path: root/arch/arm/boot/dts/sun7i-a20-orangepi.dts
2017-03-27ARM: dts: sunxi: Remove no longer used pinctrl/sun4i-a10.h headerChen-Yu Tsai
All dts files for the sunxi platform have been switched to the generic pinconf bindings. As a result, the sunxi specific pinctrl macros are no longer used. Remove the #include entry with the following command: sed --follow-symlinks -i -e '/pinctrl\/sun4i-a10.h/D' \ arch/arm/boot/dts/sun?i*.* arch/arm/boot/dts/sun9i-a80.dtsi was then edited to remove the extra empty line. Signed-off-by: Chen-Yu Tsai <wens@csie.org> Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
2016-12-26ARM: sunxi: Convert pinctrl nodes to generic bindingsMaxime Ripard
Now that we can handle the generic pinctrl bindings, convert our DT to it. Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com> Acked-by: Chen-Yu Tsai <wens@csie.org> Reviewed-by: Linus Walleij <linus.walleij@linaro.org>
2016-12-26ARM: sunxi: Remove useless allwinner,pull propertyMaxime Ripard
The allwinner,pull property set to NO_PULL was really considered our default (and wasn't even changing the default value in the code). Remove these properties to make it obvious that we do not set anything in such a case. Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com> Acked-by: Chen-Yu Tsai <wens@csie.org> Reviewed-by: Linus Walleij <linus.walleij@linaro.org>
2016-12-26ARM: sunxi: Remove useless allwinner,drive propertyMaxime Ripard
The allwinner,drive property set to 10mA was really considered as our default. Remove all those properties entirely to make that obvious. Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com> Acked-by: Chen-Yu Tsai <wens@csie.org> Reviewed-by: Linus Walleij <linus.walleij@linaro.org>
2015-09-29ARM: dts: sun7i: Enable USB DRC on the Orange piReinder de Haan
Add usb otg support for Orange pi, based on Orange pi mini. Signed-off-by: Reinder de Haan <patchesrdh@mveas.com> Signed-off-by: Hans de Goede <hdegoede@redhat.com> Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
2015-05-10ARM: sunxi: dt: Remove the FSF addressMaxime Ripard
The FSF address triggers a warning on checkpatch, saying that the FSF license is already present in the Linux source code, and that it has already changed in the past. Remove it from our DT, as suggested. Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
2015-05-02ARM: sunxi: dts: split IR pins for A10 and A20Marcus Cooper
Currently none of the target boards nor the driver supports IR TX. However this pin is used in a few instances as a GPIO. Split the pin ctrl descriptions so that only the IR RX is configured to be used. Signed-off-by: Marcus Cooper <codekipper@gmail.com> Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
2015-04-27ARM: dts: sun7i: Add dts file for the Orangepi SBCHans de Goede
The Orangepi is a development board using the Allwinner A20 SoC, with 1G RAM, microsd slot, HDMI, 1Gbit ethernet, USB wifi, Micro USB (otg), sata, 4 USB A ports, ir receiver and a headphones jack. Also see: http://linux-sunxi.org/Xunlong_Orange_Pi http://www.orangepi.org/ Signed-off-by: Hans de Goede <hdegoede@redhat.com> [maxime: Added /chosen/stdout-path] Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
