The BananaPro uses uart4 for the default rx/tx pins on the 40 pins connector,
so enable uart4.
Uart2 is also available at the bananapro io-pins, but like on the bananapi
the primary function of the pins is to act as gpios, see:
http://forum.lemaker.org/forum.php?mod=viewthread&tid=10852
Remove the uart2 node, people who want to use uart2 can do so with a
devicetree-overlay.
Signed-off-by: Michael Ring <mail@michael-ring.org>
[hdegoede@redhat.com: Remove uart2 node]
Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
The pinctrl groups for SPI until now were also adding the chip selects in
the SPI pinctrl group.
This was causing a few issues, since a board was forced to use a random
number of chipselects, even though it might use one of these chip selects
for another pin.
The number of chipselects defined was also not the same from one group to
another because of different needs at the time these groups have been
introduced, resulting in no clear view from the board DTS on what exactly
is being muxed, which even might change in the future.
Solve this by creating different pinctrl groups for the chipselects and the
standard SPI pins (CLK, MOSI and MISO) so that we fix both issues.
The FSF address triggers a warning on checkpatch, saying that the FSF
license is already present in the Linux source code, and that it has
already changed in the past.
Remove it from our DT, as suggested.
Currently none of the target boards nor the driver supports
IR TX. However this pin is used in a few instances as a GPIO.
Split the pin ctrl descriptions so that only the IR RX is
configured to be used.
Signed-off-by: Marcus Cooper <codekipper@gmail.com>
Add UART aliases and stdout-path property for all the Allwinner boards so that
we won't have to rely on the bootargs' console= value, while working with
legacy bootloaders.
While we're at it, also remove the mentions of earlyprintk in the bootargs,
that will remove our default bootargs entirely, and allow the kernel to boot on
a system even if DEBUG_LL is configured for another system.
Add support for the new Bananapro A20 development board from lemaker.org.
This board features 1G RAM, 2 USB A receptacles, 1 micro USB receptacle for
OTG, 1 micro USB receptacle for power, HDMI, sata, Gbit ethernet, ir receiver,
3.5 mm jack for a/v out, on board microphone, 40 gpio pins and sdio wifi.
