Now that we can handle the generic pinctrl bindings, convert our DT to it.
Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
Acked-by: Chen-Yu Tsai <wens@csie.org>
The allwinner,drive property set to 10mA was really considered as our
default. Remove all those properties entirely to make that obvious.
Most of the sun8i q8 boards have an SDIO wifi controller, on the
variants which use an USB wifi controller, this will result in a
couple of error msg-s in dmesg when proving the sdio bus and
an used mmc controller.
The best way to deal with wifi on this boards really is to simply
let the kernel auto-detect usb or sdio wifi controllers, so we
will just have to live with the few errors in dmesg.
This has been tested on a23 based q8 tablets with ESP8089, RTL8703AS and
RTL8189FTV wifi controllers.
Copy sun8i-q8-common.dtsi to sun8i-reference-design-tablet.dtsi. This
is part of renaming all the sun?i-q8-common.dtsi files to
sun?i-reference-design-tablet.dtsi since most of the hw-config in there
is shared by all sunxi tablets.
Note that in this case we keep sun5i-q8-common.dtsi as it is shared
between a23 / a33 q8 tablets. Also we leave the usb-wifi config in
there (rather then in sun8i-reference-design-tablet.dtsi) as most
sun8i tablets use sdio wifi rather then usb wifi.
Rename sunxi-q8-common.dtsi to sunxi-reference-design-tablet.dtsi. This
Some of the sun8i q8 boards have an usb wifi controller, on other
variants this will result in an used usb root-hub, but the best
way to deal with wifi on this boards is to simply let the kernel
auto-detect usb or sdio wifi controllers.
This has been tested on an a23 based q8 tablet with a RTL8188ETV wifi
controller.
Now that we've all the necessary bits in place we can enable
full otg support on these tablets.
dc1sw is an on/off only regulator and as such it cannot have constraints.
This is a limitation of the kernel regulator implementation which resolves
supplies on the first regulator_get(), which is done after applying
constraints, and applying the constrains will fail because it calls
_regulator_get_voltage() and _regulator_do_set_voltage() both of which
will fail on a switch regulator when there is no supply (yet).
This causes registering of all axp22x regulators to fail with the
following errors:
[ 1.395249] vcc-lcd: failed to get the current voltage(-22)
[ 1.405131] axp20x-regulator axp20x-regulator: Failed to register dc1sw
[ 1.412436] axp20x-regulator: probe of axp20x-regulator failed with error -22
This commit removes the constrains on dc1sw / vcc-lcd fixing this problem
note that dcdc1 itself is contrained to the exact same values, so this
does not change anything.
A23/A33 Q8 tablets have an X-Powers AXP223 PMIC connected via RSB. Its
regulators provide power to various parts of the SoC and the board.
Also add lcd regulator supply for simplefb and update the existing
vmmc-supply for mmc0.
Signed-off-by: Chen-Yu Tsai <wens@csie.org>
The Reduced Serial Bus controller is used to talk to the onboard PMIC.
The LCD backlight on the A23/A33 Q8 format tablets is enabled
with a GPIO controlled regulator, and brightness controlled with
the SoC's PWM controller.
The backlight is powered from the AXP223 PMIC's DC1SW output,
which is not supported yet. A proper bootloader is required
to enable it.
The brightness levels are arbitrary. The FEX files do not have
such information. As such, actual brightness levels may differ
from device to device.
Cheap allwinner based devices in the q8 enclosure come in many variants,
all sharing the case and a number of other basic features.
They differ in the display, touchscreen, accelerometer and wifi chips
used.
This commit adds 2 dtsi files defining the shared features of all the
q8 tablets. sunxi-q8-common.dtsi defines features shared amongst all
q8 tablets, sun8i-q8-common.dtsi defines features shared amongst all
a23 / a33 based q8 tablets, but not with a13 q8 based tablets.
a13 based tablets use a different card-detect pin for the mmc, and
use uart1 instead of the r_uart for the serial console.
