path: root/arch/arm/boot/dts/tps65910.dtsi
2019-06-19treewide: Replace GPLv2 boilerplate/reference with SPDX - rule 500Thomas Gleixner
Based on 2 normalized pattern(s): this program is free software you can redistribute it and or modify it under the terms of the gnu general public license version 2 as published by the free software foundation this program is free software you can redistribute it and or modify it under the terms of the gnu general public license version 2 as published by the free software foundation # extracted by the scancode license scanner the SPDX license identifier GPL-2.0-only has been chosen to replace the boilerplate/reference in 4122 file(s). Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Reviewed-by: Enrico Weigelt <info@metux.net> Reviewed-by: Kate Stewart <kstewart@linuxfoundation.org> Reviewed-by: Allison Randal <allison@lohutok.net> Cc: linux-spdx@vger.kernel.org Link: https://lkml.kernel.org/r/20190604081206.933168790@linutronix.de Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-02-28ARM: dts: tps65910 backup battery regulatorMarkus Pargmann
This patch adds a devicetree node for the backup battery regulator. Signed-off-by: Markus Pargmann <mpa@pengutronix.de> Signed-off-by: Tony Lindgren <tony@atomide.com>
2012-08-30arm/dts: regulator: Add tps65910 device tree dataAnilKumar Ch
Add device tree data for tps65910 regulator by adding all tps65910 regulator nodes. Regulator is initialized based on compatiable name provided in tps65910 DT file. All tps65910 PMIC regulator device tree nodes are placed in a seperate device tree include file (tps65910.dtsi). This patch was tested on AM335x-EVM. Signed-off-by: AnilKumar Ch <anilkumar@ti.com> Reviewed-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
