[ Upstream commit 5719ac19fc32d892434939c1756c2f9a8322e6ef ]
"arm,cortex-a15-pmu" is not a valid fallback compatible string for an
Cortex-A7 PMU, so drop it.
Cc: Maxime Ripard <maxime.ripard@bootlin.com>
Cc: Chen-Yu Tsai <wens@csie.org>
Signed-off-by: Rob Herring <robh@kernel.org>
Acked-by: Will Deacon <will.deacon@arm.com>
Signed-off-by: Maxime Ripard <maxime.ripard@bootlin.com>
Add SoC specific compatibles for all sunXi crypto nodes, in addition to
the one already used (allwinner,sun4i-a10-crypto).
Signed-off-by: Antoine Tenart <antoine.tenart@free-electrons.com>
Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
As part of our effort to move pinctrl/GPIO interlocking into the
driver where it belongs, this patch drops the definition and usage
of the mmc0_cd_pin_reference_design pinmux setting for the default
mmc0 card detect GPIO pin.
Signed-off-by: Chen-Yu Tsai <wens@csie.org>
This patch changes the device node position of ps20 and ps21 to fix
ordering by rising physical address.
From
uart7: serial@01c29c00
i2c0: i2c@01c2ac00
i2c1: i2c@01c2b000
i2c2: i2c@01c2b400
i2c3: i2c@01c2b800
i2c4: i2c@01c2c000
gmac: ethernet@01c50000
hstimer@01c60000
gic: interrupt-controller@01c81000
ps20: ps2@01c2a000
ps21: ps2@01c2a400
to
ps20: ps2@01c2a000
ps21: ps2@01c2a400
i2c0: i2c@01c2ac00
i2c1: i2c@01c2b000
i2c2: i2c@01c2b400
i2c3: i2c@01c2b800
i2c4: i2c@01c2c000
hstimer@01c60000
Signed-off-by: Patrick Menschel <menschel.p@posteo.de>
The A20 SoC has an on-board CAN controller. This patch adds
the pinctrl settings for pins PH20 and PH21.
This patch is adapted from the description in
Documentation/devicetree/bindings/net/can/sun4i_can.txt
This patch adds the device node.
The CAN controller is inherited from the A10 SoC and uses the same driver.
All dts files for the sunxi platform have been switched to the generic
pinconf bindings. As a result, the sunxi specific pinctrl macros are
no longer used.
Remove the #include entry with the following command:
sed --follow-symlinks -i -e '/pinctrl\/sun4i-a10.h/D' \
arch/arm/boot/dts/sun?i*.*
arch/arm/boot/dts/sun9i-a80.dtsi was then edited to remove the extra
empty line.
https://git.kernel.org/pub/scm/linux/kernel/git/mripard/linux into next/dt
Pull "Allwinner DT changes for 4.11" from Maxime Ripard:
The usual chunk of DT changes, most notably:
- Support for the H2+ and the V3s
- CPUFreq support for the A33
- SPDIF support for the A31 and H3
- New boards: Beelink X2, Lichee Pi One, Lichee Pi Zero,
Orange Pi Zero
* tag 'sunxi-dt-for-4.11' of https://git.kernel.org/pub/scm/linux/kernel/git/mripard/linux: (42 commits)
ARM: dts: sun8i-h3: Add SPDIF to the Beelink X2
ARM: dts: sun8i-h3: Add the SPDIF block to the H3
ARM: dts: sun8i-h3: Add SPDIF TX pin to the H3
ARM: dts: sun8i-h3: Add dts for the Beelink X2 STB
ARM: sun8i: sina33: Enable display
ARM: sun8i: a23/a33: Add the oscillators accuracy
ARM: sun8i: a23/a33: Enable the real LOSC and use it
ARM: dts: sunxi: add support for Lichee Pi Zero board
ARM: dts: sunxi: add dtsi file for V3s SoC
ARM: dts: sun6i: sina31s: Enable USB OTG controller in peripheral mode
ARM: dts: sun8i: reference-design: use AXP223 DTSI
ARM: dts: sun8i: parrot: use AXP223 DTSI
ARM: dts: sun8i: sina33: use AXP223 DTSI
ARM: dts: sun8i: a33-olinuxino: use AXP223 DTSI
ARM: dts: add DTSI for AXP223
dt-bindings: power: axp20x-usb: add axp223 compatible
ARM: dts: sun7i: Add wifi dt node on Banana Pro
ARM: dts: sun6i: Add SPDIF to the Mele I7
devicetree: bindings: Add vendor prefix for Shenzhen Xunlong Software
ARM: dts: sun8i-h3: orange-pi-pc: Enable audio codec
Since everybody copied my own mistake from the DT binding example,
let's address all the offenders in one swift go.
Most of them got the CPU interface size wrong (4kB, while it should
be 8kB), except for both keystone platforms which got the control
interface wrong (4kB instead of 8kB).
In a few cases where I knew for sure what implementation was used,
I've added the "arm,gic-400" compatible string. I'm 99% sure that
this is what everyone is using, but short of having the TRM for
all the other SoCs, I've left them alone.
Acked-by: Shawn Guo <shawnguo@kernel.org>
Acked-by: Santosh Shilimkar <ssantosh@kernel.org>
Acked-by: Krzysztof Kozlowski <krzk@kernel.org>
Acked-by: Maxime Ripard <maxime.ripard@free-electrons.com>
Acked-by: Antoine Tenart <antoine.tenart@free-electrons.com>
Acked-by: Matthias Brugger <matthias.bgg@gmail.com>
Acked-by: Heiko Stuebner <heiko@sntech.de>
Reviewed-by: Javier Martinez Canillas <javier@osg.samsung.com>
The spi0 controller on the A20 have up to 4 CS (Chip Select) while the
others three only have 1.
Add the num-cs property to each node.
The current driver doesn't read this property but this is useful for
downstream user of DTS (FreeBSD for example).
Signed-off-by: Emmanuel Vadot <manu@bidouilliste.com>
In the past, all the MMC pins had
allwinner,pull = <SUN4I_PINCTRL_NO_PULL>;
which was actually a no-op. We were relying on U-boot to set the bias
pull up for us. These properties were removed as part of the fix up to
actually support no bias on the pins. During the transition some boards
experienced regular MMC time-outs during normal operation, while others
completely failed to initialize the SD card.
Given that MMC starts in open-drain mode and the pull-ups are required,
it's best to enable it for all the pin settings.
Now that we can handle the generic pinctrl bindings, convert our DT to it.
Acked-by: Chen-Yu Tsai <wens@csie.org>
The allwinner,pull property set to NO_PULL was really considered our
default (and wasn't even changing the default value in the code).
Remove these properties to make it obvious that we do not set anything in
such a case.
The allwinner,drive property set to 10mA was really considered as our
default. Remove all those properties entirely to make that obvious.
The pin controllers also use the two oscillators for debouncing. Add them
to the DTs.
Use the new sun7i-a20-mmc compatible for the mmc controllers on sun7i
and newer.
Signed-off-by: Ulf Hansson <ulf.hansson@linaro.org>
Add the new DAI blocks to the device tree.
This commit adds all the mod1 clocks available on A20 to its device
tree. This list was created by looking at the A20 user manual.
Signed-off-by: Emilio López <emilio@elopez.com.ar>
Add NAND Flash controller node definition to the A20 SoC.
Signed-off-by: Boris Brezillon <boris.brezillon@free-electrons.com>
Signed-off-by: Aleksei Mamlin <mamlinav@gmail.com>
No functional change. Re-order sun7i pinctrl nodes alphabetically.
Update the simplefb nodes for hdmi / tv-encoder out to point to
tcon0_ch1 instead of tcon0_ch0 as tcon clock.
While at it fix the clocks lines being longer than 80 chars.
Enable the display and TCON clocks that are needed to drive the display
engine, tcon and TV encoders.
Signed-off-by: Priit Laes <plaes@plaes.org>
Fix pll3x2 and pll7x2 not having a parent clock, specifically this
fixes the kernel turning of pll3 while simplefb is using it when
uboot has configured things to use pll3x2 as lcd ch clk parent.
Now that we've a clock node describing pll3 we must add it to the
simplefb nodes clocks lists to avoid it getting turned off when
simplefb is used.
This fixes the screen going black when using simplefb.
Enable pll3 and pll7 clocks that are needed by display clocks.
Seems like dram_gate 5 was forgotten when DRAM gating driver was added.
Add it.
Cc: stable@vger.kernel.org
Fixes: 0b4bf5a5200b (ARM: dts: sun7i: Add DRAM gates)
Add the SPDIF transceiver controller block to the A20 dtsi.
Signed-off-by: Marcus Cooper <codekipper@gmail.com>
Add the SPDIF clock to the A20 dtsi.
Add the SPDIF TX pin to the A20 dtsi.
The video engine has its own module clock, which also includes a
reset control for it.
The DRAM gates controls direct memory access for some peripherals.
These peripherals include the display pipeline, so add the required
gates to the simplefb nodes as well.
The A20 SoC includes the Allwinner audio codec, capable of both 24-bit
playback and capture. This commit adds a device node for it.
The audio codec functional clock is a child of PLL2 and is used to control
the audio rate, enable it in the DT.
The A20 uses the PLL2 as the audio PLL, which is the parent of all the
other audio clocks in the system (i2s, codec, etc.). Add it to the DTSI.
This patch add support to the keypad clock on sun7i
Signed-off-by: Yassin Jaffer <yassinjaffer@gmail.com>
specifications
sun7i-a20.dtsi contains a cpufreq operating point at 0.9 volts. The minimum
CPU voltage for the Allwinner A20 SoC, however, is 1.0 volts. Thus, raise
the voltage for the lowest operating point to 1.0 volts in order to stay
within the SoC specifications. It is an undervolted setting that isn't
stable across all SoCs and boards out there.
Cc: <stable@vger.kernel.org> # v4.0+
Fixes: d96b7161916f ("ARM: dts: sun7i: Add cpu clock reference and operating points to dtsi")
Signed-off-by: Timo Sigurdsson <public_timo.s@silentcreek.de>
Acked-by: Iain Paton <ipaton0@gmail.com>
Pull ARM DT updates from Olof Johansson:
"Ladies and gentlemen, we proudly announce to you the latest branch of
ARM device tree contents for the mainline kernel. Come and see, come
and see!
No less than twentythree thousand lines of additions! Just imagine the
joy you will have of using your mainline kernel on newly supported
hardware such as Rockchip Chromebooks, Freescale i.MX6UL boards or
UniPhier hardware!
For those of you feeling less adventurous, added hardware support on
platforms such as TI DM814x and Gumstix Overo platforms might be more
of your liking.
We've got something for everyone here!
Ahem. Cough. So, anyway...
This is the usual large batch of DT updates. Lots and lots of smaller
changes, some of the larger ones to point out are:
- Rockchip veyron (Chromebook) support, as well as several other new boards
- DRM support on Atmel AT91SAM9N12EK
- USB additions on some Allwinner platforms
- Mediatek MT6580 support
- Freescale i.MX6UL support
- cleanups for Renesas shmobile platforms
- lots of added devices on LPC18xx
- lots of added devices and boards on UniPhier
There's also some dependent code added here, in particular some
branches that are primarily merged through the clock tree"
* tag 'armsoc-dt' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (389 commits)
ARM: tegra: Add gpio-ranges property
ARM: tegra: Fix AHB base address on Tegra20, Tegra30 and Tegra114
ARM: tegra: Add Tegra124 PMU support
ARM: tegra: jetson-tk1: Add GK20A GPU DT node
ARM: tegra: venice2: Add GK20A GPU DT node
ARM: tegra: Add IOMMU node to GK20A
ARM: tegra: Add CPU regulator to the Jetson TK1 device tree
ARM: tegra: Add entries for cpufreq on Tegra124
ARM: tegra: Enable the DFLL on the Jetson TK1
ARM: tegra: Add the DFLL to Tegra124 device tree
ARM: dts: zynq: Add devicetree entry for Xilinx Zynq reset controller.
ARM: dts: UniPhier: fix PPI interrupt CPU mask of timer nodes
ARM: dts: rockchip: correct regulator power states for suspend
ARM: dts: rockchip: correct regulator PM properties
ARM: dts: vexpress: Use assigned-clock-parents for sp810
pinctrl: tegra: Only set the gpio range if needed
arm: boot: dts: am4372: add ARM timers and SCU nodes
ARM: dts: AM4372: Add the am4372-rtc compatible string
ARM: shmobile: r8a7794 dtsi: Add CPG/MSTP Clock Domain
ARM: shmobile: r8a7793 dtsi: Add CPG/MSTP Clock Domain
Pull crypto updates from Herbert Xu:
"Here is the crypto update for 4.3:
API:
- the AEAD interface transition is now complete.
- add top-level skcipher interface.
Drivers:
- x86-64 acceleration for chacha20/poly1305.
- add sunxi-ss Allwinner Security System crypto accelerator.
- add RSA algorithm to qat driver.
- add SRIOV support to qat driver.
- add LS1021A support to caam.
- add i.MX6 support to caam"
* git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6: (163 commits)
crypto: algif_aead - fix for multiple operations on AF_ALG sockets
crypto: qat - enable legacy VFs
MPI: Fix mpi_read_buffer
crypto: qat - silence a static checker warning
crypto: vmx - Fixing opcode issue
crypto: caam - Use the preferred style for memory allocations
crypto: caam - Propagate the real error code in caam_probe
crypto: caam - Fix the error handling in caam_probe
crypto: caam - fix writing to JQCR_MS when using service interface
crypto: hash - Add AHASH_REQUEST_ON_STACK
crypto: testmgr - Use new skcipher interface
crypto: skcipher - Add top-level skcipher interface
crypto: cmac - allow usage in FIPS mode
crypto: sahara - Use dmam_alloc_coherent
crypto: caam - Add support for LS1021A
crypto: qat - Don't move data inside output buffer
crypto: vmx - Fixing GHASH Key issue on little endian
crypto: vmx - Fixing AES-CTR counter bug
crypto: null - Add missing Kconfig tristate for NULL2
crypto: nx - Add forward declaration for struct crypto_aead
The A20 gates have a non continuous set of clock IDs that are valid. Add
the clock-indices property to the DT to express this.
Signed-off-by: Michael Turquette <mturquette@baylibre.com>
The current DTs were setting the cell size to 2, but used the default xlate
function that was assuming an interrupt cell size of 1, leading to the
second part of the cell (the flags) being ignored, while we were having an
inconsistent binding between the interrupts and gpio (that could also be
used as interrupts).
That "binding" doesn't work either with newer SoCs that have multiple irq
banks.
Now that we fixed the pinctrl driver to handle this like it should always
have been handled, convert the DT users, and while we're at it, remove the
size-cells property of PIO that is completely useless.
Reviewed-by: Hans de Goede <hdegoede@redhat.com>
The Security System is a hardware cryptographic accelerator that support
AES/MD5/SHA1/DES/3DES/PRNG algorithms.
It could be found on many Allwinner SoC.
This patch enable the Security System on the Allwinner A20 SoC Device-tree.
Signed-off-by: LABBE Corentin <clabbe.montjoie@gmail.com>
Add a node for the otg/drc usb controller to sun7i-a20.dtsi
The A20 has a few SRAM that can be mapped either to a device or to the CPU,
with the mapping being controlled by a SRAM controller.
Add the SRAM controller, the SRAM that it drives and the section that can
be used by the various devices.
Acked-by: Hans de Goede <hdegoede@redhat.com>
Tested-by: Hans de Goede <hdegoede@redhat.com>
This patch reverts commit ccb4ada2f193 ("ARM: dts: sun7i: Add A20 SRAM and
SRAM controller"), commit e6f51e4bd2a5 ("ARM: dts: sun5i: Add A13 and A10s
SRAM and SRAM controller") and commit 6d92b80f356f ("ARM: dts: sun4i: Add
A10 SRAM and SRAM controller").
The bindings have been changed in the SRAM driver, and we need to
change the DT accordingly.
Some boards (e.g. the BananaPro) use alternative pins for uart4, add a pinmux
entry for these.
Signed-off-by: Michael Ring <mail@michael-ring.org>
The pinctrl groups for SPI until now were also adding the chip selects in
the SPI pinctrl group.
This was causing a few issues, since a board was forced to use a random
number of chipselects, even though it might use one of these chip selects
for another pin.
The number of chipselects defined was also not the same from one group to
another because of different needs at the time these groups have been
introduced, resulting in no clear view from the board DTS on what exactly
is being muxed, which even might change in the future.
Solve this by creating different pinctrl groups for the chipselects and the
standard SPI pins (CLK, MOSI and MISO) so that we fix both issues.
A few lines (probably copy pasted) have an indentation mixing tabs and
spaces that triggers a checkpatch warning.
Fix those, and while we're at it, fix the space-indented sections.
A few lines in our DTSIs are over the 80 characters limit, making
checkpatch complain about that.
If possible (and relevant), wrap these lines to 80 characters.
The FSF address triggers a warning on checkpatch, saying that the FSF
license is already present in the Linux source code, and that it has
already changed in the past.
Remove it from our DT, as suggested.
Currently none of the target boards nor the driver supports
IR TX. However this pin is used in a few instances as a GPIO.
Split the pin ctrl descriptions so that only the IR RX is
configured to be used.
