2016-07-11 | ARM: tegra: Remove commas from unit addresses on Tegra124 | Marcel Ziswiler | |
Remove commas from unit addresses as suggested by Rob Herring upon me posting initial Apalis TK1 support: http://article.gmane.org/gmane.linux.ports.tegra/26608 Please keep the remaining 0, notation on the GPU node in place as a former mainline U-Boot version was looking for that particular notation in order to perform required fix-ups on it. Signed-off-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> Acked-by: Stephen Warren <swarren@nvidia.com> Tested-by: Alexandre Courbot <acourbot@nvidia.com> Signed-off-by: Thierry Reding <treding@nvidia.com> | |||
2015-03-30 | ARM: tegra: Add EMC timings to Jetson TK1 device tree | Mikko Perttunen | |
This adds a new file, tegra124-jetson-tk1-emc.dtsi that contains valid timings for the EMC memory clock. The file is included to the main Jetson TK1 device tree. The data is generated from the V5.0.17 version of the DVFS tables. Signed-off-by: Mikko Perttunen <mperttunen@nvidia.com> Signed-off-by: Tomeu Vizoso <tomeu.vizoso@collabora.com> Signed-off-by: Thierry Reding <treding@nvidia.com> |
