This seems to have been copied and pasted since the beginning of time,
though only until Tegra124, likely because that DT was written from
scratch or it was fixed along the way.
Signed-off-by: Thierry Reding <treding@nvidia.com>
For Tegra boards, the device-tree alias serial0 is used for the console
and so add the stdout-path information so that the console no longer
needs to be passed via the kernel boot parameters.
This has been tested on boards, tegra20-trimslice, tegra30-beaver,
tegra114-dalmore and tegra124-jetson-tk1.
Signed-off-by: Jon Hunter <jonathanh@nvidia.com>
Acked-by: Stefan Agner <stefan@agner.ch>
There are general changes pending to make the /aliases/serial* entries
number the serial ports on the system. On Tegra, so far the ports have
been just numbered dynamically as they are configured so that makes them
change.
To avoid this, add specific aliases per board to keep the old numbers.
This allows us to change the numbering by default on future SoCs while
keeping the numbering on existing boards.
Pull ARM SoC driver changes from Olof Johansson:
"A handful of driver-related changes. We've had a bunch of them going
in through other branches as well, so it's only a part of what we
really have this release.
Larger pieces are:
- Removal of a now unused PWM driver for atmel
[ This includes AVR32 changes that have been appropriately acked ]
- Performance counter support for the arm CCN interconnect
- OMAP mailbox driver cleanups and consolidation
- PCI and SATA PHY drivers for SPEAr 13xx platforms
- Redefinition (with backwards compatibility!) of PCI DT bindings for
Tegra to better model regulators/power"
Note: this merge also fixes up the semantic conflict with the new
calling convention for devm_phy_create(), see commit f0ed817638b5 ("phy:
core: Let node ptr of PHY point to PHY and not of PHY provider") that
came in through Greg's USB tree.
Semantic merge patch by Stephen Rothwell <sfr@canb.auug.org.au> through
the next tree.
* tag 'drivers-for-3.17' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (38 commits)
bus: arm-ccn: Fix error handling at event allocation
mailbox/omap: add a parent structure for every IP instance
mailbox/omap: remove the private mailbox structure
mailbox/omap: consolidate OMAP mailbox driver
mailbox/omap: simplify the fifo assignment by using macros
mailbox/omap: remove omap_mbox_type_t from mailbox ops
mailbox/omap: remove OMAP1 mailbox driver
mailbox/omap: use devm_* interfaces
bus: ARM CCN: add PERF_EVENTS dependency
bus: ARM CCN PMU driver
PCI: spear: Remove spear13xx_pcie_remove()
PCI: spear: Fix Section mismatch compilation warning for probe()
ARM: tegra: Remove legacy PCIe power supply properties
PCI: tegra: Remove deprecated power supply properties
PCI: tegra: Implement accurate power supply scheme
ARM: SPEAr13xx: Update defconfigs
ARM: SPEAr13xx: Add pcie and miphy DT nodes
ARM: SPEAr13xx: Add bindings and dt node for misc block
ARM: SPEAr13xx: Fix static mapping table
phy: Add drivers for PCIe and SATA phy on SPEAr13xx
These properties are deprecated and no longer of any use.
Currently the Tamonten DTS define a fixed regulator for the 5V supply.
However this regulator is in fact on the base board. Fix this by
properly defining the regulators found on the base boards.
Signed-off-by: Alban Bedel <alban.bedel@avionic-design.de>
These new properties more accurately reflect the real connections of the
boards and therefore make it easier to match them up with schematics.
This ensures that the PMIC RTC provides the system time, rather than
the on-SoC RTC, which is not battery-backed.
tegra124-venice2.dts isn't touched yet since we haven't added any off-
SoC RTC device to its device tree.
Use Tegra pinconrol dt-binding macro to set the values of different pinmux
properties of Tegra20 platforms.
DT node names should include a unit address iff the node has a reg
property. For Tegra DTs at least, we were previously applying a different
rule, namely that node names only needed to include a unit address if it
was required to make the node name unique. Consequently, many unit
addresses are missing. Add them.
Add properties common to all Tamonten-derived boards to the Tamonten
DTSI and add the fixed 1.05 V regulator.
Signed-off-by: Thierry Reding <thierry.reding@avionic-design.de>
Enabling the LP1 suspend mode for Tegra devices.
Tested-by: Marc Dietrich <marvin24@gmx.de> # paz00 board
Signed-off-by: Joseph Lo <josephl@nvidia.com>
Use the GIC and standard IRQ binding defines in all IRQ specifiers.
Use TEGRA_GPIO() macro to name all GPIOs referenced by GPIO properties,
and some interrupts properties. Use standard GPIO flag defines too.
Replace /include/ (dtc) with #include (C pre-processor) for all Tegra DT
files, so that gcc -E handles the entire include tree, and hence any of
those files can #include some other file e.g. for constant definitions.
This allows future use of #defines and header files in order to define
names for various constants, such as the IDs and flags in GPIO
specifiers. Use of those features will increase the readability of the
device tree files.
This patch updates all Tegra board files so that they contain all the
properties required by the updated USB DT binding. Note that this patch
only adds the new properties and does not yet remove the old properties,
in order to maintain bisectability. The old properties will be removed
once the driver has been updated to assume the new bindings.
Signed-off-by: Venu Byravarasu <vbyravarasu@nvidia.com>
[swarren: fixed some newly added regulator-name properties to better
match schematic, avoided duplicate regulator-name on Whistler.]
Adding the PM configuration of PMC when the platform support suspend
function.
Adding the bindings of the clock source of PMC in DT.
The GPIO pin of SD slot card detection should active low.
Tested-by: Thierry Reding <thierry.reding@avionic-design.de>
No Tegra20 Platform is running PLL_P at another rate than 216MHz, nor is
any using any other PLL as UART source clock. Move attribute into SoC
level dtsi file to slim down board DT files.
Signed-off-by: Lucas Stach <dev@lynxeye.de>
Hook up the required regulators, I2C DDC adapter and hotplug detect GPIO
to the Tamonten HDMI output. Carrier boards still need to explicitly
enable the output to use it.
The Tamonten SOM has an ON Semiconductor NCT1008 connected to the DVC
bus which is used to measure the ambient (local) temperature as well as
the on-die (remote) temperature.
This commit allows the I2C2 controller on Tegra20 to be routed either to
the DDC or the PTA pin group at runtime. On Tamonten this allows the I2C
bus to be used for the DDC of the HDMI connector or to access I2C chips
on the carrier board.
Commit 13511de "regulator: deprecate regulator-compatible DT property"
now allows for simpler content within the regulators node within a PMIC.
Modify all the Tegra device tree files to take advantage of this.
Acked-by: Thierry Reding <thierry.reding@avionic-design.de>
The Tamonten is an NVIDIA Tegra2 based system-on-module (SOM) that is
designed to cover a broad range of applications.
