Add a dt node describing the mma7660 accelerometer on the
polaroid-mid2407pxe03 tablet.
Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
Add a node enabling the gsl1680 touchscreen controller found on
sun8i-a23-polaroid-mid2407pxe03 tablets.
Acked-by: Chen-Yu Tsai <wens@csie.org>
The polaroid-mid2407 tablet has an esp8089 wifi chip,
add a dt node describing it.
The Polaroid MID2407PXE03 is an a23 based 7" tablet based on a M86_MB V2.0
PCB, featuring a 800x480 LCD, 512MB RAM, 4G NAND, esp8089 wifi, gsl1680
touchschreen, micro-sd slot, 3.5mm headphone jack and a micro-usb otg
connector which doubles as charging port.
