path: root/arch/arm/boot/dts/tegra30-apalis-v1.1-eval.dts
2018-09-26ARM: tegra: apalis_t30: support v1.1 hardware revisionMarcel Ziswiler
Support the V1.1 hardware revisions with the following change: Changed power rail for MMC1 interface to a 3.3V/1.8V switchable rail in order to be able to run UHS SD cards in ultra high speed 1.8V mode. [ 207.502011] mmc2: host does not support reading read-only switch, assuming write-enable [ 207.517011] mmc2: new ultra high speed SDR104 SDHC card at address aaaa [ 207.534190] mmcblk2: mmc2:aaaa SE32G 29.7 GiB [ 207.545096] mmcblk2: p1 root@apalis-t30:~# cat /sys/kernel/debug/mmc2/ios clock: 208000000 Hz actual clock: 204000000 Hz vdd: 21 (3.3 ~ 3.4 V) bus mode: 2 (push-pull) chip select: 0 (don't care) power mode: 2 (on) bus width: 2 (4 bits) timing spec: 6 (sd uhs SDR104) signal voltage: 1 (1.80 V) driver type: 0 (driver type B) root@apalis-t30:~# hdparm -t /dev/mmcblk2 /dev/mmcblk2: Timing buffered disk reads: 256 MB in 3.02 seconds = 84.71 MB/sec Signed-off-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> Reviewed-by: Rob Herring <robh@kernel.org> Signed-off-by: Thierry Reding <treding@nvidia.com>
