As part of our effort to move pinctrl/GPIO interlocking into the
driver where it belongs, this patch drops the definition and usage
of the mmc0_cd_pin_reference_design pinmux setting for the default
mmc0 card detect GPIO pin.
Signed-off-by: Chen-Yu Tsai <wens@csie.org>
Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
Now that we can handle the generic pinctrl bindings, convert our DT to it.
Acked-by: Chen-Yu Tsai <wens@csie.org>
The allwinner,pull property set to NO_PULL was really considered our
default (and wasn't even changing the default value in the code).
Remove these properties to make it obvious that we do not set anything in
such a case.
The allwinner,drive property set to 10mA was really considered as our
default. Remove all those properties entirely to make that obvious.
Add PA gpio pin for controlling power of two external amplifiers (NS4890) which are used on the Wexler TAB7200 tablet
Signed-off-by: Aleksei Mamlin <mamlinav@gmail.com>
Add a backlight for controlling the lcd panel backlight on Wexler TAB7200 tablet
Add a node for the Goodix GT911 touchscreen found on the Wexler TAB7200 tablet
Wexler TAB7200 tablet use channel 0 of the PWM controller for backlight dimming
Enable on-chip audio codec on the Wexler TAB7200 tablet.
Enable the otg/drc usb controller on the Wexler TAB7200 tablet.
The FSF address triggers a warning on checkpatch, saying that the FSF
license is already present in the Linux source code, and that it has
already changed in the past.
Remove it from our DT, as suggested.
Add UART aliases and stdout-path property for all the Allwinner boards so that
we won't have to rely on the bootargs' console= value, while working with
legacy bootloaders.
While we're at it, also remove the mentions of earlyprintk in the bootargs,
that will remove our default bootargs entirely, and allow the kernel to boot on
a system even if DEBUG_LL is configured for another system.
This patch add support for Wexler TAB7200 tablet.
The Wexler TAB7200 is a A20 based tablet with 7 inch display(800x480),
capacitive touchscreen(5 fingers), 1G RAM, 4G NAND, micro SD card slot,
mini HDMI port, 3.5mm audio plug, 1 USB OTG port and 1 USB 2.0 port.
