As part of our effort to move pinctrl/GPIO interlocking into the
driver where it belongs, this patch drops the definition and usage
of the mmc0_cd_pin_reference_design pinmux setting for the default
mmc0 card detect GPIO pin.
Signed-off-by: Chen-Yu Tsai <wens@csie.org>
Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
All dts files for the sunxi platform have been switched to the generic
pinconf bindings. As a result, the sunxi specific pinctrl macros are
no longer used.
Remove the #include entry with the following command:
sed --follow-symlinks -i -e '/pinctrl\/sun4i-a10.h/D' \
arch/arm/boot/dts/sun?i*.*
arch/arm/boot/dts/sun9i-a80.dtsi was then edited to remove the extra
empty line.
UEXT are Universal EXTension connector from Olimex. They embed i2c, spi
and uart pins along power in one connector and are found on most,
if not all, Olimex boards.
The Olimex A20 SOM EVB have two UEXT connector so enable the nodes found on
those two connectors.
Signed-off-by: Emmanuel Vadot <manu@bidouilliste.com>
Now that we can handle the generic pinctrl bindings, convert our DT to it.
Acked-by: Chen-Yu Tsai <wens@csie.org>
The allwinner,pull property set to NO_PULL was really considered our
default (and wasn't even changing the default value in the code).
Remove these properties to make it obvious that we do not set anything in
such a case.
The allwinner,drive property set to 10mA was really considered as our
default. Remove all those properties entirely to make that obvious.
sun7i-a20-olimex-som-evb.dts doesn't contain cpu-supply needed for
voltage-scaling with cpufreq-dt so define it.
The default voltages are defined in sun7i-a20.dtsi.
Enable the otg/drc usb controller on the Olimex A20 EVB.
Signed-off-by: Marcus Cooper <codekipper@gmail.com>
Reviewed-by: Hans de Goede <hdegoede@redhat.com>
The Olimex A20-SOM-EVB is an evaluation board for the Olimex
A20-SOM system-on-module. The baseboard provides a full-size SD
socket (connected to mmc3) in addition to the micro-SD socket on
the SOM itself (which is connected to mmc0).
Enable the mmc3 controller in the dts.
Signed-off-by: Karsten Merker <merker@debian.org>
A20-SOM system-on-module. It provides a set of android-style
buttons (labeled "VOL+", "VOL-", "MENU", "SEARCH", "HOME", "ESC"
and "ENTER") which are connected to a low-resolution ADC via a
resistor network.
This patch adds appropriate button definitions to the board
dts. The voltages assigned to the keys are specified in the
board schematics published by the manufacturer.
Enable the on-chip audio codec on the Olimex A20-SOM-EVB
Signed-off-by: Marcus Weseloh <mweseloh42@gmail.com>
The A20-SOM-EVB is a reference design of a 2-layer board for the
A20-SOM.
It expands the features of A20-SOM by adding VGA connector, HDMI
connector, audio In/Out, LCD connector, 2 Mpix camera, gigabit
Ethernet, SATA, USB-OTG and 2 USB hosts.
