path: root/arch/arm/boot/dts/sun5i-a13-hsg-h702.dts
2019-04-04ARM: dts: sunxi: Remove pinctrl groups setting biasMaxime Ripard
So far we've enabled pull-up and pull-down resistors on GPIOs using a pinctrl node. Now that the GPIO binding allows for a flag to declare this, let's switch to it. This brings us closer to removing all the GPIO pinctrl nodes, which will in turn allow us to switch the pinctrl strict mode on. Acked-by: Chen-Yu Tsai <wens@csie.org> Reviewed-by: Linus Walleij <linus.walleij@linaro.org> Signed-off-by: Maxime Ripard <maxime.ripard@bootlin.com>
2018-11-28ARM: dts: sun5i: Provide default muxing for relevant controllersMaxime Ripard
The I2C's, MMC0 and MMC1 controllers have only one muxing option in the SoC. In such a case, we can just move the muxing into the DTSI, and remove it from the DTS. Signed-off-by: Maxime Ripard <maxime.ripard@bootlin.com> Acked-by: Chen-Yu Tsai <wens@csie.org>
2018-11-28ARM: dts: sun5i: Remove underscores from nodes namesMaxime Ripard
Some GPIO pinctrl nodes cannot be easily removed, because they would also change the pin configuration, for example to add a pull resistor or change the current delivered by the pin. Those nodes still have underscores and unit-addresses in their node names in our DTs, so adjust their name to remove the warnings. Use that occasion to also fix some poorly chosen node-names. Signed-off-by: Maxime Ripard <maxime.ripard@bootlin.com> Acked-by: Chen-Yu Tsai <wens@csie.org>
2018-11-28ARM: dts: sun5i: Change pinctrl nodes to avoid warningMaxime Ripard
All our pinctrl nodes were using a node name convention with a unit-address to differentiate the different muxing options. However, since those nodes didn't have a reg property, they were generating warnings in DTC. In order to accomodate for this, convert the old nodes to the syntax we've been using for the new SoCs, including removing the letter suffix of the node labels to the bank of those pins to make things more readable. Signed-off-by: Maxime Ripard <maxime.ripard@bootlin.com> Acked-by: Chen-Yu Tsai <wens@csie.org>
2018-11-28ARM: dts: sun5i: Remove card detect pull-upMaxime Ripard
Boards usually have an external pull-up on the card-detect signal, so there's no need to add another one. This also removes a DTC warning. Signed-off-by: Maxime Ripard <maxime.ripard@bootlin.com> Acked-by: Chen-Yu Tsai <wens@csie.org>
2018-11-28ARM: dts: sun5i: Remove all useless pinctrl nodesMaxime Ripard
The gpio pinctrl nodes are redundant and as such useless most of the times. Since they will also generate warnings in DTC, we can simply remove most of them. Signed-off-by: Maxime Ripard <maxime.ripard@bootlin.com> Acked-by: Chen-Yu Tsai <wens@csie.org>
2018-11-28ARM: dts: sun5i: Change LRADC node names to avoid warningsMaxime Ripard
One of the usage of the LRADC is to implement buttons. The bindings define that we should have one subnode per button, with their associated voltage as a property. However, there was no reg property but we still used the voltage associated to the button as the unit-address, which eventually generated warnings in DTC. Rename the node names to avoid those warnings. Signed-off-by: Maxime Ripard <maxime.ripard@bootlin.com> Acked-by: Chen-Yu Tsai <wens@csie.org>
2018-02-13ARM: dts: sunxi: Switch MMC nodes away from cd-inverted propertyTuomas Tynkkynen
Using the cd-inverted property is not useful when GPIOs are used as card detects since the polarity can be specified with the usual GPIO_ACTIVE_(HIGH|LOW) GPIO flags. It has also caused confusion for U-Boot developers, so migrate all sunxi boards away from cd-inverted. Signed-off-by: Tuomas Tynkkynen <tuomas@tuxera.com> Signed-off-by: Maxime Ripard <maxime.ripard@bootlin.com>
2017-05-14ARM: sunxi: common-regulators: Drop pinmux settings for GPIO pinsChen-Yu Tsai
As part of our effort to move pinctrl/GPIO interlocking into the driver where it belongs, this patch drops the definition and usage of the pinmux settings for the common regulators defined in sunxi-common-regulators.dtsi. Signed-off-by: Chen-Yu Tsai <wens@csie.org> Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
2017-03-27ARM: dts: sunxi: Remove no longer used pinctrl/sun4i-a10.h headerChen-Yu Tsai
All dts files for the sunxi platform have been switched to the generic pinconf bindings. As a result, the sunxi specific pinctrl macros are no longer used. Remove the #include entry with the following command: sed --follow-symlinks -i -e '/pinctrl\/sun4i-a10.h/D' \ arch/arm/boot/dts/sun?i*.* arch/arm/boot/dts/sun9i-a80.dtsi was then edited to remove the extra empty line. Signed-off-by: Chen-Yu Tsai <wens@csie.org> Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
2016-12-26ARM: sunxi: Convert pinctrl nodes to generic bindingsMaxime Ripard
Now that we can handle the generic pinctrl bindings, convert our DT to it. Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com> Acked-by: Chen-Yu Tsai <wens@csie.org> Reviewed-by: Linus Walleij <linus.walleij@linaro.org>
2016-12-26ARM: sunxi: Remove useless allwinner,pull propertyMaxime Ripard
The allwinner,pull property set to NO_PULL was really considered our default (and wasn't even changing the default value in the code). Remove these properties to make it obvious that we do not set anything in such a case. Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com> Acked-by: Chen-Yu Tsai <wens@csie.org> Reviewed-by: Linus Walleij <linus.walleij@linaro.org>
2016-12-26ARM: sunxi: Remove useless allwinner,drive propertyMaxime Ripard
The allwinner,drive property set to 10mA was really considered as our default. Remove all those properties entirely to make that obvious. Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com> Acked-by: Chen-Yu Tsai <wens@csie.org> Reviewed-by: Linus Walleij <linus.walleij@linaro.org>
2015-07-31ARM: dts: sun5i: hsg-h702: Enable USB OTG controllerChen-Yu Tsai
This tablet has proper USB OTG support, using 3 GPIO pins for ID and VBUS detection, and also VBUS control. Signed-off-by: Chen-Yu Tsai <wens@csie.org> Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
2015-07-31ARM: dts: sun5i: hsg-h702: Enable side volume buttons with LRADCChen-Yu Tsai
The tablet has volume up/down buttons on the side, connected to the LRADC. Signed-off-by: Chen-Yu Tsai <wens@csie.org> Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
2015-05-10ARM: sunxi: dt: Remove the FSF addressMaxime Ripard
The FSF address triggers a warning on checkpatch, saying that the FSF license is already present in the Linux source code, and that it has already changed in the past. Remove it from our DT, as suggested. Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
2015-04-27ARM: sunxi: DT: Add stdout-path propertyMaxime Ripard
Add UART aliases and stdout-path property for all the Allwinner boards so that we won't have to rely on the bootargs' console= value, while working with legacy bootloaders. While we're at it, also remove the mentions of earlyprintk in the bootargs, that will remove our default bootargs entirely, and allow the kernel to boot on a system even if DEBUG_LL is configured for another system. Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
2015-04-27ARM: sun5i: a13: hsg h702: Convert to DT label based syntaxMaxime Ripard
In order to lessen the amount of duplication of the DT tree, ease the new and follow the trend that prefers to use label based references when overriding DTSI nodes, convert the board to this syntax Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
2015-02-17Merge tag 'dt-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull ARM SoC DT updates from Olof Johansson: "DT changes continue to be the bulk of our merge window contents. We continue to have a large set of changes across the board as new platforms and drivers are added. Some of the new platforms are: - Alphascale ASM9260 - Marvell Armada 388 - CSR Atlas7 - TI Davinci DM816x - Hisilicon HiP01 - ST STiH418 There have also been some sweeping changes, including relicensing of DTS contents from GPL to GPLv2+/X11 so that the same files can be reused in other non-GPL projects more easily. There's also been changes to the DT Makefile to make it a little less conflict-ridden and churny down the road" * tag 'dt-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (330 commits) ARM: dts: Add PPMU node for exynos4412-trats2 ARM: dts: Add PPMU node for exynos3250-monk and exynos3250-rinato ARM: dts: Add PPMU dt node for exynos4 and exynos4210 ARM: dts: Add PPMU dt node for exynos3250 ARM: dts: add mipi dsi device node for exynos4415 ARM: dts: add fimd device node for exynos4415 ARM: dts: Add syscon phandle to the video-phy node for Exynos4 ARM: dts: Add sound nodes for exynos4412-trats2 ARM: dts: Fix CLK_MOUT_CAMn parent clocks assignment for exynos4412-trats2 ARM: dts: Fix CLK_UART_ISP_SCLK clock assignment in exynos4x12.dtsi ARM: dts: Add max77693 charger node for exynos4412-trats2 ARM: dts: Switch max77686 regulators to GPIO control for exynos4412-trats2 ARM: dts: Add suspend configuration for max77686 regulators for exynos4412-trats2 ARM: dts: Add Maxim 77693 fuel gauge node for exynos4412-trats2 ARM: dts: am57xx-beagle-x15: Fix USB2 mode ARM: dts: am57xx-beagle-x15: Add extcon nodes for USB ARM: dts: dra72-evm: Add extcon nodes for USB ARM: dts: dra7-evm: Add extcon nodes for USB ARM: dts: rockchip: move the hdmi ddc-i2c-bus property to the actual boards ARM: dts: rockchip: enable vops and hdmi output on rk3288-firefly and -evb ...
2015-01-25ARM: sunxi: dt: Fix aliasesMaxime Ripard
Commit f77d55a3b56a ("serial: 8250_dw: get index of serial line from DT aliases") made the serial driver now use the serial aliases to get the tty number, pointing out that our aliases have been wrong all along. Remove them from the DTSI and add custom ones in the relevant boards. Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
2015-01-21ARM: dts: sun5i: hsg-h702: add axp209 regulator nodesChen-Yu Tsai
This patch adds the regulator nodes for the axp209 by including the axp209 dtsi. As the inputs of these regulators are from the axp209's PS output, which is basically just a mux over the 2 inputs, it is considered to be unregulated. Thus we do not provide input supply properties for them. The regulator names and constraints are based on the board schematics and the SoC datasheet. DCDC2 is used as the cpu power supply. This patch also references it from the cpu node. LDO3 powers the USB WiFi module. This patch also references it from the usb-phy node. Also get rid of axp209 properties already set in axp209.dtsi. Signed-off-by: Chen-Yu Tsai <wens@csie.org> Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
2015-01-21ARM: sunxi: DT: Convert the DTs to use a header for the pinctrl nodesMaxime Ripard
The pinctrl nodes require some extra opaque arguments for the pull up and drive strength values. Introduce a new header file and convert the device trees to replace these opaque numbers by defines. Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
2015-01-21ARM: sunxi: DT: convert DTs to use common GPIOs includesMaxime Ripard
Replace the various raw GPIO flags by their definition in the common dt-bindings header. Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
2015-01-21ARM: sunxi: DT: Convert to device tree includesMaxime Ripard
Prepare the device trees to use the C preprocessor. Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
2014-10-27ARM: sunxi: Fix GPLv2 wordingMaxime Ripard
During the GPL to GPL/X11 licensing migration, the GPL notice introduced mentionned the device trees as a library, which is not really accurate. It began to spread by copy and paste. Fix all these library mentions to reflect the file that it's actually just a file. Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
2014-09-17ARM: dts: sun5i: Add DT for HSG H702 tablet boardChen-Yu Tsai
This is a Q8 format 7 inch tablet with an Allwinner A13 SoC. It has 512MB DRAM, 4GB NAND flash, an accelerometer, camera, RTL8188-based WiFi, and micro SD slot for external storage. It is likely made by a subsidiary of Hanns.G (Hannstar). Signed-off-by: Chen-Yu Tsai <wens@csie.org> Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
