path: root/arch/arm/boot/dts/sun7i-a20-olimex-som-evb.dts
2017-05-14ARM: sunxi: Drop mmc0_cd_pin_reference_design pinmux settingChen-Yu Tsai
As part of our effort to move pinctrl/GPIO interlocking into the driver where it belongs, this patch drops the definition and usage of the mmc0_cd_pin_reference_design pinmux setting for the default mmc0 card detect GPIO pin. Signed-off-by: Chen-Yu Tsai <wens@csie.org> Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
2017-03-27ARM: dts: sunxi: Remove no longer used pinctrl/sun4i-a10.h headerChen-Yu Tsai
All dts files for the sunxi platform have been switched to the generic pinconf bindings. As a result, the sunxi specific pinctrl macros are no longer used. Remove the #include entry with the following command: sed --follow-symlinks -i -e '/pinctrl\/sun4i-a10.h/D' \ arch/arm/boot/dts/sun?i*.* arch/arm/boot/dts/sun9i-a80.dtsi was then edited to remove the extra empty line. Signed-off-by: Chen-Yu Tsai <wens@csie.org> Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
2017-01-10ARM: dts: sunxi: Enable UEXT related nodes for Olimex A20 SOM EVBEmmanuel Vadot
UEXT are Universal EXTension connector from Olimex. They embed i2c, spi and uart pins along power in one connector and are found on most, if not all, Olimex boards. The Olimex A20 SOM EVB have two UEXT connector so enable the nodes found on those two connectors. Signed-off-by: Emmanuel Vadot <manu@bidouilliste.com> Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
2016-12-26ARM: sunxi: Convert pinctrl nodes to generic bindingsMaxime Ripard
Now that we can handle the generic pinctrl bindings, convert our DT to it. Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com> Acked-by: Chen-Yu Tsai <wens@csie.org> Reviewed-by: Linus Walleij <linus.walleij@linaro.org>
2016-12-26ARM: sunxi: Remove useless allwinner,pull propertyMaxime Ripard
The allwinner,pull property set to NO_PULL was really considered our default (and wasn't even changing the default value in the code). Remove these properties to make it obvious that we do not set anything in such a case. Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com> Acked-by: Chen-Yu Tsai <wens@csie.org> Reviewed-by: Linus Walleij <linus.walleij@linaro.org>
2016-12-26ARM: sunxi: Remove useless allwinner,drive propertyMaxime Ripard
The allwinner,drive property set to 10mA was really considered as our default. Remove all those properties entirely to make that obvious. Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com> Acked-by: Chen-Yu Tsai <wens@csie.org> Reviewed-by: Linus Walleij <linus.walleij@linaro.org>
2016-11-22ARM: dts: sunxi: Add cpu-supply for Olimex A20 EVBEmmanuel Vadot
sun7i-a20-olimex-som-evb.dts doesn't contain cpu-supply needed for voltage-scaling with cpufreq-dt so define it. The default voltages are defined in sun7i-a20.dtsi. Signed-off-by: Emmanuel Vadot <manu@bidouilliste.com> Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
2016-02-09ARM: dts: sun7i: Enable USB DRC on Olimex A20 EVBMarcus Cooper
Enable the otg/drc usb controller on the Olimex A20 EVB. Signed-off-by: Marcus Cooper <codekipper@gmail.com> Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com> Reviewed-by: Hans de Goede <hdegoede@redhat.com>
2015-12-11ARM: dts: sun7i: Olimex A20-SOM-EVB: Enable mmc3 (baseboard SD socket)Karsten Merker
The Olimex A20-SOM-EVB is an evaluation board for the Olimex A20-SOM system-on-module. The baseboard provides a full-size SD socket (connected to mmc3) in addition to the micro-SD socket on the SOM itself (which is connected to mmc0). Enable the mmc3 controller in the dts. Signed-off-by: Karsten Merker <merker@debian.org> Acked-by: Chen-Yu Tsai <wens@csie.org> Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
2015-12-11ARM: dts: sun7i: Olimex A20-SOM-EVB: Add LRADC keysKarsten Merker
The Olimex A20-SOM-EVB is an evaluation board for the Olimex A20-SOM system-on-module. It provides a set of android-style buttons (labeled "VOL+", "VOL-", "MENU", "SEARCH", "HOME", "ESC" and "ENTER") which are connected to a low-resolution ADC via a resistor network. This patch adds appropriate button definitions to the board dts. The voltages assigned to the keys are specified in the board schematics published by the manufacturer. Signed-off-by: Karsten Merker <merker@debian.org> Acked-by: Chen-Yu Tsai <wens@csie.org> Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
2015-11-17ARM: dts: sun4i: Enable audio codec on Olimex A20-SOM-EVBMarcus Weseloh
Enable the on-chip audio codec on the Olimex A20-SOM-EVB Signed-off-by: Marcus Weseloh <mweseloh42@gmail.com> Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
2015-10-01ARM: sun7i: dt: Add new Olimex A20 EVB deviceMarcus Cooper
The A20-SOM-EVB is a reference design of a 2-layer board for the A20-SOM. It expands the features of A20-SOM by adding VGA connector, HDMI connector, audio In/Out, LCD connector, 2 Mpix camera, gigabit Ethernet, SATA, USB-OTG and 2 USB hosts. Signed-off-by: Marcus Cooper <codekipper@gmail.com> Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
