path: root/arch/arm/boot/dts/usb_a9260_common.dtsi
2019-05-21treewide: Replace GPLv2 boilerplate/reference with SPDX - rule 4Thomas Gleixner
Based on 1 normalized pattern(s): licensed under gplv2 or later extracted by the scancode license scanner the SPDX license identifier GPL-2.0-or-later has been chosen to replace the boilerplate/reference in 118 file(s). Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Reviewed-by: Jilayne Lovejoy <opensource@jilayne.com> Reviewed-by: Steve Winslow <swinslow@gmail.com> Reviewed-by: Allison Randal <allison@lohutok.net> Reviewed-by: Kate Stewart <kstewart@linuxfoundation.org> Cc: linux-spdx@vger.kernel.org Link: https://lkml.kernel.org/r/20190519154040.961286471@linutronix.de Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-12-31ARM: dts: at91: calao: use TCB0 as timersAlexandre Belloni
Use tcb0 for timers as selected in at91_dt_defconfig. [tested on usb_a9g20 and usb_a9263] Tested-by: Alexandre Belloni <alexandre.belloni@free-electrons.com> Acked-by: Nicolas Ferre <nicolas.ferre@atmel.com> Signed-off-by: Alexandre Belloni <alexandre.belloni@free-electrons.com>
2017-05-31ARM: dts: at91: Switch to the new NAND bindingsBoris Brezillon
Use the new EBI/NAND bindings to declare NAND chips and remove old NAND nodes along the way. Note that we keep using old bindings in at91rm9200.dtsi because this SoC is not supported by the EBI driver. Signed-off-by: Boris Brezillon <boris.brezillon@free-electrons.com> Tested-by: Peter Rosin <peda@axentia.se> Signed-off-by: Alexandre Belloni <alexandre.belloni@free-electrons.com>
2016-07-15ARM: dts: at91: fix i2c-gpio node nameAlexandre Belloni
i2c-gpio doesn't need a reg property. Change the node names to i2c-gpio-x as used in other dts to remove the unit-address. Solves: Warning (unit_address_vs_reg): Node /i2c@0 has a unit name, but no reg property Warning (unit_address_vs_reg): Node /i2c@1 has a unit name, but no reg property Warning (unit_address_vs_reg): Node /i2c@2 has a unit name, but no reg property Signed-off-by: Alexandre Belloni <alexandre.belloni@free-electrons.com>
2016-06-10ARM: dts: at91: calao: remove leftovers clock definitionAlexandre Belloni
The clocks group properties and the clock@0 node have been obsolete for two years, remove them. Acked-by: Nicolas Ferre <nicolas.ferre@atmel.com> Signed-off-by: Alexandre Belloni <alexandre.belloni@free-electrons.com>
2016-06-07ARM: dts: at91: at91sam9260: Remove leading zeros in OHCI node.Raashid Muhammed
Remove leading zeros in OHCI node for at91sam9260 based boards. Signed-off-by: Raashid Muhammed <raashidmuhammed@zilogic.com> Reviewed-by: Vijay Kumar B. <vijaykumar@bravegnu.org> Signed-off-by: Alexandre Belloni <alexandre.belloni@free-electrons.com>
2015-11-16ARM: at91/dt: replace gpio-key,wakeup with wakeup-source propertySudeep Holla
Though the keyboard driver for GPIO buttons(gpio-keys) will continue to check for/support the legacy "gpio-key,wakeup" boolean property to enable gpio buttons as wakeup source, "wakeup-source" is the new standard binding. This patch replaces the legacy "gpio-key,wakeup" with the unified "wakeup-source" property in order to avoid any futher copy-paste duplication. Cc: Alexandre Belloni <alexandre.belloni@free-electrons.com> Cc: Jean-Christophe Plagniol-Villard <plagnioj@jcrosoft.com> Signed-off-by: Sudeep Holla <sudeep.holla@arm.com> Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com>
2014-07-09ARM: at91/dt: usb_a9260: define crystals frequenciesAlexandre Belloni
Define Calao USB-A9260, USB-A9G20 and USB-A9G20-LPW main and slow crystals frequencies. Signed-off-by: Alexandre Belloni <alexandre.belloni@free-electrons.com> Acked-by: Nicolas Ferre <nicolas.ferre@atmel.com>
2013-05-17ARM: at91: dt: switch to standard GPIO flag defines.Jean-Christophe PLAGNIOL-VILLARD
Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com> Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com>
2012-04-20ARM: at91: Calao USB A926x factorize common binding in usb_a9260_commonJean-Christophe PLAGNIOL-VILLARD
This will simplify the adding of the A9260. Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com> Acked-by: Nicolas Ferre <nicolas.ferre@atmel.com>
