The DWMAC binding never supported having the Ethernet PHY node as a
direct child to the controller, nor did it support the "phy" property
as a way to specify which Ethernet PHY to use. What seemed to work
was simply the implementation ignoring the "phy" property and instead
probing all addresses on the MDIO bus and using the first available
one.
The recent switch from "phy" to "phy-handle" breaks the assumptions
of the implementation, and does not match what the binding requires.
The binding requires that if an MDIO bus is described, it shall be
a sub-node with the "snps,dwmac-mdio" compatible string.
Add a device node for the MDIO bus, and move the Ethernet PHY node
under it. Also fix up the #address-cells and #size-cells properties
where needed.
Fixes: de332de26d19 ("ARM: dts: sunxi: Switch from phy to phy-handle")
Signed-off-by: Chen-Yu Tsai <wens@csie.org>
Signed-off-by: Maxime Ripard <maxime.ripard@bootlin.com>
The phy device tree property has been deprecated in favor of phy-handle,
let's replace it.
Reviewed-by: Andrew Lunn <andrew@lunn.ch>
The I2C and MMC controllers have only one muxing option in the SoC. In such a
case, we can just move the muxing into the DTSI, and remove it from
the DTS.
Acked-by: Chen-Yu Tsai <wens@csie.org>
All our pinctrl nodes were using a node name convention with a unit-address
to differentiate the different muxing options. However, since those nodes
didn't have a reg property, they were generating warnings in DTC.
In order to accomodate for this, convert the old nodes to the syntax we've
been using for the new SoCs, including removing the letter suffix of the
node labels to the bank of those pins to make things more readable.
The gpio pinctrl nodes are redundant and as such useless most of the times.
Since they will also generate warnings in DTC, we can simply remove most of
them.
Using the cd-inverted property is not useful when GPIOs are used as card
detects since the polarity can be specified with the usual
GPIO_ACTIVE_(HIGH|LOW) GPIO flags. It has also caused confusion for
U-Boot developers, so migrate all sunxi boards away from cd-inverted.
As part of our effort to move pinctrl/GPIO interlocking into the
driver where it belongs, this patch drops the definition and usage
of the mmc0_cd_pin_reference_design pinmux setting for the default
mmc0 card detect GPIO pin.
Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
All dts files for the sunxi platform have been switched to the generic
pinconf bindings. As a result, the sunxi specific pinctrl macros are
no longer used.
Remove the #include entry with the following command:
sed --follow-symlinks -i -e '/pinctrl\/sun4i-a10.h/D' \
arch/arm/boot/dts/sun?i*.*
arch/arm/boot/dts/sun9i-a80.dtsi was then edited to remove the extra
empty line.
Now that we can handle the generic pinctrl bindings, convert our DT to it.
The allwinner,pull property set to NO_PULL was really considered our
default (and wasn't even changing the default value in the code).
Remove these properties to make it obvious that we do not set anything in
such a case.
The allwinner,drive property set to 10mA was really considered as our
default. Remove all those properties entirely to make that obvious.
The FSF address triggers a warning on checkpatch, saying that the FSF
license is already present in the Linux source code, and that it has
already changed in the past.
Remove it from our DT, as suggested.
Currently none of the target boards nor the driver supports
IR TX. However this pin is used in a few instances as a GPIO.
Split the pin ctrl descriptions so that only the IR RX is
configured to be used.
Signed-off-by: Marcus Cooper <codekipper@gmail.com>
Add UART aliases and stdout-path property for all the Allwinner boards so that
we won't have to rely on the bootargs' console= value, while working with
legacy bootloaders.
While we're at it, also remove the mentions of earlyprintk in the bootargs,
that will remove our default bootargs entirely, and allow the kernel to boot on
a system even if DEBUG_LL is configured for another system.
In order to lessen the amount of duplication of the DT tree, ease the
new and follow the trend that prefers to use label based references
when overriding DTSI nodes, convert the board to this syntax
The NMI IRQ controller uses the standard flags definition for the IRQ level and
edges.
Use the common header to use defines instead of opaque numbers.
The pinctrl nodes require some extra opaque arguments for the pull up and drive
strength values.
Introduce a new header file and convert the device trees to replace these
opaque numbers by defines.
Replace the various raw GPIO flags by their definition in the common
dt-bindings header.
Prepare the device trees to use the C preprocessor.
During the GPL to GPL/X11 licensing migration, the GPL notice introduced
mentionned the device trees as a library, which is not really accurate. It
began to spread by copy and paste. Fix all these library mentions to reflect
the file that it's actually just a file.
The Mele M3 is yet another Allwinnner based Android top set box from Mele.
It uses a housing similar to the A2000, but without the USM sata storage slot
at the top.
It features an A20 SoC, 1G RAM, 4G eMMC (unique for Allwinner devices),
100Mbit ethernet, HDMI out, 3 USB A receptacles, VGA, and A/V OUT connections.
