Set cpu_alert0 temperature to 85°C instead of 850°C.
Fixes: 32a5d2d170cc ("ARM: dts: sun5i: Add cpu thermal zones to dtsi")
Signed-off-by: Hugo Grostabussiat <bonstra@bonstra.fr.eu.org>
Acked-by: Chen-Yu Tsai <wens@csie.org>
Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
Most of the display engine is shared between the R8 and the A13. Move the
common parts to the Á13 DTSI.
The RGB bus can be used in several configurations, one of which being the
RGB666.
Add a pinctrl group for that case.
Enable the display and TCON (channel 0 and channel 1) clocks that are going
to be needed to drive the display engine, tcon and TV encoders.
The DRAM gates control whether the image / display devices on the SoC have
access to the DRAM clock or not.
Enable it.
It turns out that the A13 / R8 also have a tve encoder block, and a gate
for it.
Add it to the DT.
Add dts nodes for the PWM controller on the A13 / A10s.
The A10s and A13 gates have a non continuous set of clock IDs that are
valid. Add the clock-indices property to the DT to express this.
Signed-off-by: Michael Turquette <mturquette@baylibre.com>
A few lines (probably copy pasted) have an indentation mixing tabs and
spaces that triggers a checkpatch warning.
Fix those, and while we're at it, fix the space-indented sections.
A few lines in our DTSIs are over the 80 characters limit, making
checkpatch complain about that.
If possible (and relevant), wrap these lines to 80 characters.
The FSF address triggers a warning on checkpatch, saying that the FSF
license is already present in the Linux source code, and that it has
already changed in the past.
Remove it from our DT, as suggested.
The A13 and the A10s use the same die (this has been confirmed by Allwinner),
as such there is no need to differentiate between the ehci/ohci parts of both,
the only reasons there were different allwinner,sun5i-a*-foo compatible
between these 2 parts is costemetically and because we could when we still
had 2 completely different dtsi files.
The allwinner,sun5i-a*-foo compatible strings are not used for binding at all,
the actual driver binds to the generic-?hci compatible, so we can safely remove
this cosmetical difference and simplify the dtsi files.
Now that we have a common DTSI for the sun5i family, move the A13 to use it.
The current GPL only licensing on the DTSI makes it very impractical for other
software components licensed under another license.
In order to make it easier for them to reuse our device trees, relicense our
DTSI first under a GPL/X11 dual-license. Hopefully, the DTS will follow soon.
Acked-by: David Lanzendörfer <david.lanzendoerfer@o2s.ch>
Acked-by: Emilio López <emilio@elopez.com.ar>
Acked-by: Hans de Goede <hdegoede@redhat.com>
Acked-by: Lorenzo Pieralisi <lorenzo.pieralisi@arm.com>
Acked-by: Oliver Schinagl <oliver@schinagl.nl>
Acked-by: Roman Byshko <rbyshko@gmail.com>
Without proper regulator support for individual boards, it is dangerous
to have overclocked/overvoltaged OPPs in the list. Cpufreq will increase
the frequency without the accompanying voltage increase, resulting in
an unstable system.
Remove them for now. We can revisit them with the new version of OPP
bindings, which support boost settings and frequency ranges, among
other things.
Signed-off-by: Chen-Yu Tsai <wens@csie.org>
git://git.linaro.org/people/mike.turquette/linux
Pull clock framework updates from Mike Turquette:
"The clock framework changes contain the usual driver additions,
enhancements and fixes mostly for ARM32, ARM64, MIPS and Power-based
devices.
Additionally the framework core underwent a bit of surgery with two
major changes:
- The boundary between the clock core and clock providers (e.g clock
drivers) is now more well defined with dedicated provider helper
functions. struct clk no longer maps 1:1 with the hardware clock
but is a true per-user cookie which helps us tracker users of
hardware clocks and debug bad behavior.
- The addition of rate constraints for clocks. Rate ranges are now
supported which are analogous to the voltage ranges in the
regulator framework.
Unfortunately these changes to the core created some breakeage. We
think we fixed it all up but for this reason there are lots of last
minute commits trying to undo the damage"
* tag 'clk-for-linus-3.20' of git://git.linaro.org/people/mike.turquette/linux: (113 commits)
clk: Only recalculate the rate if needed
Revert "clk: mxs: Fix invalid 32-bit access to frac registers"
clk: qoriq: Add support for the platform PLL
powerpc/corenet: Enable CLK_QORIQ
clk: Replace explicit clk assignment with __clk_hw_set_clk
clk: Add __clk_hw_set_clk helper function
clk: Don't dereference parent clock if is NULL
MIPS: Alchemy: Remove bogus args from alchemy_clk_fgcs_detr
clkdev: Always allocate a struct clk and call __clk_get() w/ CCF
clk: shmobile: div6: Avoid division by zero in .round_rate()
clk: omap: compile legacy omap3 clocks conditionally
clkdev: Export clk_register_clkdev
clk: Add rate constraints to clocks
clk: remove clk-private.h
pci: xgene: do not use clk-private.h
arm: omap2+ remove dead clock code
clk: Make clk API return per-user struct clk instances
clk: tegra: Define PLLD_DSI and remove dsia(b)_mux
clk: tegra: Add support for the Tegra132 CAR IP block
Pull ARM SoC DT updates from Olof Johansson:
"DT changes continue to be the bulk of our merge window contents.
We continue to have a large set of changes across the board as new
platforms and drivers are added.
Some of the new platforms are:
- Alphascale ASM9260
- Marvell Armada 388
- CSR Atlas7
- TI Davinci DM816x
- Hisilicon HiP01
- ST STiH418
There have also been some sweeping changes, including relicensing of
DTS contents from GPL to GPLv2+/X11 so that the same files can be
reused in other non-GPL projects more easily. There's also been
changes to the DT Makefile to make it a little less conflict-ridden
and churny down the road"
* tag 'dt-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (330 commits)
ARM: dts: Add PPMU node for exynos4412-trats2
ARM: dts: Add PPMU node for exynos3250-monk and exynos3250-rinato
ARM: dts: Add PPMU dt node for exynos4 and exynos4210
ARM: dts: Add PPMU dt node for exynos3250
ARM: dts: add mipi dsi device node for exynos4415
ARM: dts: add fimd device node for exynos4415
ARM: dts: Add syscon phandle to the video-phy node for Exynos4
ARM: dts: Add sound nodes for exynos4412-trats2
ARM: dts: Fix CLK_MOUT_CAMn parent clocks assignment for exynos4412-trats2
ARM: dts: Fix CLK_UART_ISP_SCLK clock assignment in exynos4x12.dtsi
ARM: dts: Add max77693 charger node for exynos4412-trats2
ARM: dts: Switch max77686 regulators to GPIO control for exynos4412-trats2
ARM: dts: Add suspend configuration for max77686 regulators for exynos4412-trats2
ARM: dts: Add Maxim 77693 fuel gauge node for exynos4412-trats2
ARM: dts: am57xx-beagle-x15: Fix USB2 mode
ARM: dts: am57xx-beagle-x15: Add extcon nodes for USB
ARM: dts: dra72-evm: Add extcon nodes for USB
ARM: dts: dra7-evm: Add extcon nodes for USB
ARM: dts: rockchip: move the hdmi ddc-i2c-bus property to the actual boards
ARM: dts: rockchip: enable vops and hdmi output on rk3288-firefly and -evb
Commit f77d55a3b56a ("serial: 8250_dw: get index of serial line from DT
aliases") made the serial driver now use the serial aliases to get the tty
number, pointing out that our aliases have been wrong all along.
Remove them from the DTSI and add custom ones in the relevant boards.
The core temperature sensor now supports thermal zones. Add a thermal
zone mapping for the cpus with passive cooling (cpufreq throttling).
Acked-by: Eduardo Valentin <edubezval@gmail.com>
Add simplefb nodes for "[de_fe0-]de_be0-lcd0" and "[de_fe0-]de_be0-lcd0-tve0"
display pipelines for when u-boot has set up a pipeline to drive a LCD panel /
VGA output rather then the HDMI output.
The cpu core is clocked from the "cpu" clock. Add a reference to it
in the first cpu node. Also add "cpu0" label to the node.
The operating points were taken from the A13 FEX files in the
sunxi-boards repository. All FEX files have the same settings.
Now that the resistive touchpanel driver supports thermal sensors,
add the "#thermal-sensor-cells" property as required by the thermal
framework.
The pinctrl nodes require some extra opaque arguments for the pull up and drive
strength values.
Introduce a new header file and convert the device trees to replace these
opaque numbers by defines.
The DMA engine for the A10/A20 and derivatives require an opaque extra
argument.
Add a dt-bindings header, and convert the device trees to it.
Prepare the device trees to use the C preprocessor.
Add the sample and output clocks for the MMC phase support.
Reviewed-by: Chen-Yu Tsai <wens@csie.org>
Tested-by: Chen-Yu Tsai <wens@csie.org>
usbphy0 support in the sunxi usb-phy driver has been merged, but the
dtsi's for sun4i/sun5i haven't been updated. This results in the phy
driver failing to load, breaking usb support.
Fixes: 6827a46f5994 ('phy: sun4i: add support for USB phy0')
With the new factors infrastructure in place, we can unify apb1 and
apb1_mux as a single clock now.
Signed-off-by: Emilio López <emilio@elopez.com.ar>
[wens@csie.org: Change apb1 node label to "apb1"; reword commit title]
Pull clock tree updates from Mike Turquette:
"The clk tree changes for 3.18 are dominated by clock drivers. Mostly
fixes and enhancements to existing drivers as well as new drivers.
This tag contains a bit more arch code than I usually take due to some
OMAP2+ changes. Additionally it contains the restart notifier
handlers which are merged as a dependency into several trees.
The PXA changes are the only messy part. Due to having a stable tree
I had to revert one patch and follow up with one more fix near the tip
of this tag. Some dead code is introduced but it will soon become
live code after 3.18-rc1 is released as the rest of the PXA family is
converted over to the common clock framework.
Another trend in this tag is that multiple vendors have started to
push the complexity of changing their CPU frequency into the clock
driver, whereas this used to be done in CPUfreq drivers.
Changes to the clk core include a generic gpio-clock type and a
clk_set_phase() function added to the top-level clk.h api. Due to
some confusion on the fbdev mailing list the kernel boot parameters
documentation was updated to further explain the clk_ignore_unused
parameter, which is often required by users of the simplefb driver.
Finally some fixes to the locking around the clock debugfs stuff was
done to prevent deadlocks when interacting with other subsystems."
* tag 'clk-for-linus-3.18' of git://git.linaro.org/people/mike.turquette/linux: (99 commits)
clk: pxa clocks build system fix
Revert "arm: pxa: Transition pxa27x to clk framework"
clk: samsung: register restart handlers for s3c2412 and s3c2443
clk: rockchip: add restart handler
clk: rockchip: rk3288: i2s_frac adds flag to set parent's rate
doc/kernel-parameters.txt: clarify clk_ignore_unused
dts: add devicetree bindings for pxa27x clocks
clk: add pxa27x clock drivers
arm: pxa: add clock pll selection bits
clk: dts: document pxa clock binding
clk: add pxa clocks infrastructure
clk: gpio-gate: Ensure gpiod_ APIs are prototyped
clk: ti: dra7-atl-clock: Mark the device as pm_runtime_irq_safe
clk: ti: LLVMLinux: Move __init outside of type definition
clk: ti: consider the fact that of_clk_get() might return an error
clk: ti: dra7-atl-clock: fix a memory leak
clk: ti: change clock init to use generic of_clk_init
clk: hix5hd2: add I2C clocks
clk: hix5hd2: add watchdog0 clocks
Now that we have a compatible of its own for the mbus clock, switch to it.
The clock-frequency values of the i2c controller nodes match the
defaults of the driver. Remove the properties to use the defaults,
and be consistent with sun8i.
All of our SPI controllers support DMA transfers, so let's add the
properties here so they can be used when it's best to do so.
The A10S and A13 SoCs have sun4i-compatible DMA controllers. Let's add
the corresponding nodes to represent them on the device tree.
The pinctrl device is also an interrupt controller for external
interrupts. Add the missing #interrupt-cells property.
Also remove the unused #address-cells property.
[hdegoede@redhat.com: make the same change for sun4i, sun5i and sun6i]
git://git.kernel.org/pub/scm/linux/kernel/git/wsa/linux into next
Pull i2c updates from Wolfram Sang:
"I2C has the following updates for 3.16:
- major cleanups to the rcar and sh_mobile drivers
- removal of nuc900 driver which had a compile error for years
- usual bunch of driver updates, bugfixes and cleanups"
* 'i2c/for-next' of git://git.kernel.org/pub/scm/linux/kernel/git/wsa/linux: (44 commits)
i2c: pca954x: Fix compilation without CONFIG_GPIOLIB
i2c: mux: pca954x: Use the descriptor-based GPIO API
i2c: mpc: insert DR read in i2c_fixup()
i2c: bfin: turn to Resource-managed API in probe function
i2c: Make of_device_id array const
i2c: remove unnecessary OOM messages
i2c: designware-pci: Add Haswell PCI IDs
i2c: designware: Add runtime PM hooks
i2c: designware: Disable device on system suspend
i2c: nuc900: remove driver
i2c: imx: update i2c clock divider for each transaction
i2c: imx: fix the i2c bus hang issue when do repeat restart
i2c: rcar: update copyright and license information
i2c: rcar: janitorial cleanup after refactoring
i2c: rcar: reuse status bits as enable bits
i2c: rcar: remove spinlock
i2c: rcar: refactor status bit handling
i2c: rcar: refactor setting up msg
i2c: rcar: check bus free before first message
i2c: rcar: refactor irq state machine
Switch the device tree to the new compatibles introduced in the i2c drivers
to have a common pattern accross all Allwinner SoCs.
Signed-off-by: Wolfram Sang <wsa@the-dreams.de>
Add nodes for the 3 mmc controllers found on A10s SoCs and for the 2 mmc
controllers found on A13 SoCs.
Signed-off-by: David Lanzendörfer <david.lanzendoerfer@o2s.ch>
This adds pin-muxing info for the mmc controller / port combinations which
are known to be used on actual boards.
Pull ARM SoC device tree changes from Arnd Bergmann:
"A large part of the arm-soc patches are nowadays DT changes, adding
support for new SoCs, boards and devices without changing kernel
source. The plan is still to move the devicetree files out of the
kernel tree and reduce the amount of churn going on here, but we keep
finding reasons to delay doing that.
Changes are really all over the place, with little sticking out
particularly. We have contributions from a total of 116 people in
this branch.
Unfortunately, the size of this branch also causes a significant
number of conflicts at the moment, typically when subsystem
maintainers merge patches that change the driver at the same time as
the dts files. In most cases this could be avoided because the dts
changes are supposed to be compatible in both ways, and we are asking
everyone to send ARM dts changes through our tree only"
* tag 'dt-3.15' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (541 commits)
dts: stmmac: Document the clocks property in the stmmac base document
dts: socfpga: Add DTS entry for adding the stmmac glue layer for stmmac.
ARM: STi: stih41x: Add support for the FSM Serial Flash Controller
ARM: STi: stih416: Add support for the FSM Serial Flash Controller
ARM: tegra: fix Dalmore pinctrl configuration
ARM: dts: keystone: use common "ti,keystone" compatible instead of -evm
ARM: dts: k2hk-evm: set ubifs partition size for 512M NAND
ARM: dts: Build all keystone dt blobs
ARM: dts: keystone: Fix control register range for clktsip
ARM: dts: keystone: Fix domain register range for clkfftc1
ARM: dts: bcm28155-ap: leave camldo1 on to fix reboot
ARM: dts: add bcm590xx pmu support and enable for bcm28155-ap
ARM: dts: bcm21664: Add device tree files.
ARM: DT: bcm21664: Device tree bindings
ARM: efm32: properly namespace i2c location property
ARM: efm32: fix unit address part in USART2 device nodes' names
ARM: mvebu: Enable NAND controller in Armada 385-DB
ARM: mvebu: Add support for NAND controller in Armada 38x SoC
ARM: mvebu: Add the Core Divider clock to Armada 38x SoCs
ARM: mvebu: Add a 2 GHz fixed-clock on Armada 38x SoCs
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/char-misc
Pull char/misc driver patches from Greg KH:
"Here's the big char/misc driver updates for 3.15-rc1.
Lots of various things here, including the new mcb driver subsystem.
All of these have been in linux-next for a while"
* tag 'char-misc-3.15-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/char-misc: (118 commits)
extcon: Move OF helper function to extcon core and change function name
extcon: of: Remove unnecessary function call by using the name of device_node
extcon: gpio: Use SIMPLE_DEV_PM_OPS macro
extcon: palmas: Use SIMPLE_DEV_PM_OPS macro
mei: don't use deprecated DEFINE_PCI_DEVICE_TABLE macro
mei: amthif: fix checkpatch error
mei: client.h fix checkpatch errors
mei: use cl_dbg where appropriate
mei: fix Unnecessary space after function pointer name
mei: report consistently copy_from/to_user failures
mei: drop pr_fmt macros
mei: make me hw headers private to me hw.
mei: fix memory leak of pending write cb objects
mei: me: do not reset when less than expected data is received
drivers: mcb: Fix build error discovered by 0-day bot
cs5535-mfgpt: Simplify dependencies
spmi: pm: drop bus-level PM suspend/resume routines
spmi: pmic_arb: make selectable on ARCH_QCOM
Drivers: hv: vmbus: Increase the limit on the number of pfns we can handle
pch_phub: Report error writing MAC back to user
Pull irq code updates from Thomas Gleixner:
"The irq department proudly presents:
- Another tree wide sweep of irq infrastructure abuse. Clear winner
of the trainwreck engineering contest was:
#include "../../../kernel/irq/settings.h"
- Tree wide update of irq_set_affinity() callbacks which miss a cpu
online check when picking a single cpu out of the affinity mask.
- Tree wide consolidation of interrupt statistics.
- Updates to the threaded interrupt infrastructure to allow explicit
wakeup of the interrupt thread and a variant of synchronize_irq()
which synchronizes only the hard interrupt handler. Both are
needed to replace the homebrewn thread handling in the mmc/sdhci
code.
- New irq chip callbacks to allow proper support for GPIO based irqs.
The GPIO based interrupts need to request/release GPIO resources
from request/free_irq.
- A few new ARM interrupt chips. No revolutionary new hardware, just
differently wreckaged variations of the scheme.
- Small improvments, cleanups and updates all over the place"
I was hoping that that trainwreck engineering contest was a April Fools'
joke. But no.
* 'irq-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (68 commits)
irqchip: sun7i/sun6i: Disable NMI before registering the handler
ARM: sun7i/sun6i: dts: Fix IRQ number for sun6i NMI controller
ARM: sun7i/sun6i: irqchip: Update the documentation
ARM: sun7i/sun6i: dts: Add NMI irqchip support
ARM: sun7i/sun6i: irqchip: Add irqchip driver for NMI controller
genirq: Export symbol no_action()
arm: omap: Fix typo in ams-delta-fiq.c
m68k: atari: Fix the last kernel_stat.h fallout
irqchip: sun4i: Simplify sun4i_irq_ack
irqchip: sun4i: Use handle_fasteoi_irq for all interrupts
genirq: procfs: Make smp_affinity values go+r
softirq: Add linux/irq.h to make it compile again
m68k: amiga: Add linux/irq.h to make it compile again
irqchip: sun4i: Don't ack IRQs > 0, fix acking of IRQ 0
irqchip: sun4i: Fix a comment about mask register initialization
irqchip: sun4i: Fix irq 0 not working
genirq: Add a new IRQCHIP_EOI_THREADED flag
genirq: Document IRQCHIP_ONESHOT_SAFE flag
ARM: sunxi: dt: Convert to the new irq controller compatibles
irqchip: sunxi: Change compatibles
Pull timer changes from Thomas Gleixner:
"This assorted collection provides:
- A new timer based timer broadcast feature for systems which do not
provide a global accessible timer device. That allows those
systems to put CPUs into deep idle states where the per cpu timer
device stops.
- A few NOHZ_FULL related improvements to the timer wheel
- The usual updates to timer devices found in ARM SoCs
- Small improvements and updates all over the place"
* 'timers-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (44 commits)
tick: Remove code duplication in tick_handle_periodic()
tick: Fix spelling mistake in tick_handle_periodic()
x86: hpet: Use proper destructor for delayed work
workqueue: Provide destroy_delayed_work_on_stack()
clocksource: CMT, MTU2, TMU and STI should depend on GENERIC_CLOCKEVENTS
timer: Remove code redundancy while calling get_nohz_timer_target()
hrtimer: Rearrange comments in the order struct members are declared
timer: Use variable head instead of &work_list in __run_timers()
clocksource: exynos_mct: silence a static checker warning
arm: zynq: Add support for cpufreq
arm: zynq: Don't use arm_global_timer with cpufreq
clocksource/cadence_ttc: Overhaul clocksource frequency adjustment
clocksource/cadence_ttc: Call clockevents_update_freq() with IRQs enabled
clocksource: Add Kconfig entries for CMT, MTU2, TMU and STI
sh: Remove Kconfig entries for TMU, CMT and MTU2
ARM: shmobile: Remove CMT, TMU and STI Kconfig entries
clocksource: armada-370-xp: Use atomic access for shared registers
clocksource: orion: Use atomic access for shared registers
clocksource: timer-keystone: Delete unnecessary variable
clocksource: timer-keystone: introduce clocksource driver for Keystone
Switch the device tree to the new compatibles introduced in the irqchip drivers
The watchdog compatibles were following a different pattern than the one found
in the other devices. Now that the driver supports the right pattern, switch to
it in the DT.
Switch the device tree to the new compatibles introduced in the timer driver
Signed-off-by: Daniel Lezcano <daniel.lezcano@linaro.org>
Add nodes for the usb-phy and ehci- and ohci-usb-host controllers.
Signed-off-by: Roman Byshko <rbyshko@gmail.com>
The A13 has 3 SPI controllers compatible with the one found in the A10. Add
them in the DT.
