[ Upstream commit 016add12977bcc30f77d7e48fc9a3a024cb46645 ]
SPI controller nodes should be named 'spi' rather than 'ssp'. Fixing the
name enables dtc SPI bus checks.
Cc: Linus Walleij <linus.walleij@linaro.org>
Signed-off-by: Rob Herring <robh@kernel.org>
Philippe Ombredanne.
How this work was done:
the use cases:
lines of source
lines).
identifiers to apply.
COPYING file license applied.
GPL-2.0 11139
the concluded license(s).
in time.
they are related.
in about 15000 files.
correct identifier.
version early this week with:
license ids and scores
generate the patches.
This moves the boardfile definition of the flash memory in the
Versatile board into the device tree. The flash was already
defined with the property "arm,versatile-flash" which was
not handled by the kernel: instead define it as compatible
also with "cfi-flash" so it detects properly, and delete the
corresponding boardfile code so we get a smooth transition.
The old compatible string "arm,versatile-flash" is reused to
indicate to the MTD physmap subsystem that this flash requires
special VPP handling. (See separate patch.)
Cc: Grant Likely <grant.likely@linaro.org>
Cc: Rob Herring <robh@kernel.org>
The compatible string "simple-bus" is well defined in ePAPR, while
I see no documentation for the "arm,amba-bus" arnywhere in ePAPR or
Documentation/devicetree/.
DT is also used by other projects than Linux kernel. It is not a
good idea to rely on such an unofficial binding.
This commit
- replaces "arm,amba-bus" with "simple-bus"
- drops "arm,amba-bus" where it is used along with "simple-bus"
Pull ARM DT updates from Olof Johansson:
"As usual, the bulk of this release is again DT file contents.
There's a huge number of changes here, and it's challenging to give a
crisp overview of just what is in here. To start with:
New boards:
- TI-based DM3730 from LogicPD (Torpedo)
- Cosmic+ M4 (nommu) initial support (Freescale Vybrid)
- Raspberry Pi 2 DT files
- Watchdog on Meson8b
- Veyron-mickey (ASUS Chromebit) DTS
- Rockchip rk3228 SoC and eval board
- Sigma Designs Tango4
Improvements:
- Improved support for Qualcomm APQ8084, including Sony Xperia Z DT files
- Misc new devices for Rockchip rk3036 and rk3288
- Allwinner updates for misc SoCs and systems
... and a _large_ number of other changes across the field. Devices
added to SoC DTSI and board DTS files for a number of SoC vendors, new
product boards on already-supported SoCs, cleanups and refactorings of
existing DTS/DTSI files and a bunch of other changes"
* tag 'armsoc-dt' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (469 commits)
ARM: dts: compulab: add new board description
ARM: versatile: add the syscon LEDs to the DT
dts: vt8500: Fix errors in SDHC node for WM8505
ARM: dts: imx6q: clean up unused ipu2grp
ARM: dts: silk: Add compatible property to "partitions" node
ARM: dts: gose: Add compatible property to "partitions" node
ARM: dts: porter: Add compatible property to "partitions" node
ARM: dts: koelsch: Add compatible property to "partitions" node
ARM: dts: lager: Add compatible property to "partitions" node
ARM: dts: bockw: Add compatible property to "partitions" node
ARM: dts: meson8b: Add watchdog node
Documentation: watchdog: Add new bindings for meson8b
ARM: meson: Add status LED for Odroid-C1
ARM: dts: uniphier: fix a typo in comment block
ARM: bcm2835: Add the auxiliary clocks to the device tree.
ARM: bcm2835: Add devicetree for bcm2836 and Raspberry Pi 2 B
ARM: bcm2835: Move the CPU/peripheral include out of common RPi DT.
ARM: bcm2835: Split the DT for peripherals from the DT for the CPU
ARM: realview: set up cache correctly on the PB11MPCore
ARM: dts: Unify G2D device node with other devices on exynos4
The device tree version of Versatile AP/PB never had LED support
so we are missing LEDs from our hardware boards. Add this as
syscon LEDs like we did for Integrator and Juno. We need to
spawn devices in the syscon with "simple-mfd" for this to work.
Commit 0976c946a610d06e907335b7a3afa6db046f8e1b
"arm/versatile: Fix versatile irq specifications"
has an off-by-one error on the Versatile AB that has
been regressing the Versatile AB hardware for some time.
However it seems like the interrupt assignments have
never been correct and I have now adjusted them according
to the specification. The masks for the valid interrupts
made it impossible to assign the right SIC interrupt
for the MMCI, so I went in and fixed these to correspond
to the specifications, and added references if anyone
wants to double-check.
Due to the Versatile PB including the Versatile AB
as a base DTS file, we need to override and correct
some values to correspond to the actual changes in the
hardware.
For the Versatile PB I don't think the IRQ line
assignment for MMCI has ever been correct for either of
the two MMCI blocks. It would be nice if someone with the
physical PB board could test this.
Patch tested on the Versatile AB, QEMU for Versatile AB
and QEMU for Versatile PB.
Cc: stable@vger.kernel.org
Fixes: 0976c946a610 ("arm/versatile: Fix versatile irq specifications")
The Versatile boards have the same sysregs as other ARM Ltd boards. Add
the nodes in order to enable support for 24MHz counter as sched_clock.
This is a minimal node definition as the existing sub node definition
used on VExpress has some issues raised by Linus W.
Cc: devicetree@vger.kernel.org
Signed-off-by: Daniel Lezcano <daniel.lezcano@linaro.org>
Pull device tree updates from Grant Likely:
"The branch contains the following device tree changes the v3.17 merge
window:
Group changes to the device tree. In preparation for adding device
tree overlay support, OF_DYNAMIC is reworked so that a set of device
tree changes can be prepared and applied to the tree all at once.
OF_RECONFIG notifiers see the most significant change here so that
users always get a consistent view of the tree. Notifiers generation
is moved from before a change to after it, and notifiers for a group
of changes are emitted after the entire block of changes have been
applied
Automatic console selection from DT. Console drivers can now use
of_console_check() to see if the device node is specified as a console
device. If so then it gets added as a preferred console. UART
devices get this support automatically when uart_add_one_port() is
called.
DT unit tests no longer depend on pre-loaded data in the device tree.
Data is loaded dynamically at the start of unit tests, and then
unloaded again when the tests have completed.
Also contains a few bugfixes for reserved regions and early memory
setup"
* tag 'devicetree-for-linus' of git://git.secretlab.ca/git/linux: (21 commits)
of: Fixing OF Selftest build error
drivers: of: add automated assignment of reserved regions to client devices
of: Use proper types for checking memory overflow
of: typo fix in __of_prop_dup()
Adding selftest testdata dynamically into live tree
of: Add todo tasklist for Devicetree
of: Transactional DT support.
of: Reorder device tree changes and notifiers
of: Move dynamic node fixups out of powerpc and into common code
of: Make sure attached nodes don't carry along extra children
of: Make devicetree sysfs update functions consistent.
of: Create unlocked versions of node and property add/remove functions
OF: Utility helper functions for dynamic nodes
of: Move CONFIG_OF_DYNAMIC code into a separate file
of: rename of_aliases_mutex to just of_mutex
of/platform: Fix of_platform_device_destroy iteration of devices
of: Migrate of_find_node_by_name() users to for_each_node_by_name()
tty: Update hypervisor tty drivers to use core stdout parsing code.
arm/versatile: Add the uart as the stdout device.
of: Enable console on serial ports specified by /chosen/stdout-path
Add a stdout-path property to the Versatile devicetree so that automatic
console selection works without needing a console= line on the kernel
command line.
Signed-off-by: Grant Likely <grant.likely@linaro.org>
The versatile dts is missing any clock data. Add the clocks.
It is not clear from the documentation where pclk comes from, so for
now it is a dummy clock which is sufficient for things to work.
While not needed for probing, add the "arm,pl180" compatible string for
completeness.
Add valid-mask and clear-mask properties to the versatile dts so the
platform code doing the same thing can be removed.
Two of the versatile irq definitions are incorrect, mostly because two
devices have connections to more than one interrupt controller. Fix them
by using the new interrupts-extended property to fan out without using
an awful interrupt-map nexus node.
Enable DT based init for the sp804 timers on versatile DT platform.
The MMCI driver will not work without two IRQs since this is not
flagged as a single-irq variant. Looking through the complex IRQ
definition for the MMCI on the versatile (including an #if 1
statement forcing MMCI IRQ0 to the VIC) this appears to the the
correct IRQ number for both models.
Cc: Niklas Hernaeus <niklas.hernaeus@linaro.org>
For testing the dt work, define a dt-enabled versatile platform.
This patch adds a new versatile platform for when using the device
tree. Add platform and amba devices are discovered and registered by
parsing the device tree. Clocks and initial io mappings are still
configured statically.
This patch still depends on some static platform_data for a few devices
which is passed via the auxdata structure to of_platform_populate(),
but it is a viable starting point until the drivers can get all
configuration data out of the device tree.
