path: root/arch/arm/boot/dts/tegra124-nyan-big.dts
Many source files in the tree are missing licensing information, which makes it harder for compliance tools to determine the correct license. By default all files without license information are under the default license of the kernel, which is GPL version 2. Update the files which contain no license information with the 'GPL-2.0' SPDX license identifier. The SPDX identifier is a legally binding shorthand, which can be used instead of the full boiler plate text. This patch is based on work done by Thomas Gleixner and Kate Stewart and Philippe Ombredanne. How this work was done: Patches were generated and checked against linux-4.14-rc6 for a subset of the use cases: - file had no licensing information it it. - file was a */uapi/* one with no licensing information in it, - file was a */uapi/* one with existing licensing information, Further patches will be generated in subsequent months to fix up cases where non-standard license headers were used, and references to license had to be inferred by heuristics based on keywords. The analysis to determine which SPDX License Identifier to be applied to a file was done in a spreadsheet of side by side results from of the output of two independent scanners (ScanCode & Windriver) producing SPDX tag:value files created by Philippe Ombredanne. Philippe prepared the base worksheet, and did an initial spot review of a few 1000 files. The 4.13 kernel was the starting point of the analysis with 60,537 files assessed. Kate Stewart did a file by file comparison of the scanner results in the spreadsheet to determine which SPDX license identifier(s) to be applied to the file. She confirmed any determination that was not immediately clear with lawyers working with the Linux Foundation. Criteria used to select files for SPDX license identifier tagging was: - Files considered eligible had to be source code files. - Make and config files were included as candidates if they contained >5 lines of source - File already had some variant of a license header in it (even if <5 lines). All documentation files were explicitly excluded. The following heuristics were used to determine which SPDX license identifiers to apply. - when both scanners couldn't find any license traces, file was considered to have no license information in it, and the top level COPYING file license applied. For non */uapi/* files that summary was: SPDX license identifier # files ---------------------------------------------------|------- GPL-2.0 11139 and resulted in the first patch in this series. If that file was a */uapi/* path one, it was "GPL-2.0 WITH Linux-syscall-note" otherwise it was "GPL-2.0". Results of that was: SPDX license identifier # files ---------------------------------------------------|------- GPL-2.0 WITH Linux-syscall-note 930 and resulted in the second patch in this series. - if a file had some form of licensing information in it, and was one of the */uapi/* ones, it was denoted with the Linux-syscall-note if any GPL family license was found in the file or had no licensing in it (per prior point). Results summary: SPDX license identifier # files ---------------------------------------------------|------ GPL-2.0 WITH Linux-syscall-note 270 GPL-2.0+ WITH Linux-syscall-note 169 ((GPL-2.0 WITH Linux-syscall-note) OR BSD-2-Clause) 21 ((GPL-2.0 WITH Linux-syscall-note) OR BSD-3-Clause) 17 LGPL-2.1+ WITH Linux-syscall-note 15 GPL-1.0+ WITH Linux-syscall-note 14 ((GPL-2.0+ WITH Linux-syscall-note) OR BSD-3-Clause) 5 LGPL-2.0+ WITH Linux-syscall-note 4 LGPL-2.1 WITH Linux-syscall-note 3 ((GPL-2.0 WITH Linux-syscall-note) OR MIT) 3 ((GPL-2.0 WITH Linux-syscall-note) AND MIT) 1 and that resulted in the third patch in this series. - when the two scanners agreed on the detected license(s), that became the concluded license(s). - when there was disagreement between the two scanners (one detected a license but the other didn't, or they both detected different licenses) a manual inspection of the file occurred. - In most cases a manual inspection of the information in the file resulted in a clear resolution of the license that should apply (and which scanner probably needed to revisit its heuristics). - When it was not immediately clear, the license identifier was confirmed with lawyers working with the Linux Foundation. - If there was any question as to the appropriate license identifier, the file was flagged for further research and to be revisited later in time. In total, over 70 hours of logged manual review was done on the spreadsheet to determine the SPDX license identifiers to apply to the source files by Kate, Philippe, Thomas and, in some cases, confirmation by lawyers working with the Linux Foundation. Kate also obtained a third independent scan of the 4.13 code base from FOSSology, and compared selected files where the other two scanners disagreed against that SPDX file, to see if there was new insights. The Windriver scanner is based on an older version of FOSSology in part, so they are related. Thomas did random spot checks in about 500 files from the spreadsheets for the uapi headers and agreed with SPDX license identifier in the files he inspected. For the non-uapi files Thomas did random spot checks in about 15000 files. In initial set of patches against 4.14-rc6, 3 files were found to have copy/paste license identifier errors, and have been fixed to reflect the correct identifier. Additionally Philippe spent 10 hours this week doing a detailed manual inspection and review of the 12,461 patched files from the initial patch version early this week with: - a full scancode scan run, collecting the matched texts, detected license ids and scores - reviewing anything where there was a license detected (about 500+ files) to ensure that the applied SPDX license was correct - reviewing anything where there was no detection but the patch license was not GPL-2.0 WITH Linux-syscall-note to ensure that the applied SPDX license was correct This produced a worksheet with 20 files needing minor correction. This worksheet was then exported into 3 different .csv files for the different types of files to be modified. These .csv files were then reviewed by Greg. Thomas wrote a script to parse the csv files and add the proper SPDX tag to the file, in the format that the file expected. This script was further refined by Greg based on the output to detect more types of files automatically and to distinguish between header and source .c files (which need different comment types.) Finally Greg ran the script using the .csv files to generate the patches. Reviewed-by: Kate Stewart <kstewart@linuxfoundation.org> Reviewed-by: Philippe Ombredanne <pombredanne@nexb.com> Reviewed-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-01-25ARM: tegra: nyan-big: Proper pinmux for TPM I2CPaul Kocialkowski
This corrects the pinmux for accessing the TPM over the I2C line. Thus, it allows correctly probing the module, that previously failed with I2C errors. Signed-off-by: Paul Kocialkowski <contact@paulk.fr> Signed-off-by: Thierry Reding <treding@nvidia.com>
2017-01-25ARM: tegra: nyan-big: Include compatible revisions for proper detectionPaul Kocialkowski
Depthcharge (the payload used with cros devices) will attempt to detect boards using their revision. This includes all the known revisions for the nyan-big board so that the dtb can be selected preferably. Defining compatibly revisions allows depthcharge to select the kernel via the revision it detects instead of using the default kernel. This allows having a FIT image with multiple kernels for multiple devices. Signed-off-by: Paul Kocialkowski <contact@paulk.fr> Signed-off-by: Thierry Reding <treding@nvidia.com>
2016-07-11ARM: tegra: Remove commas from unit addresses on Tegra124Marcel Ziswiler
Remove commas from unit addresses as suggested by Rob Herring upon me posting initial Apalis TK1 support: http://article.gmane.org/gmane.linux.ports.tegra/26608 Please keep the remaining 0, notation on the GPU node in place as a former mainline U-Boot version was looking for that particular notation in order to perform required fix-ups on it. Signed-off-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> Acked-by: Stephen Warren <swarren@nvidia.com> Tested-by: Alexandre Courbot <acourbot@nvidia.com> Signed-off-by: Thierry Reding <treding@nvidia.com>
2015-03-30ARM: tegra: Add EMC timings to Nyan Big device treeTomeu Vizoso
This adds a new file, tegra124-nyan-big-emc.dtsi that contains valid timings for the EMC memory clock. The file is included to the main device tree file for the Nyan Big. The frequency 528MHz is missing because we don't currently have a timing configuration that works. Additionally, only the timings for the ram-code 1 is present as that's what could be tested currently, though downstream has timings for more ram-codes. Signed-off-by: Tomeu Vizoso <tomeu.vizoso@collabora.com> Signed-off-by: Thierry Reding <treding@nvidia.com>
2015-03-24ARM: tegra: Use generated pinmux data for Nyan BigTomeu Vizoso
Google has submitted a board config for the pinmux programming of the Nyan Big board. Use the whole of it as it's generated to make it easier to update as the configuration gets fixed in the future. Signed-off-by: Tomeu Vizoso <tomeu.vizoso@collabora.com> Acked-by: Stephen Warren <swarren@nvidia.com> Reviewed-by: Alexandre Courbot <acourbot@nvidia.com> Signed-off-by: Thierry Reding <treding@nvidia.com>
2015-03-24ARM: tegra: Move generic parts out of the nyan-big DTTomeu Vizoso
In preparation for adding the DT for the nyan-blaze board. Signed-off-by: Tomeu Vizoso <tomeu.vizoso@collabora.com> Acked-by: Stephen Warren <swarren@nvidia.com> Reviewed-by: Alexandre Courbot <acourbot@nvidia.com> Signed-off-by: Thierry Reding <treding@nvidia.com>
2015-03-24ARM: tegra: Change model of sound card in Nyan BigTomeu Vizoso
Change it from "Acer Chromebook 13" to GoogleNyanBig so it's unique and identifiable. With this change the card id exposed to userspace becomes GoogleNyanBig instead of the current A13. Signed-off-by: Tomeu Vizoso <tomeu.vizoso@collabora.com> Acked-by: Stephen Warren <swarren@nvidia.com> Reviewed-by: Alexandre Courbot <acourbot@nvidia.com> Signed-off-by: Thierry Reding <treding@nvidia.com>
2015-01-06ARM: tegra: Enable the mic-detect gpio on Acer Chromebook 13Dylan Reid
Enables the gpio-base mic detection on the Acer Chromebook 13. This gpio is set by the jack-detection chip when it notices either of the TRRS type headsets with a microphone. Signed-off-by: Dylan Reid <dgreid@chromium.org> Acked-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Thierry Reding <treding@nvidia.com>
2014-11-13ARM: dts: tegra: move serial aliases to per-boardOlof Johansson
There are general changes pending to make the /aliases/serial* entries number the serial ports on the system. On Tegra, so far the ports have been just numbered dynamically as they are configured so that makes them change. To avoid this, add specific aliases per board to keep the old numbers. This allows us to change the numbering by default on future SoCs while keeping the numbering on existing boards. Signed-off-by: Olof Johansson <olof@lixom.net> Signed-off-by: Thierry Reding <treding@nvidia.com>
2014-09-05ARM: tegra: add Acer Chromebook 13 device treeDylan Reid
The Acer Chromebook 13, codenamed Big, contains an NVIDIA tegra124 processor and is similar to the Venice2 reference platform. The keyboard, USB 2, audio, sdcard and emmc have been tested and work on the 1366x768 models. The Full HD models haven't been tested yet. WiFi does not yet work, it needs at least some PMIC changes to enable the 32k clock. The elan trackpad is not yet functional but hopefully will be soon as there are patches under review. There is also an issue on reboot because the TPM isn't reset. It will cause the stock firmware to enter recovery mode. This can be worked around by an EC-reset, press the refresh and power keys at the same time. Signed-off-by: Dylan Reid <dgreid@chromium.org> Signed-off-by: Stephen Warren <swarren@nvidia.com>
