Some controllers found in the R8 DTSI actually apply to all of the sun5i
family. Move those into the common DTSI so that all SoCs can benefit from
it.
Acked-by: Chen-Yu Tsai <wens@csie.org>
Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
Now that we have drivers for all of them, convert all the SoCs that share
the sun5i DTSI to the new CCU driver.
Most of the display engine is shared between the R8 and the A13. Move the
common parts to the Á13 DTSI.
The TCON, tv-encoder and display engine backends and frontends are combined
to create our display pipeline.
Add them to the R8 DTSI. It's supposed to be perfectly compatible with the
A10s and A13, but since we haven't tested it on them yet, it's safer to
just enable it on the R8. Eventually, it should be moved to sun5i.dtsi
Enable the display and TCON (channel 0 and channel 1) clocks that are going
to be needed to drive the display engine, tcon and TV encoders.
The DRAM gates control whether the image / display devices on the SoC have
access to the DRAM clock or not.
Enable it.
The R8 is very close to the A13, but it still has a few differences,
notably a composite output, which the A13 lacks.
Add a DTSI based on the A13's to hold those differences.
Reviewed-by: Chen-Yu Tsai <wens@csie.org>
Reviewed-by: Hans de Goede <hdegoede@redhat.com>
