The CHIP has a status LED connected to one of the AXP GPIOs. Add the
gpio-leds node to be able to use the proper LED framework to control it.
Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
The sun4i-timer driver registers its sched_clock only if the machine is
compatible with "allwinner,sun5i-a13", "allwinner,sun5i-a10s" or
"allwinner,sun4i-a10".
Add the missing "allwinner,sun5i-a13" string to the machine compatible.
Signed-off-by: Boris Brezillon <boris.brezillon@free-electrons.com>
Fixes: 465a225fb2af ("ARM: sun5i: Add C.H.I.P DTS")
Cc: <stable@vger.kernel.org>
The CHIP has a composite output available muxed with the microphone in the
micro-jack plug.
Enable the composite output in its DTS.
The current DT doesn't have a phandle to the CPU regulator in the CPU node,
which disables the CPU voltage scaling entirely.
Add that phandle.
The CHIP v0.2 has a composite output on a mini-jack connector, the audio
part being provided by the on-SoC codec. Enable it.
Acked-by: Chen-Yu Tsai <wens@csie.org>
The C.H.I.P. is a small SBC with an Allwinner R8, 8GB of NAND, 512MB of
RAM, USB host and OTG, a wifi / bluetooth combo chip, an audio/video jack
and two connectors to plug additional boards on top of it.
Reviewed-by: Hans de Goede <hdegoede@redhat.com>
