path: root/arch/arm/boot/dts/tegra30-colibri-eval-v3.dts
2014-05-15ARM: tegra: initial add of Colibri T30Stefan Agner
This patch adds the device tree to support Toradex Colibri T30, a computer on module which can be used on different carrier boards. The module consists of a Tegra 30 SoC, two PMIC, DDR3L RAM, eMMC, a LM95245 temperature sensor and an AX88772B USB Ethernet Controller. Furthermore, there is a STMPE811 and SGTL5000 audio codec which are not yet supported. Anything that is not self contained on the module is disabled by default. The device tree for the Evaluation Board includes the modules device tree and enables the supported pheripherials of the carrier board (the Evaluation Board supports almost all of them). Signed-off-by: Stefan Agner <stefan@agner.ch> Signed-off-by: Stephen Warren <swarren@nvidia.com>
