Integrate Freescale SGTL5000 analogue audio codec support.
Signed-off-by: Marcel Ziswiler <marcel@ziswiler.com>
[treding@nvidia.com: remove leading 0 from unit-address]
Signed-off-by: Thierry Reding <treding@nvidia.com>
This seems to have been copied and pasted since the beginning of time,
though only until Tegra124, likely because that DT was written from
scratch or it was fixed along the way.
Align pin names on subsequent lines with the first the name of the first
pin in the first line.
Rather than a bogus label just add a comment identifying the SDHCI
instance connected to the on-module eMMC.
Activate STMPE811 touch controller as found on Colibri T30 modules.
Add TOUCH_PEN_INT# pin muxing required for proper STMPE811 touch screen
controller operation.
Fix the comment about the 3v3 fixed supply as the previous v3_3 was
bogus.
Add pin muxing for the on-module power I2C bus which connects to the
PMICs, temperature sensor and touch screen controller.
Improve the comment about the THERMD_ALERT# pin which is the unlatched
I2C address pin of the LM95245 temperature sensor and therefore
requires disabling for now otherwise it won't get detected properly.
While at it also move that pin further down to have it alphabetically
sorted again.
Fix HDMI supplies (both regular VDD as well as PLL ones) being switched
by the TPS65911 PMIC's GPIO6 aka EN_VDD_HDMI by introducing two new GPIO
witched fixed regulators avdd_hdmi_pll_1v8_reg and avdd_hdmi_3v3_reg.
Update introductory comment about what exact hardware revisions this
device tree is compatible with as a hint for our customers.
Working on Gigabit/PCIe support in U-Boot for Apalis T30 I realised
that the current device tree source includes for our modules only
happen to work due to referencing the on-carrier 5v0 supply from USB
which is not at all available on-module. The modules actually contain
TPS60150 charge pumps to generate the PMIC required 5 volts from the
one and only 3.3 volt module supply. This patch fixes this.
(Note: When back-porting this to v3.16 stable releases, simply drop the
change to tegra30-apalis.dtsi; that file was added in v3.17)
Cc: <stable@vger.kernel.org> #v3.16+
This patch adds the device tree to support Toradex Colibri T30, a
computer on module which can be used on different carrier boards.
The module consists of a Tegra 30 SoC, two PMIC, DDR3L RAM, eMMC,
a LM95245 temperature sensor and an AX88772B USB Ethernet
Controller. Furthermore, there is a STMPE811 and SGTL5000 audio
codec which are not yet supported. Anything that is not self
contained on the module is disabled by default.
The device tree for the Evaluation Board includes the modules
device tree and enables the supported pheripherials of the carrier
board (the Evaluation Board supports almost all of them).
Signed-off-by: Stefan Agner <stefan@agner.ch>
