path: root/arch/arm/boot/dts/tegra30-apalis.dtsi
2018-09-26ARM: tegra: apalis_t30: support v1.1 hardware revisionMarcel Ziswiler
Support the V1.1 hardware revisions with the following change: Changed power rail for MMC1 interface to a 3.3V/1.8V switchable rail in order to be able to run UHS SD cards in ultra high speed 1.8V mode. [ 207.502011] mmc2: host does not support reading read-only switch, assuming write-enable [ 207.517011] mmc2: new ultra high speed SDR104 SDHC card at address aaaa [ 207.534190] mmcblk2: mmc2:aaaa SE32G 29.7 GiB [ 207.545096] mmcblk2: p1 root@apalis-t30:~# cat /sys/kernel/debug/mmc2/ios clock: 208000000 Hz actual clock: 204000000 Hz vdd: 21 (3.3 ~ 3.4 V) bus mode: 2 (push-pull) chip select: 0 (don't care) power mode: 2 (on) bus width: 2 (4 bits) timing spec: 6 (sd uhs SDR104) signal voltage: 1 (1.80 V) driver type: 0 (driver type B) root@apalis-t30:~# hdparm -t /dev/mmcblk2 /dev/mmcblk2: Timing buffered disk reads: 256 MB in 3.02 seconds = 84.71 MB/sec Signed-off-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> Reviewed-by: Rob Herring <robh@kernel.org> Signed-off-by: Thierry Reding <treding@nvidia.com>
2018-09-26ARM: tegra: apalis_t30: move hda node from carrier to moduleMarcel Ziswiler
Move the hda node from the carrier board to the module level device tree. Signed-off-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> Signed-off-by: Thierry Reding <treding@nvidia.com>
2018-09-26ARM: tegra: apalis_t30: fix mcp2515 can controller interrupt polarityMarcel Ziswiler
Fix the MCP2515 SPI CAN controller interrupt polarity which according to its datasheet defaults to low-active aka falling edge. Signed-off-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> Signed-off-by: Thierry Reding <treding@nvidia.com>
2018-09-26ARM: tegra: apalis_t30: rename tps65911@2d, stmpe811@41 and tps62362@60Marcel Ziswiler
Rename a few nodes using more common names: - rename tps65911@2d to pmic@2d - rename stmpe811@41 to touchscreen@41 - rename tps62362@60 to regulator@60 Signed-off-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> Signed-off-by: Thierry Reding <treding@nvidia.com>
2018-09-26ARM: tegra: apalis_t30: rename hdmiddc to hdmi_ddcMarcel Ziswiler
Rename hdmiddc to hdmi_ddc to be more in-line with other device trees. Signed-off-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> Signed-off-by: Thierry Reding <treding@nvidia.com>
2018-09-26ARM: tegra: apalis_t30: drop module level model and compatibleMarcel Ziswiler
Drop model and compatible nodes from the module level device tree as they get overridden by the carrier board device tree anyway. Signed-off-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> Signed-off-by: Thierry Reding <treding@nvidia.com>
2018-09-26ARM: tegra: apalis_t30: get rid of fake clocks simple busMarcel Ziswiler
Get rid of the fake clocks simple bus and use node names as per the actual schematics. Signed-off-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> Signed-off-by: Thierry Reding <treding@nvidia.com>
2018-09-26ARM: tegra: apalis_t30: enable emmc ddr52 modeMarcel Ziswiler
Add mmc-ddr-1_8v property enabling eMMC DDR52 mode. root@apalis-t30:~# cat /sys/kernel/debug/mmc1/ios clock: 52000000 Hz actual clock: 52000000 Hz vdd: 21 (3.3 ~ 3.4 V) bus mode: 2 (push-pull) chip select: 0 (don't care) power mode: 2 (on) bus width: 3 (8 bits) timing spec: 8 (mmc DDR52) signal voltage: 1 (1.80 V) driver type: 0 (driver type B) root@apalis-t30:~# hdparm -t /dev/mmcblk1 /dev/mmcblk1: Timing buffered disk reads: 232 MB in 3.01 seconds = 77.10 MB/sec Signed-off-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> Signed-off-by: Thierry Reding <treding@nvidia.com>
2018-09-26ARM: tegra: apalis_t30: add proper emmc vmmc and vqmmc suppliesMarcel Ziswiler
Add proper eMMC vmmc and vqmmc supplies e.g. fixing signalling voltage. Signed-off-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> Signed-off-by: Thierry Reding <treding@nvidia.com>
2018-09-26ARM: tegra: apalis_t30: add i2c-thermtripMarcel Ziswiler
Add i2c-thermtrip which would set the DEV_OFF bit in the DCDC control register of the TPS65911 PMIC. Signed-off-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> Signed-off-by: Thierry Reding <treding@nvidia.com>
2018-09-26ARM: tegra: apalis_t30: further lm95245 temperature sensor annotationMarcel Ziswiler
Further LM95245 temperature sensor annotation. Signed-off-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> Signed-off-by: Thierry Reding <treding@nvidia.com>
2018-09-26ARM: tegra: apalis_t30: use proper irq-gpio for stmpe811Marcel Ziswiler
Use proper irq-gpio for stmpe811 touch controller. Signed-off-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> Signed-off-by: Thierry Reding <treding@nvidia.com>
2018-09-26ARM: tegra: apalis_t30: add missing pinmuxMarcel Ziswiler
Explicitly mux all T30 SoC balls now: - Apalis GPIO - Apalis HDMI1 - Apalis I2C1 - Apalis I2C2 (DDC) - Apalis LCD1 - Apalis Parallel Camera - Apalis SATA1_ACT# - Apalis SPDIF1 - Apalis TS (Low-speed type specific) - Apalis USBH_EN - Apalis USBH_OC# - Apalis VGA1 - on-module i210/i211 LAN control signals - not connected and therefore disabled signals Signed-off-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> Signed-off-by: Thierry Reding <treding@nvidia.com>
2018-09-26ARM: tegra: apalis_t30: pinmux clean-upMarcel Ziswiler
Clean-up pinmuxing: - white-space clean-up - explicitly disable input of BKL1_ON, BKL1_PWM and BKL1_PWM_EN# - annotate Apalis I2C3 usage for CAM - get rid of nvidia,lock property - add missing eMMC sdmmc4_cmd_pt7 and explicitly enable input - explicitly disable lcd_dc1_pd2 (e.g. LM95245 I2C address pin) - annotate TOUCH_PEN_INT# being on-module - As underscores in node names are not recommended replace them all where possible with dashes. Signed-off-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> Signed-off-by: Thierry Reding <treding@nvidia.com>
2018-09-26ARM: tegra: apalis_t30: white-space/newline clean-upMarcel Ziswiler
White-space and newline clean-up. Signed-off-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> Signed-off-by: Thierry Reding <treding@nvidia.com>
2018-09-26ARM: tegra: apalis_t30: annotate uarts and move compatible to boardMarcel Ziswiler
Annotate UARTs and move the serial UART "nvidia,tegra30-hsuart" compatible definitions from the carrier board to the module level device trees. One could still override this in a custom carrier board device tree if required. Signed-off-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> Signed-off-by: Thierry Reding <treding@nvidia.com>
2018-09-26ARM: tegra: apalis_t30: add missing regulatorsMarcel Ziswiler
Add missing regulators: - reg_module_3v3_audio being VDDA supply of SGTL5000 - VDDD supply of SGTL5000 actually being reg_1v8_vio - carrier board HDMI supply being reg_5v0 - carrier board reg_3v3 actually being backlight and panel power supply Signed-off-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> Signed-off-by: Thierry Reding <treding@nvidia.com>
2018-09-26ARM: tegra: apalis_t30: regulator clean-upMarcel Ziswiler
Just cosmetic regulator clean-up. Signed-off-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> Signed-off-by: Thierry Reding <treding@nvidia.com>
2018-09-26ARM: tegra: apalis_t30: reorder host1x/hdmi propertiesMarcel Ziswiler
Reorder Host1x/HDMI properties. Signed-off-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> Signed-off-by: Thierry Reding <treding@nvidia.com>
2018-09-26ARM: tegra: apalis_t30: annotate/clean-up pcie controller/port nodesMarcel Ziswiler
Annotate PCIe port nodes and clean-up PCIe controller/port status' with respect to carrier board vs. module level device trees. As port 3 connects to the on-module Gigabit Ethernet MACPHY it is always enabled together with the PCIe controller itself. Signed-off-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> Signed-off-by: Thierry Reding <treding@nvidia.com>
2018-09-26ARM: tegra: apalis_t30: reorder pcie propertiesMarcel Ziswiler
Reorder PCIe properties. Signed-off-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> Signed-off-by: Thierry Reding <treding@nvidia.com>
2018-09-26ARM: tegra: apalis_t30: add local-mac-address propertyMarcel Ziswiler
Add empty local-mac-address property to be filled in by boot loader (e.g. U-Boot). Signed-off-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> Signed-off-by: Thierry Reding <treding@nvidia.com>
2018-09-26ARM: tegra: apalis_t30: pull-up sd card detect pinsMarcel Ziswiler
In order to avoid any floating SD card detect pins as may e.g. happen on Ixora V1.1A pull them all up. Signed-off-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> Signed-off-by: Thierry Reding <treding@nvidia.com>
2018-09-26ARM: tegra: apalis_t30: fix mmc1 cmd pull-upMarcel Ziswiler
Fix MMC1 cmd pin pull-up causing issues on carrier boards without external pull-up. Signed-off-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> Signed-off-by: Thierry Reding <treding@nvidia.com>
2018-07-09ARM: tegra: Fix unit_address_vs_reg and avoid_unnecessary_addr_size DTC warningsKrzysztof Kozlowski
Remove unneeded address/size cells properties and unit addresses to fix DTC warnings like: arch/arm/boot/dts/tegra30-apalis-eval.dtb: Warning (unit_address_vs_reg): /i2c@7000d000/stmpe811@41/stmpe_touchscreen@0: node has a unit name, but no reg property arch/arm/boot/dts/tegra30-apalis-eval.dtb: Warning (avoid_unnecessary_addr_size): /i2c@7000d000/stmpe811@41: unnecessary #address-cells/#size-cells without "ranges" or child "reg" property Signed-off-by: Krzysztof Kozlowski <krzk@kernel.org> Reviewed-by: Stefan Agner <stefan@agner.ch> Signed-off-by: Thierry Reding <treding@nvidia.com>
2018-07-09ARM: tegra: Fix unit_address_vs_reg DTC warnings for /memoryKrzysztof Kozlowski
Add a generic /memory node in each Tegra DTSI (with empty reg property, to be overidden by each DTS) and set proper unit address for /memory nodes to fix the DTC warnings: arch/arm/boot/dts/tegra20-harmony.dtb: Warning (unit_address_vs_reg): /memory: node has a reg or ranges property, but no unit name The DTB after the change is the same as before except adding unit-address to /memory node. Signed-off-by: Krzysztof Kozlowski <krzk@kernel.org> Reviewed-by: Stefan Agner <stefan@agner.ch> Signed-off-by: Thierry Reding <treding@nvidia.com>
2018-07-09ARM: tegra: Remove usage of deprecated skeleton.dtsiKrzysztof Kozlowski
Remove the usage of skeleton.dtsi because it was deprecated since commit 9c0da3cc61f1 ("ARM: dts: explicitly mark skeleton.dtsi as deprecated"). It also allows later to fix DTC warnings for missing unit name in /memory nodes. Compiled DTBs are the same as before this commit. Signed-off-by: Krzysztof Kozlowski <krzk@kernel.org> Reviewed-by: Stefan Agner <stefan@agner.ch> Signed-off-by: Thierry Reding <treding@nvidia.com>
2018-07-09ARM: tegra: Fix can2 on Tegra30 ApalisMarcel Ziswiler
CAN2 currently fails on probe as follows: mcp251x spi1.1: Probe failed, err=19 Fix this by enabling input on pin mux of resp. SPI4 pins. Signed-off-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> Signed-off-by: Marcel Ziswiler <marcel@ziswiler.com> Signed-off-by: Thierry Reding <treding@nvidia.com>
2018-03-08ARM: tegra: apalis/colibri: Remove unneeded reg propertyMarcel Ziswiler
As described in Documentation/devicetree/bindings/input/touchscreen/stmpe.txt there is no 'reg' property under stmpe_touchscreen, so remove it to fix the following build warning with W=1: arch/arm/boot/dts/tegra30-apalis-eval.dtb: Warning (unit_address_vs_reg): Node /i2c@7000d000/stmpe811@41/stmpe_touchscreen has a reg or ranges property, but no unit name Similar to commit 89277e8e2679 ("ARM: dts: imx6qdl-apalis: Remove unneeded reg property"). Signed-off-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> Signed-off-by: Thierry Reding <treding@nvidia.com>
2018-03-08ARM: tegra: Fix I2C bus frequencies on Apalis/ColibriMarcel Ziswiler
Use a faster speed of 400 kbit/s for regular I2C busses. Use a slower speed of 10 kbit/s for DDC/EDID to improve reliability. Use a slower speed of 100 kbit/s for power I2C to be within specs of the LM95245 temperature sensor. While at it further annotate I2C pin usage. Signed-off-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> Signed-off-by: Thierry Reding <treding@nvidia.com>
2018-03-08ARM: tegra: Use proper IRQ type definitionsMarcel Ziswiler
This switches a few interrupt definitions that were using either GPIO_ACTIVE_HIGH or GPIO_ACTIVE_LOW as IRQ type, which is invalid. This is mostly a cosmetic change, that doesn't affect any driver. Analogous to Paul's commit 38333641b6dd ("ARM: tegra: nyan: Use proper IRQ type definitions"). Signed-off-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> Signed-off-by: Thierry Reding <treding@nvidia.com>
Many source files in the tree are missing licensing information, which makes it harder for compliance tools to determine the correct license. By default all files without license information are under the default license of the kernel, which is GPL version 2. Update the files which contain no license information with the 'GPL-2.0' SPDX license identifier. The SPDX identifier is a legally binding shorthand, which can be used instead of the full boiler plate text. This patch is based on work done by Thomas Gleixner and Kate Stewart and Philippe Ombredanne. How this work was done: Patches were generated and checked against linux-4.14-rc6 for a subset of the use cases: - file had no licensing information it it. - file was a */uapi/* one with no licensing information in it, - file was a */uapi/* one with existing licensing information, Further patches will be generated in subsequent months to fix up cases where non-standard license headers were used, and references to license had to be inferred by heuristics based on keywords. The analysis to determine which SPDX License Identifier to be applied to a file was done in a spreadsheet of side by side results from of the output of two independent scanners (ScanCode & Windriver) producing SPDX tag:value files created by Philippe Ombredanne. Philippe prepared the base worksheet, and did an initial spot review of a few 1000 files. The 4.13 kernel was the starting point of the analysis with 60,537 files assessed. Kate Stewart did a file by file comparison of the scanner results in the spreadsheet to determine which SPDX license identifier(s) to be applied to the file. She confirmed any determination that was not immediately clear with lawyers working with the Linux Foundation. Criteria used to select files for SPDX license identifier tagging was: - Files considered eligible had to be source code files. - Make and config files were included as candidates if they contained >5 lines of source - File already had some variant of a license header in it (even if <5 lines). All documentation files were explicitly excluded. The following heuristics were used to determine which SPDX license identifiers to apply. - when both scanners couldn't find any license traces, file was considered to have no license information in it, and the top level COPYING file license applied. For non */uapi/* files that summary was: SPDX license identifier # files ---------------------------------------------------|------- GPL-2.0 11139 and resulted in the first patch in this series. If that file was a */uapi/* path one, it was "GPL-2.0 WITH Linux-syscall-note" otherwise it was "GPL-2.0". Results of that was: SPDX license identifier # files ---------------------------------------------------|------- GPL-2.0 WITH Linux-syscall-note 930 and resulted in the second patch in this series. - if a file had some form of licensing information in it, and was one of the */uapi/* ones, it was denoted with the Linux-syscall-note if any GPL family license was found in the file or had no licensing in it (per prior point). Results summary: SPDX license identifier # files ---------------------------------------------------|------ GPL-2.0 WITH Linux-syscall-note 270 GPL-2.0+ WITH Linux-syscall-note 169 ((GPL-2.0 WITH Linux-syscall-note) OR BSD-2-Clause) 21 ((GPL-2.0 WITH Linux-syscall-note) OR BSD-3-Clause) 17 LGPL-2.1+ WITH Linux-syscall-note 15 GPL-1.0+ WITH Linux-syscall-note 14 ((GPL-2.0+ WITH Linux-syscall-note) OR BSD-3-Clause) 5 LGPL-2.0+ WITH Linux-syscall-note 4 LGPL-2.1 WITH Linux-syscall-note 3 ((GPL-2.0 WITH Linux-syscall-note) OR MIT) 3 ((GPL-2.0 WITH Linux-syscall-note) AND MIT) 1 and that resulted in the third patch in this series. - when the two scanners agreed on the detected license(s), that became the concluded license(s). - when there was disagreement between the two scanners (one detected a license but the other didn't, or they both detected different licenses) a manual inspection of the file occurred. - In most cases a manual inspection of the information in the file resulted in a clear resolution of the license that should apply (and which scanner probably needed to revisit its heuristics). - When it was not immediately clear, the license identifier was confirmed with lawyers working with the Linux Foundation. - If there was any question as to the appropriate license identifier, the file was flagged for further research and to be revisited later in time. In total, over 70 hours of logged manual review was done on the spreadsheet to determine the SPDX license identifiers to apply to the source files by Kate, Philippe, Thomas and, in some cases, confirmation by lawyers working with the Linux Foundation. Kate also obtained a third independent scan of the 4.13 code base from FOSSology, and compared selected files where the other two scanners disagreed against that SPDX file, to see if there was new insights. The Windriver scanner is based on an older version of FOSSology in part, so they are related. Thomas did random spot checks in about 500 files from the spreadsheets for the uapi headers and agreed with SPDX license identifier in the files he inspected. For the non-uapi files Thomas did random spot checks in about 15000 files. In initial set of patches against 4.14-rc6, 3 files were found to have copy/paste license identifier errors, and have been fixed to reflect the correct identifier. Additionally Philippe spent 10 hours this week doing a detailed manual inspection and review of the 12,461 patched files from the initial patch version early this week with: - a full scancode scan run, collecting the matched texts, detected license ids and scores - reviewing anything where there was a license detected (about 500+ files) to ensure that the applied SPDX license was correct - reviewing anything where there was no detection but the patch license was not GPL-2.0 WITH Linux-syscall-note to ensure that the applied SPDX license was correct This produced a worksheet with 20 files needing minor correction. This worksheet was then exported into 3 different .csv files for the different types of files to be modified. These .csv files were then reviewed by Greg. Thomas wrote a script to parse the csv files and add the proper SPDX tag to the file, in the format that the file expected. This script was further refined by Greg based on the output to detect more types of files automatically and to distinguish between header and source .c files (which need different comment types.) Finally Greg ran the script using the .csv files to generate the patches. Reviewed-by: Kate Stewart <kstewart@linuxfoundation.org> Reviewed-by: Philippe Ombredanne <pombredanne@nexb.com> Reviewed-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-06-13ARM: dts: tegra: fix PCI bus dtc warningsRob Herring
dtc recently added PCI bus checks. Fix these warnings. Signed-off-by: Rob Herring <robh@kernel.org> Cc: Stephen Warren <swarren@wwwdotorg.org> Cc: Thierry Reding <thierry.reding@gmail.com> Cc: Alexandre Courbot <gnurou@gmail.com> Cc: linux-tegra@vger.kernel.org Signed-off-by: Thierry Reding <treding@nvidia.com>
2016-11-07ARM: tegra: apalis/colibri t30: Integrate audioMarcel Ziswiler
Integrate Freescale SGTL5000 analogue audio codec support. Signed-off-by: Marcel Ziswiler <marcel@ziswiler.com> Reviewed-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> [treding@nvidia.com: remove leading 0 from unit-address] Signed-off-by: Thierry Reding <treding@nvidia.com>
2016-07-11ARM: tegra: Add spaces around = in propertiesThierry Reding
This seems to have been copied and pasted since the beginning of time, though only until Tegra124, likely because that DT was written from scratch or it was fixed along the way. Signed-off-by: Thierry Reding <treding@nvidia.com>
2016-07-11ARM: tegra: Fix a couple of DTC warningsThierry Reding
Add unit-addresses to nodes that have a reg property to avoid warnings on newer versions of DTC. Signed-off-by: Thierry Reding <treding@nvidia.com>
2015-09-15ARM: tegra: apalis: Properly align pin namesThierry Reding
Align pin names on subsequent lines with the first the name of the first pin in the first line. Signed-off-by: Thierry Reding <treding@nvidia.com>
2015-09-15ARM: tegra: apalis: Add digital audio pin muxingMarcel Ziswiler
Add Apalis digital audio pin muxing which is e.g. used for HDA operation together with the Realtek HDA codec as found on the Apalis Evaluation board. Signed-off-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> Signed-off-by: Thierry Reding <treding@nvidia.com>
2015-09-15ARM: tegra: apalis: Add comment concerning eMMCMarcel Ziswiler
Instead of adding an otherwise unused emmc label just add a comment describing what the SDHCI is routed to. Signed-off-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> Signed-off-by: Thierry Reding <treding@nvidia.com>
2015-09-15ARM: tegra: apalis: Fix pin muxingMarcel Ziswiler
Fix pin muxing which got broken due to certain stuff having been fixed or renamed since. Signed-off-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> Signed-off-by: Thierry Reding <treding@nvidia.com>
2015-09-15ARM: tegra: apalis: Fix HDMI power suppliesMarcel Ziswiler
Fix HDMI supplies (both regular VDD as well as PLL ones) being switched by the TPS65911 PMIC's GPIO6 aka EN_VDD_HDMI by introducing two new GPIO switched fixed regulators avdd_hdmi_pll_1v8_reg and avdd_hdmi_3v3_reg. Signed-off-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> Signed-off-by: Thierry Reding <treding@nvidia.com>
2015-09-15ARM: tegra: apalis: Update hardware revisions compatibility commentMarcel Ziswiler
Update introductory comment about what exact hardware revisions this device tree is compatible with as a hint for our customers. Signed-off-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> Signed-off-by: Thierry Reding <treding@nvidia.com>
2014-08-24ARM: tegra: apalis/colibri t30: fix on-module 5v0 suppliesMarcel Ziswiler
Working on Gigabit/PCIe support in U-Boot for Apalis T30 I realised that the current device tree source includes for our modules only happen to work due to referencing the on-carrier 5v0 supply from USB which is not at all available on-module. The modules actually contain TPS60150 charge pumps to generate the PMIC required 5 volts from the one and only 3.3 volt module supply. This patch fixes this. (Note: When back-porting this to v3.16 stable releases, simply drop the change to tegra30-apalis.dtsi; that file was added in v3.17) Cc: <stable@vger.kernel.org> #v3.16+ Signed-off-by: Marcel Ziswiler <marcel@ziswiler.com> Signed-off-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Olof Johansson <olof@lixom.net>
2014-07-17ARM: tegra: Migrate Apalis T30 PCIe power supply schemeMarcel Ziswiler
This migration is required for continued PCIe operation after commit d3c7e24b84fc "PCI: tegra: Implement accurate power supply scheme". Signed-off-by: Marcel Ziswiler <marcel@ziswiler.com> [swarren: added commit subject and shortened hash] Signed-off-by: Stephen Warren <swarren@nvidia.com>
2014-07-17ARM: tegra: initial support for apalis t30Marcel Ziswiler
This patch adds the device tree to support Toradex Apalis T30, a computer on module which can be used on different carrier boards. The module consists of a Tegra 3 SoC, two PMICs, 1 or 2 GB of DDR3L RAM, eMMC, an LM95245 temperature sensor chip, an i210 resp. i211 gigabit Ethernet controller, an STMPE811 ADC/touch controller as well as two MCP2515 CAN controllers. Furthermore, there is an SGTL5000 audio codec which is not yet supported. Anything that is not self contained on the module is disabled by default. The device tree for the Evaluation Board includes the modules device tree and enables the supported peripherals of the carrier board (the Evaluation Board supports almost all of them). While at it also add the device tree binding documentation for Apalis T30. Signed-off-by: Marcel Ziswiler <marcel@ziswiler.com> [swarren: fixed some node sort orders] Signed-off-by: Stephen Warren <swarren@nvidia.com>
