path: root/arch/arm/boot/dts/sun8i-a23-polaroid-mid2809pxe04.dts
2016-12-26ARM: sunxi: Convert pinctrl nodes to generic bindingsMaxime Ripard
Now that we can handle the generic pinctrl bindings, convert our DT to it. Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com> Acked-by: Chen-Yu Tsai <wens@csie.org> Reviewed-by: Linus Walleij <linus.walleij@linaro.org>
2016-12-26ARM: sunxi: Remove useless allwinner,pull propertyMaxime Ripard
The allwinner,pull property set to NO_PULL was really considered our default (and wasn't even changing the default value in the code). Remove these properties to make it obvious that we do not set anything in such a case. Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com> Acked-by: Chen-Yu Tsai <wens@csie.org> Reviewed-by: Linus Walleij <linus.walleij@linaro.org>
2016-12-26ARM: sunxi: Remove useless allwinner,drive propertyMaxime Ripard
The allwinner,drive property set to 10mA was really considered as our default. Remove all those properties entirely to make that obvious. Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com> Acked-by: Chen-Yu Tsai <wens@csie.org> Reviewed-by: Linus Walleij <linus.walleij@linaro.org>
2016-09-21ARM: dts: sun8i: Add touchscreen node for sun8i-a23-polaroid-mid2809pxe04Hans de Goede
Add a node enabling the gsl3670 touchscreen controller found on sun8i-a23-polaroid-mid2809pxe04 tablets. Signed-off-by: Hans de Goede <hdegoede@redhat.com> Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com> Acked-by: Chen-Yu Tsai <wens@csie.org>
2016-08-26ARM: dts: sun8i: Add dt node for esp8089 wifi chip on polaroid-mid2809Hans de Goede
The polaroid-mid2809 tablet has an esp8089 wifi chip, add a dt node describing it. Signed-off-by: Hans de Goede <hdegoede@redhat.com> Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
2016-07-18ARM: dts: sun8i: Use sun8i-reference-design-tablet for polaroid mid2809pxe04Hans de Goede
This results in quite a nice cleanup for this dts file. Signed-off-by: Hans de Goede <hdegoede@redhat.com> Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
2016-07-04ARM: dts: sun8i-a23-polaroid-mid2809pxe04: Disable ehci0Hans de Goede
The Polaroid mid2809pxe04 tablet uses an sdio esp8089 wifi chip, so ehci0 is not used and should be disabled. Signed-off-by: Hans de Goede <hdegoede@redhat.com> Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
2016-07-04ARM: dts: sun8i-a23-polaroid-mid2809pxe04: Add full otg supportHans de Goede
Now that we've all the necessary bits in place we can enable full otg support on these tablets. Signed-off-by: Hans de Goede <hdegoede@redhat.com> Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
2016-03-27ARM: dts: sun8i: Add dts file for the Polaroid MID2809PXE4 tabletHans de Goede
The Polaroid MID2809PXE4 is a 9" tablet which is clearly marked Polaroid MID2809PXE4 on the back. It features a 9" 16:9 800x480 LCD, A23 Soc, 1GB RAM, 8GB NAND, gsl3670 touchscreen and esp8089 wifi. Signed-off-by: Hans de Goede <hdegoede@redhat.com> Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
