Now that we can handle the generic pinctrl bindings, convert our DT to it.
Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
Acked-by: Chen-Yu Tsai <wens@csie.org>
The allwinner,pull property set to NO_PULL was really considered our
default (and wasn't even changing the default value in the code).
Remove these properties to make it obvious that we do not set anything in
such a case.
The allwinner,drive property set to 10mA was really considered as our
default. Remove all those properties entirely to make that obvious.
On some Q8 and other tablets ldo_io1 is used as vcc-touchscreen,
config at as such in sun8i-reference-design-tablet.dtsi.
Note that it will only be enabled when it us actually referenced by
a foo-supply property in the touchscreen node, so for tablets which
do not use ldo_io1 as vcc-touchscreen, it will be disabled.
Add a dt node describing the mma7660 accelerometer on the
polaroid-mid2407pxe03 tablet.
Add a node enabling the gsl1680 touchscreen controller found on
sun8i-a23-polaroid-mid2407pxe03 tablets.
The polaroid-mid2407 tablet has an esp8089 wifi chip,
add a dt node describing it.
The Polaroid MID2407PXE03 is an a23 based 7" tablet based on a M86_MB V2.0
PCB, featuring a 800x480 LCD, 512MB RAM, 4G NAND, esp8089 wifi, gsl1680
touchschreen, micro-sd slot, 3.5mm headphone jack and a micro-usb otg
connector which doubles as charging port.
