The DWMAC binding never supported having the Ethernet PHY node as a
direct child to the controller, nor did it support the "phy" property
as a way to specify which Ethernet PHY to use. What seemed to work
was simply the implementation ignoring the "phy" property and instead
probing all addresses on the MDIO bus and using the first available
one.
The recent switch from "phy" to "phy-handle" breaks the assumptions
of the implementation, and does not match what the binding requires.
The binding requires that if an MDIO bus is described, it shall be
a sub-node with the "snps,dwmac-mdio" compatible string.
Add a device node for the MDIO bus, and move the Ethernet PHY node
under it. Also fix up the #address-cells and #size-cells properties
where needed.
Fixes: de332de26d19 ("ARM: dts: sunxi: Switch from phy to phy-handle")
Signed-off-by: Chen-Yu Tsai <wens@csie.org>
Signed-off-by: Maxime Ripard <maxime.ripard@bootlin.com>
The phy device tree property has been deprecated in favor of phy-handle,
let's replace it.
Reviewed-by: Andrew Lunn <andrew@lunn.ch>
So far we've enabled pull-up and pull-down resistors on GPIOs using a
pinctrl node. Now that the GPIO binding allows for a flag to declare this,
let's switch to it.
This brings us closer to removing all the GPIO pinctrl nodes, which will in
turn allow us to switch the pinctrl strict mode on.
Acked-by: Chen-Yu Tsai <wens@csie.org>
While the USB PHY Device Tree mandates that the name of the VBUS detect pin
should be usb0_vbus_det-gpios, a significant number of device tree use
usb0_vbus_det-gpio instead.
This was functional because the GPIO framework falls back to the gpio
suffix that is legacy, but we should fix this.
While the USB PHY Device Tree mandates that the name of the ID detect pin
should be usb0_id_det-gpios, a significant number of device tree use
usb0_id_det-gpio instead.
The I2C and MMC controllers have only one muxing option in the SoC. In such a
case, we can just move the muxing into the DTSI, and remove it from
the DTS.
Some GPIO pinctrl nodes cannot be easily removed, because they would also
change the pin configuration, for example to add a pull resistor or change
the current delivered by the pin.
Those nodes still have underscores and unit-addresses in their node names
in our DTs, so adjust their name to remove the warnings. Use that occasion
to also fix some poorly chosen node-names.
All our pinctrl nodes were using a node name convention with a unit-address
to differentiate the different muxing options. However, since those nodes
didn't have a reg property, they were generating warnings in DTC.
In order to accomodate for this, convert the old nodes to the syntax we've
been using for the new SoCs, including removing the letter suffix of the
node labels to the bank of those pins to make things more readable.
The gpio pinctrl nodes are redundant and as such useless most of the times.
Since they will also generate warnings in DTC, we can simply remove most of
them.
Using the cd-inverted property is not useful when GPIOs are used as card
detects since the polarity can be specified with the usual
GPIO_ACTIVE_(HIGH|LOW) GPIO flags. It has also caused confusion for
U-Boot developers, so migrate all sunxi boards away from cd-inverted.
All the A20 devices I own have standard HDMI connectors wired
to the dedicated HDMI pins on the SoC:
- Bananapi M1+
- Cubieboard 2
- Cubietruck
- Lamobo R1 (or Bananapi R1)
Development boards from Olimex also have standard HDMI connectors.
Schematics for them are publicly available. Enable HDMI on them as
well.
- Olimex A20-OLinuXino-LIME
- Olimex A20-OLinuXino-LIME2
- Olimex A20-OLinuXino-MICRO
Enable the display pipeline and HDMI output for them.
Tested-by: Priit Laes <plaes@plaes.org> # Cubietruck, A20-OLinuXino-MICRO
Tested-by: Olliver Schinagl <oliver@schinagl.nl> # A20-OLinuXino-LIME2
Tested-by: Jonathan Liu <net147@gmail.com> # A20-OLinuXino-LIME
Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
As part of our effort to move pinctrl/GPIO interlocking into the
driver where it belongs, this patch drops the definition and usage
of the mmc0_cd_pin_reference_design pinmux setting for the default
mmc0 card detect GPIO pin.
All dts files for the sunxi platform have been switched to the generic
pinconf bindings. As a result, the sunxi specific pinctrl macros are
no longer used.
Remove the #include entry with the following command:
sed --follow-symlinks -i -e '/pinctrl\/sun4i-a10.h/D' \
arch/arm/boot/dts/sun?i*.*
arch/arm/boot/dts/sun9i-a80.dtsi was then edited to remove the extra
empty line.
Now that we can handle the generic pinctrl bindings, convert our DT to it.
The allwinner,pull property set to NO_PULL was really considered our
default (and wasn't even changing the default value in the code).
Remove these properties to make it obvious that we do not set anything in
such a case.
The allwinner,drive property set to 10mA was really considered as our
default. Remove all those properties entirely to make that obvious.
The Olimex A20 OLinuXino Lime features an eeprom that is always on the
board. This patch adds it to the dts.
Signed-off-by: Olliver Schinagl <oliver@schinagl.nl>
Enable the otg/drc usb controller on the A20-OLinuxIno-Lime.
The FSF address triggers a warning on checkpatch, saying that the FSF
license is already present in the Linux source code, and that it has
already changed in the past.
Remove it from our DT, as suggested.
Add UART aliases and stdout-path property for all the Allwinner boards so that
we won't have to rely on the bootargs' console= value, while working with
legacy bootloaders.
While we're at it, also remove the mentions of earlyprintk in the bootargs,
that will remove our default bootargs entirely, and allow the kernel to boot on
a system even if DEBUG_LL is configured for another system.
In order to lessen the amount of duplication of the DT tree, ease the
new and follow the trend that prefers to use label based references
when overriding DTSI nodes, convert the board to this syntax
The NMI IRQ controller uses the standard flags definition for the IRQ level and
edges.
Use the common header to use defines instead of opaque numbers.
The pinctrl nodes require some extra opaque arguments for the pull up and drive
strength values.
Introduce a new header file and convert the device trees to replace these
opaque numbers by defines.
Replace the various raw GPIO flags by their definition in the common
dt-bindings header.
Prepare the device trees to use the C preprocessor.
The current GPL only licensing on the DTSI makes it very impractical for other
software components licensed under another license.
In order to make it easier for them to reuse our device trees, relicense our
device trees under a GPL/X11 dual-license.
Acked-by: FUKAUMI Naoki <naobsd@gmail.com>
This patch adds support for Olimex A20-OLinuXino-LIME board.
Signed-off-by: FUKAUMI Naoki <naobsd@gmail.com>
