specifications
commit eaeef1ad9b6ea6df1d1220c254d9563da60cb9d1 upstream.
sun7i-a20.dtsi contains a cpufreq operating point at 0.9 volts. The minimum
CPU voltage for the Allwinner A20 SoC, however, is 1.0 volts. Thus, raise
the voltage for the lowest operating point to 1.0 volts in order to stay
within the SoC specifications. It is an undervolted setting that isn't
stable across all SoCs and boards out there.
Fixes: d96b7161916f ("ARM: dts: sun7i: Add cpu clock reference and
operating points to dtsi")
Signed-off-by: Timo Sigurdsson <public_timo.s@silentcreek.de>
Acked-by: Iain Paton <ipaton0@gmail.com>
Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
commit 8bf1b9b3d90194a174493febc731f7783f2adf1a upstream.
The touchscreen controller in the A13 and later has a different temperature
curve than the one in the original A10, change the compatible for the A13 and
later so that the kernel will use the correct curve.
Reported-by: Tong Zhang <lovewilliam@gmail.com>
Without proper regulator support for individual boards, it is dangerous
to have overclocked/overvoltaged OPPs in the list. Cpufreq will increase
the frequency without the accompanying voltage increase, resulting in
an unstable system.
Remove them for now. We can revisit them with the new version of OPP
bindings, which support boost settings and frequency ranges, among
other things.
Signed-off-by: Chen-Yu Tsai <wens@csie.org>
git://git.linaro.org/people/mike.turquette/linux
Pull clock framework updates from Mike Turquette:
"The clock framework changes contain the usual driver additions,
enhancements and fixes mostly for ARM32, ARM64, MIPS and Power-based
devices.
Additionally the framework core underwent a bit of surgery with two
major changes:
- The boundary between the clock core and clock providers (e.g clock
drivers) is now more well defined with dedicated provider helper
functions. struct clk no longer maps 1:1 with the hardware clock
but is a true per-user cookie which helps us tracker users of
hardware clocks and debug bad behavior.
- The addition of rate constraints for clocks. Rate ranges are now
supported which are analogous to the voltage ranges in the
regulator framework.
Unfortunately these changes to the core created some breakeage. We
think we fixed it all up but for this reason there are lots of last
minute commits trying to undo the damage"
* tag 'clk-for-linus-3.20' of git://git.linaro.org/people/mike.turquette/linux: (113 commits)
clk: Only recalculate the rate if needed
Revert "clk: mxs: Fix invalid 32-bit access to frac registers"
clk: qoriq: Add support for the platform PLL
powerpc/corenet: Enable CLK_QORIQ
clk: Replace explicit clk assignment with __clk_hw_set_clk
clk: Add __clk_hw_set_clk helper function
clk: Don't dereference parent clock if is NULL
MIPS: Alchemy: Remove bogus args from alchemy_clk_fgcs_detr
clkdev: Always allocate a struct clk and call __clk_get() w/ CCF
clk: shmobile: div6: Avoid division by zero in .round_rate()
clk: omap: compile legacy omap3 clocks conditionally
clkdev: Export clk_register_clkdev
clk: Add rate constraints to clocks
clk: remove clk-private.h
pci: xgene: do not use clk-private.h
arm: omap2+ remove dead clock code
clk: Make clk API return per-user struct clk instances
clk: tegra: Define PLLD_DSI and remove dsia(b)_mux
clk: tegra: Add support for the Tegra132 CAR IP block
Pull ARM SoC DT updates from Olof Johansson:
"DT changes continue to be the bulk of our merge window contents.
We continue to have a large set of changes across the board as new
platforms and drivers are added.
Some of the new platforms are:
- Alphascale ASM9260
- Marvell Armada 388
- CSR Atlas7
- TI Davinci DM816x
- Hisilicon HiP01
- ST STiH418
There have also been some sweeping changes, including relicensing of
DTS contents from GPL to GPLv2+/X11 so that the same files can be
reused in other non-GPL projects more easily. There's also been
changes to the DT Makefile to make it a little less conflict-ridden
and churny down the road"
* tag 'dt-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (330 commits)
ARM: dts: Add PPMU node for exynos4412-trats2
ARM: dts: Add PPMU node for exynos3250-monk and exynos3250-rinato
ARM: dts: Add PPMU dt node for exynos4 and exynos4210
ARM: dts: Add PPMU dt node for exynos3250
ARM: dts: add mipi dsi device node for exynos4415
ARM: dts: add fimd device node for exynos4415
ARM: dts: Add syscon phandle to the video-phy node for Exynos4
ARM: dts: Add sound nodes for exynos4412-trats2
ARM: dts: Fix CLK_MOUT_CAMn parent clocks assignment for exynos4412-trats2
ARM: dts: Fix CLK_UART_ISP_SCLK clock assignment in exynos4x12.dtsi
ARM: dts: Add max77693 charger node for exynos4412-trats2
ARM: dts: Switch max77686 regulators to GPIO control for exynos4412-trats2
ARM: dts: Add suspend configuration for max77686 regulators for exynos4412-trats2
ARM: dts: Add Maxim 77693 fuel gauge node for exynos4412-trats2
ARM: dts: am57xx-beagle-x15: Fix USB2 mode
ARM: dts: am57xx-beagle-x15: Add extcon nodes for USB
ARM: dts: dra72-evm: Add extcon nodes for USB
ARM: dts: dra7-evm: Add extcon nodes for USB
ARM: dts: rockchip: move the hdmi ddc-i2c-bus property to the actual boards
ARM: dts: rockchip: enable vops and hdmi output on rk3288-firefly and -evb
Commit f77d55a3b56a ("serial: 8250_dw: get index of serial line from DT
aliases") made the serial driver now use the serial aliases to get the tty
number, pointing out that our aliases have been wrong all along.
Remove them from the DTSI and add custom ones in the relevant boards.
Signed-off-by: VishnuPatekar <vishnupatekar0510@gmail.com>
This patch add missing mdio label for sun[457]i.
Signed-off-by: Aleksei Mamlin <mamlinav@gmail.com>
The core temperature sensor now supports thermal zones. Add a thermal
zone mapping for the cpus with passive cooling (cpufreq throttling).
Acked-by: Eduardo Valentin <edubezval@gmail.com>
Add simplefb nodes for "[de_fe0-]de_be0-lcd0" and "[de_fe0-]de_be0-lcd0-tve0"
display pipelines for when u-boot has set up a pipeline to drive a LCD panel /
VGA output rather then the HDMI output.
The cpu core is clocked from the "cpu" clock. Add a reference to it
in the first cpu node. Also add "cpu0" label to the node.
The operating points were taken from the A20 FEX files in the
sunxi-boards repository. Not all boards have the same settings. The
settings in this patch are the most generic ones.
Now that the resistive touchpanel driver supports thermal sensors,
add the "#thermal-sensor-cells" property as required by the thermal
framework.
The GIC requires some extra opaque arguments to set the IRQ type and flags.
Convert the DTs to using the common defines.
The pinctrl nodes require some extra opaque arguments for the pull up and drive
strength values.
Introduce a new header file and convert the device trees to replace these
opaque numbers by defines.
The DMA engine for the A10/A20 and derivatives require an opaque extra
argument.
Add a dt-bindings header, and convert the device trees to it.
Prepare the device trees to use the C preprocessor.
Add the sample and output clocks for the MMC phase support.
Reviewed-by: Chen-Yu Tsai <wens@csie.org>
Tested-by: Chen-Yu Tsai <wens@csie.org>
Pull clk framework updates from Mike Turquette:
"This is much later than usual due to several last minute bugs that had
to be addressed. As usual the majority of changes are new drivers and
modifications to existing drivers. The core recieved many fixes along
with the groundwork for several large changes coming in the future
which will better parition clock providers from clock consumers"
* tag 'clk-for-linus-3.19' of git://git.linaro.org/people/mike.turquette/linux: (86 commits)
clk: samsung: Fix Exynos 5420 pinctrl setup and clock disable failure due to domain being gated
ARM: OMAP3: clock: fix boot breakage in legacy mode
ARM: OMAP2+: clock: fix DPLL code to use new determine rate APIs
clk: Really fix deadlock with mmap_sem
clk: mmp: fix sparse non static symbol warning
clk: Change clk_ops->determine_rate to return a clk_hw as the best parent
clk: change clk_debugfs_add_file to take a struct clk_hw
clk: Don't expose __clk_get_accuracy
clk: Don't try to use a struct clk* after it could have been freed
clk: Remove unused function __clk_get_prepare_count
clk: samsung: Fix double add of syscore ops after driver rebind
clk: samsung: exynos4: set parent of sclk_hdmiphy to hdmi
clk: samsung: exynos4415: Fix build with PM_SLEEP disabled
clk: samsung: remove unnecessary inclusion of header files from clk.h
clk: samsung: remove unnecessary CONFIG_OF from clk.c
clk: samsung: Spelling s/bwtween/between/
clk: rockchip: Add support for the mmc clock phases using the framework
clk: rockchip: add bindings for the mmc clocks
clk: rockchip: rk3288 export i2s0_clkout for use in DT
clk: rockchip: use clock ID for DMC (memory controller) on rk3288
Review of the u-boot sunxi simplefb patches has led to the decision that
u-boot should not use a specific path to find the nodes as this goes contrary
to how devicetree usually works.
Instead a platform specific compatible + properties should be used for this.
The simplefb bindings have already been updated to reflect this, this patch
brings the sunxi devicetree files in line with the new binding, and the
actual u-boot implementation as it is going upstream.
Avoid the parent pll for the mod-clk for de_be0 getting disabled when non of
the other users are enabled (which can happen when none of i2c, spi and mmc
are in use).
Note for now we point directly to the parent rather then to the de_be0 mod-clk
as that is not modelled in our devicetree yet.
Add a simplefb template node for u-boot to further fill and activate.
With the new factors infrastructure in place, we can unify apb1 and
apb1_mux as a single clock now.
Signed-off-by: Emilio López <emilio@elopez.com.ar>
[wens@csie.org: Change apb1 node label to "apb1"; reword commit title]
Signed-off-by: Roman Byshko <rbyshko@gmail.com>
During the GPL to GPL/X11 licensing migration, the GPL notice introduced
mentionned the device trees as a library, which is not really accurate. It
began to spread by copy and paste. Fix all these library mentions to reflect
the file that it's actually just a file.
The uart3_pins_a multiplexes the uart3 pins to port G, add a pinctrl entry
for mapping them to port H (as used on the Bananapi).
Pull clock tree updates from Mike Turquette:
"The clk tree changes for 3.18 are dominated by clock drivers. Mostly
fixes and enhancements to existing drivers as well as new drivers.
This tag contains a bit more arch code than I usually take due to some
OMAP2+ changes. Additionally it contains the restart notifier
handlers which are merged as a dependency into several trees.
The PXA changes are the only messy part. Due to having a stable tree
I had to revert one patch and follow up with one more fix near the tip
of this tag. Some dead code is introduced but it will soon become
live code after 3.18-rc1 is released as the rest of the PXA family is
converted over to the common clock framework.
Another trend in this tag is that multiple vendors have started to
push the complexity of changing their CPU frequency into the clock
driver, whereas this used to be done in CPUfreq drivers.
Changes to the clk core include a generic gpio-clock type and a
clk_set_phase() function added to the top-level clk.h api. Due to
some confusion on the fbdev mailing list the kernel boot parameters
documentation was updated to further explain the clk_ignore_unused
parameter, which is often required by users of the simplefb driver.
Finally some fixes to the locking around the clock debugfs stuff was
done to prevent deadlocks when interacting with other subsystems."
* tag 'clk-for-linus-3.18' of git://git.linaro.org/people/mike.turquette/linux: (99 commits)
clk: pxa clocks build system fix
Revert "arm: pxa: Transition pxa27x to clk framework"
clk: samsung: register restart handlers for s3c2412 and s3c2443
clk: rockchip: add restart handler
clk: rockchip: rk3288: i2s_frac adds flag to set parent's rate
doc/kernel-parameters.txt: clarify clk_ignore_unused
dts: add devicetree bindings for pxa27x clocks
clk: add pxa27x clock drivers
arm: pxa: add clock pll selection bits
clk: dts: document pxa clock binding
clk: add pxa clocks infrastructure
clk: gpio-gate: Ensure gpiod_ APIs are prototyped
clk: ti: dra7-atl-clock: Mark the device as pm_runtime_irq_safe
clk: ti: LLVMLinux: Move __init outside of type definition
clk: ti: consider the fact that of_clk_get() might return an error
clk: ti: dra7-atl-clock: fix a memory leak
clk: ti: change clock init to use generic of_clk_init
clk: hix5hd2: add I2C clocks
clk: hix5hd2: add watchdog0 clocks
Now that we have a compatible of its own for the mbus clock, switch to it.
Acked-by: Hans de Goede <hdegoede@redhat.com>
The current GPL only licensing on the DTSI makes it very impractical for other
software components licensed under another license.
In order to make it easier for them to reuse our device trees, relicense our
DTSI first under a GPL/X11 dual-license. Hopefully, the DTS will follow soon.
Acked-by: Alexander Bersenev <bay@hackerdom.ru>
Acked-by: Alexandre Belloni <alexandre.belloni@free-electrons.com>
Acked-by: Carlo Caione <carlo@caione.org>
Acked-by: Chen-Yu Tsai <wens@csie.org>
Acked-by: Emilio López <emilio@elopez.com.ar>
Acked-by: Marc Zyngier <marc.zyngier@arm.com>
Acked-by: Oliver Schinagl <oliver@schinagl.nl>
Acked-by: Roman Byshko <rbyshko@gmail.com>
This patch add generic dts node for uart3/4/5, i2c3 and spi2.
Signed-off-by: Wills Wang <wills.wang.open@gmail.com>
The clock-frequency values of the i2c controller nodes match the
defaults of the driver. Remove the properties to use the defaults,
and be consistent with sun8i.
All of our SPI controllers support DMA transfers, so let's add the
properties here so they can be used when it's best to do so.
The A20 SoC has a sun4i-compatible DMA controller. Let's add a node to
represent it on the device tree.
The sun7i block is the same as the one in the sun4i, rename the compatible
to reflect this.
I've already included the matching change to sunxi-cir.c in my pull-req to
Mauro.
The pinctrl device is also an interrupt controller for external
interrupts. Add the missing #interrupt-cells property.
Also remove the unused #address-cells property.
[hdegoede@redhat.com: make the same change for sun4i, sun5i and sun6i]
This patch adds records for two IR controllers on A20
Signed-off-by: Alexander Bersenev <bay@hackerdom.ru>
Signed-off-by: Alexsey Shestacov <wingrime@linux-sunxi.org>
This patch adds pins for two IR controllers on A20
git://git.kernel.org/pub/scm/linux/kernel/git/wsa/linux into next
Pull i2c updates from Wolfram Sang:
"I2C has the following updates for 3.16:
- major cleanups to the rcar and sh_mobile drivers
- removal of nuc900 driver which had a compile error for years
- usual bunch of driver updates, bugfixes and cleanups"
* 'i2c/for-next' of git://git.kernel.org/pub/scm/linux/kernel/git/wsa/linux: (44 commits)
i2c: pca954x: Fix compilation without CONFIG_GPIOLIB
i2c: mux: pca954x: Use the descriptor-based GPIO API
i2c: mpc: insert DR read in i2c_fixup()
i2c: bfin: turn to Resource-managed API in probe function
i2c: Make of_device_id array const
i2c: remove unnecessary OOM messages
i2c: designware-pci: Add Haswell PCI IDs
i2c: designware: Add runtime PM hooks
i2c: designware: Disable device on system suspend
i2c: nuc900: remove driver
i2c: imx: update i2c clock divider for each transaction
i2c: imx: fix the i2c bus hang issue when do repeat restart
i2c: rcar: update copyright and license information
i2c: rcar: janitorial cleanup after refactoring
i2c: rcar: reuse status bits as enable bits
i2c: rcar: remove spinlock
i2c: rcar: refactor status bit handling
i2c: rcar: refactor setting up msg
i2c: rcar: check bus free before first message
i2c: rcar: refactor irq state machine
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc into next
Pull ARM SoC devicetree updates from Olof Johansson:
"As with previous release, this continues to be among the largest
branches we merge, with lots of new contents.
New things for this release are among other things:
- DTSI contents for the new SoCs supported in 3.16 (see SoC pull request)
- Qualcomm APQ8064 and APQ8084 SoCs and eval boards
- Nvidia Jetson TK1 development board (Tegra T124-based)
Two new SoCs that didn't need enough new platform code to stand out
enough for me to notice when writing the SoC tag, but that adds new DT
contents are:
- TI DRA72
- Marvell Berlin 2Q"
* tag 'dt-for-3.16' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (500 commits)
ARM: dts: add secure firmware support for exynos5420-arndale-octa
ARM: dts: add pmu sysreg node to exynos3250
ARM: dts: correct the usb phy node in exynos5800-peach-pi
ARM: dts: correct the usb phy node in exynos5420-peach-pit
ARM: dts: add dts files for exynos5410 and exynos5410-smdk5410
ARM: dts: add dts files for exynos3250 SoC
ARM: dts: add mfc node for exynos5800
ARM: dts: add Vbus regulator for USB 3.0 on exynos5800-peach-pi
ARM: dts: enable fimd for exynos5800-peach-pi
ARM: dts: enable display controller for exynos5800-peach-pi
ARM: dts: enable hdmi for exynos5800-peach-pi
ARM: dts: add dts file for exynos5800-peach-pi board
ARM: dts: add dts file for exynos5800 SoC
ARM: dts: add dts file for exynos5260-xyref5260 board
ARM: dts: add dts files for exynos5260 SoC
ARM: dts: update watchdog node name in exynos5440
ARM: dts: use key code macros on Origen and Arndale boards
ARM: dts: enable RTC and WDT nodes on Origen boards
ARM: dts: qcom: Add APQ8084-MTP board support
ARM: dts: qcom: Add APQ8084 SoC support
Switch the device tree to the new compatibles introduced in the i2c drivers
to have a common pattern accross all Allwinner SoCs.
Signed-off-by: Wolfram Sang <wsa@the-dreams.de>
This adds pin-muxing info for the mmc controller / port combinations which
are known to be used on actual boards.
Add nodes for the 4 mmc controllers found on A20 SoCs to
arch/arm/boot/dts/sun7i-a20.dtsi.
Signed-off-by: David Lanzendörfer <david.lanzendoerfer@o2s.ch>
Add the PWM bindings for the Allwinner A20.
Signed-off-by: Alexandre Belloni <alexandre.belloni@free-electrons.com>
Add the pinctrl descriptions for both PWM channels of the Allwinner A20.
For some reason, the base address of the fifth I2C adapter in the A20 was
incorrect. Change this to the actual base address.
Reported-by: Marcus Cooper <codekipper@gmail.com>
Enable the performance monitoring unit found in the A20 SoCs.
Reviewed-by: Hans de Goede <hdegoede@redhat.com>
