path: root/arch/arm/boot/dts/usb_a9263.dts
2016-07-15ARM: dts: at91: fix i2c-gpio node nameAlexandre Belloni
i2c-gpio doesn't need a reg property. Change the node names to i2c-gpio-x as used in other dts to remove the unit-address. Solves: Warning (unit_address_vs_reg): Node /i2c@0 has a unit name, but no reg property Warning (unit_address_vs_reg): Node /i2c@1 has a unit name, but no reg property Warning (unit_address_vs_reg): Node /i2c@2 has a unit name, but no reg property Signed-off-by: Alexandre Belloni <alexandre.belloni@free-electrons.com>
2016-06-10ARM: dts: at91: calao: remove leftovers clock definitionAlexandre Belloni
The clocks group properties and the clock@0 node have been obsolete for two years, remove them. Acked-by: Nicolas Ferre <nicolas.ferre@atmel.com> Signed-off-by: Alexandre Belloni <alexandre.belloni@free-electrons.com>
2015-11-16ARM: at91/dt: replace gpio-key,wakeup with wakeup-source propertySudeep Holla
Though the keyboard driver for GPIO buttons(gpio-keys) will continue to check for/support the legacy "gpio-key,wakeup" boolean property to enable gpio buttons as wakeup source, "wakeup-source" is the new standard binding. This patch replaces the legacy "gpio-key,wakeup" with the unified "wakeup-source" property in order to avoid any futher copy-paste duplication. Cc: Alexandre Belloni <alexandre.belloni@free-electrons.com> Cc: Jean-Christophe Plagniol-Villard <plagnioj@jcrosoft.com> Signed-off-by: Sudeep Holla <sudeep.holla@arm.com> Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com>
2014-07-09ARM: at91/dt: usb_a9263: define crystals frequenciesAlexandre Belloni
Define Calao USB-A9263 main and slow crystals frequencies. Signed-off-by: Alexandre Belloni <alexandre.belloni@free-electrons.com> Acked-by: Nicolas Ferre <nicolas.ferre@atmel.com>
2013-05-31ARM: at91: dt: usb-a9263: add dataflash supportJean-Christophe PLAGNIOL-VILLARD
Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com> Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com>
2013-05-31ARM: at91: dt: usb-a9263: update shutdown controllerJean-Christophe PLAGNIOL-VILLARD
enable rtt and wakeup button (5 msec low) Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com> Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com>
2013-05-17ARM: at91: dt: switch to standard GPIO flag defines.Jean-Christophe PLAGNIOL-VILLARD
2013-05-17ARM: at91: dt: use #include for all device treesJean-Christophe PLAGNIOL-VILLARD
to prepare the switch to the macro. Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com> Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com>
2012-04-20ARM: at91: DT: add Calao USB A9263 board supportJean-Christophe PLAGNIOL-VILLARD
Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com> Acked-by: Nicolas Ferre <nicolas.ferre@atmel.com>
