The h8homlet board has the A83T's standard USB 1.1/2.0 host pair routed
to a USB host port on the board. The other USB host port is routed to
USB OTG controller.
Signed-off-by: Chen-Yu Tsai <wens@csie.org>
The AXP813/AXP818 PMICs used with the A83T/H8 SoCs are actually 2 dies
in one package sharing the serial bus (I2C/RSB) pins. One die is the
actual PMIC. The other is an AC100 codec / RTC combo chip.
This patch adds the device nodes for the AC100 chip to the h8homlet-v2
device tree.
Acked-by: Maxime Ripard <maxime.ripard@free-electrons.com>
This patch enables the RSB controller and adds a device node for the
PMIC die to the h8homlet-v2 device tree. Since the AXP813 and AXP818
are virtually identical, this patch uses the compatible string for
the former as a fallback.
The H8 homlet has a micro-SD card slot connected to mmc0,
and onboard eMMC from FORESEE, connected to mmc2.
The pinmux setting nodes all have an address element in their node
names, however the pinctrl node does not have #address-cells.
Rename the existing pinmux setting nodes and labels in sun8i-a83t.dtsi,
dropping identifiers for functions that only have one possible setting,
and using the pingroup name if the function is identically available on
different pingroups.
Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
H8Homlet Proto v2.0 Board is A83T Dev Board by Allwinner.
It has UART, ethernet, USB, HDMI, etc ports on it.
A83T patches are tested on this board.
For FEL mode it needs USB A-A(Male) cable. I used uart0 which
is multiplexed to microsd pins PF2 and PF4.
Enabled UART0 Header(PB9, PB10 pins).
Signed-off-by: Vishnu Patekar <vishnupatekar0510@gmail.com>
