_DSI and remove dsia(b)_mux
clk: tegra: Add support for the Tegra132 CAR IP block
Pull ARM SoC DT updates from Olof Johansson:
"DT changes continue to be the bulk of our merge window contents.
We continue to have a large set of changes across the board as new
platforms and drivers are added.
Some of the new platforms are:
- Alphascale ASM9260
- Marvell Armada 388
- CSR Atlas7
- TI Davinci DM816x
- Hisilicon HiP01
- ST STiH418
There have also been some sweeping changes, including relicensing of
DTS contents from GPL to GPLv2+/X11 so that the same files can be
reused in other non-GPL projects more easily. There's also been
changes to the DT Makefile to make it a little less conflict-ridden
and churny down the road"
* tag 'dt-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (330 commits)
ARM: dts: Add PPMU node for exynos4412-trats2
ARM: dts: Add PPMU node for exynos3250-monk and exynos3250-rinato
ARM: dts: Add PPMU dt node for exynos4 and exynos4210
ARM: dts: Add PPMU dt node for exynos3250
ARM: dts: add mipi dsi device node for exynos4415
ARM: dts: add fimd device node for exynos4415
ARM: dts: Add syscon phandle to the video-phy node for Exynos4
ARM: dts: Add sound nodes for exynos4412-trats2
ARM: dts: Fix CLK_MOUT_CAMn parent clocks assignment for exynos4412-trats2
ARM: dts: Fix CLK_UART_ISP_SCLK clock assignment in exynos4x12.dtsi
ARM: dts: Add max77693 charger node for exynos4412-trats2
ARM: dts: Switch max77686 regulators to GPIO control for exynos4412-trats2
ARM: dts: Add suspend configuration for max77686 regulators for exynos4412-trats2
ARM: dts: Add Maxim 77693 fuel gauge node for exynos4412-trats2
ARM: dts: am57xx-beagle-x15: Fix USB2 mode
ARM: dts: am57xx-beagle-x15: Add extcon nodes for USB
ARM: dts: dra72-evm: Add extcon nodes for USB
ARM: dts: dra7-evm: Add extcon nodes for USB
ARM: dts: rockchip: move the hdmi ddc-i2c-bus property to the actual boards
ARM: dts: rockchip: enable vops and hdmi output on rk3288-firefly and -evb
Commit f77d55a3b56a ("serial: 8250_dw: get index of serial line from DT
aliases") made the serial driver now use the serial aliases to get the tty
number, pointing out that our aliases have been wrong all along.
Remove them from the DTSI and add custom ones in the relevant boards.
This patch add missing mdio label for sun[457]i.
Signed-off-by: Aleksei Mamlin <mamlinav@gmail.com>
Add simplefb nodes for "[de_fe0-]de_be0-lcd0" and "[de_fe0-]de_be0-lcd0-tve0"
display pipelines for when u-boot has set up a pipeline to drive a LCD panel /
VGA output rather then the HDMI output.
Now that the resistive touchpanel driver supports thermal sensors,
add the "#thermal-sensor-cells" property as required by the thermal
framework.
Acked-by: Eduardo Valentin <edubezval@gmail.com>
The pinctrl nodes require some extra opaque arguments for the pull up and drive
strength values.
Introduce a new header file and convert the device trees to replace these
opaque numbers by defines.
The DMA engine for the A10/A20 and derivatives require an opaque extra
argument.
Add a dt-bindings header, and convert the device trees to it.
Prepare the device trees to use the C preprocessor.
Add the sample and output clocks for the MMC phase support.
Tested-by: Chen-Yu Tsai <wens@csie.org>
usbphy0 support in the sunxi usb-phy driver has been merged, but the
dtsi's for sun4i/sun5i haven't been updated. This results in the phy
driver failing to load, breaking usb support.
Fixes: 6827a46f5994 ('phy: sun4i: add support for USB phy0')
Pull clk framework updates from Mike Turquette:
"This is much later than usual due to several last minute bugs that had
to be addressed. As usual the majority of changes are new drivers and
modifications to existing drivers. The core recieved many fixes along
with the groundwork for several large changes coming in the future
which will better parition clock providers from clock consumers"
* tag 'clk-for-linus-3.19' of git://git.linaro.org/people/mike.turquette/linux: (86 commits)
clk: samsung: Fix Exynos 5420 pinctrl setup and clock disable failure due to domain being gated
ARM: OMAP3: clock: fix boot breakage in legacy mode
ARM: OMAP2+: clock: fix DPLL code to use new determine rate APIs
clk: Really fix deadlock with mmap_sem
clk: mmp: fix sparse non static symbol warning
clk: Change clk_ops->determine_rate to return a clk_hw as the best parent
clk: change clk_debugfs_add_file to take a struct clk_hw
clk: Don't expose __clk_get_accuracy
clk: Don't try to use a struct clk* after it could have been freed
clk: Remove unused function __clk_get_prepare_count
clk: samsung: Fix double add of syscore ops after driver rebind
clk: samsung: exynos4: set parent of sclk_hdmiphy to hdmi
clk: samsung: exynos4415: Fix build with PM_SLEEP disabled
clk: samsung: remove unnecessary inclusion of header files from clk.h
clk: samsung: remove unnecessary CONFIG_OF from clk.c
clk: samsung: Spelling s/bwtween/between/
clk: rockchip: Add support for the mmc clock phases using the framework
clk: rockchip: add bindings for the mmc clocks
clk: rockchip: rk3288 export i2s0_clkout for use in DT
clk: rockchip: use clock ID for DMC (memory controller) on rk3288
Review of the u-boot sunxi simplefb patches has led to the decision that
u-boot should not use a specific path to find the nodes as this goes contrary
to how devicetree usually works.
Instead a platform specific compatible + properties should be used for this.
The simplefb bindings have already been updated to reflect this, this patch
brings the sunxi devicetree files in line with the new binding, and the
actual u-boot implementation as it is going upstream.
Avoid the parent pll for the mod-clk for de_be0 getting disabled when non of
the other users are enabled (which can happen when none of i2c, spi and mmc
are in use).
Note for now we point directly to the parent rather then to the de_be0 mod-clk
as that is not modelled in our devicetree yet.
Add a simplefb template node for u-boot to further fill and activate.
With the new factors infrastructure in place, we can unify apb1 and
apb1_mux as a single clock now.
Signed-off-by: Emilio López <emilio@elopez.com.ar>
[wens@csie.org: Change apb1 node label to "apb1"; reword commit title]
Pull clock tree updates from Mike Turquette:
"The clk tree changes for 3.18 are dominated by clock drivers. Mostly
fixes and enhancements to existing drivers as well as new drivers.
This tag contains a bit more arch code than I usually take due to some
OMAP2+ changes. Additionally it contains the restart notifier
handlers which are merged as a dependency into several trees.
The PXA changes are the only messy part. Due to having a stable tree
I had to revert one patch and follow up with one more fix near the tip
of this tag. Some dead code is introduced but it will soon become
live code after 3.18-rc1 is released as the rest of the PXA family is
converted over to the common clock framework.
Another trend in this tag is that multiple vendors have started to
push the complexity of changing their CPU frequency into the clock
driver, whereas this used to be done in CPUfreq drivers.
Changes to the clk core include a generic gpio-clock type and a
clk_set_phase() function added to the top-level clk.h api. Due to
some confusion on the fbdev mailing list the kernel boot parameters
documentation was updated to further explain the clk_ignore_unused
parameter, which is often required by users of the simplefb driver.
Finally some fixes to the locking around the clock debugfs stuff was
done to prevent deadlocks when interacting with other subsystems."
* tag 'clk-for-linus-3.18' of git://git.linaro.org/people/mike.turquette/linux: (99 commits)
clk: pxa clocks build system fix
Revert "arm: pxa: Transition pxa27x to clk framework"
clk: samsung: register restart handlers for s3c2412 and s3c2443
clk: rockchip: add restart handler
clk: rockchip: rk3288: i2s_frac adds flag to set parent's rate
doc/kernel-parameters.txt: clarify clk_ignore_unused
dts: add devicetree bindings for pxa27x clocks
clk: add pxa27x clock drivers
arm: pxa: add clock pll selection bits
clk: dts: document pxa clock binding
clk: add pxa clocks infrastructure
clk: gpio-gate: Ensure gpiod_ APIs are prototyped
clk: ti: dra7-atl-clock: Mark the device as pm_runtime_irq_safe
clk: ti: LLVMLinux: Move __init outside of type definition
clk: ti: consider the fact that of_clk_get() might return an error
clk: ti: dra7-atl-clock: fix a memory leak
clk: ti: change clock init to use generic of_clk_init
clk: hix5hd2: add I2C clocks
clk: hix5hd2: add watchdog0 clocks
Now that we have a compatible of its own for the mbus clock, switch to it.
The clock-frequency values of the i2c controller nodes match the
defaults of the driver. Remove the properties to use the defaults,
and be consistent with sun8i.
All of our SPI controllers support DMA transfers, so let's add the
properties here so they can be used when it's best to do so.
The A10S and A13 SoCs have sun4i-compatible DMA controllers. Let's add
the corresponding nodes to represent them on the device tree.
The pinctrl device is also an interrupt controller for external
interrupts. Add the missing #interrupt-cells property.
Also remove the unused #address-cells property.
[hdegoede@redhat.com: make the same change for sun4i, sun5i and sun6i]
