... for V2M-P1 motherboard CLCD (limited to 640x480 16bpp and using
dedicated video RAM bank) and for V2P-CA9 (up to 1024x768 16bpp).
Signed-off-by: Pawel Moll <pawel.moll@arm.com>
This patch - finally, after over 6 months! :-( - addresses
Samuel's request to split the vexpress-sysreg driver into
smaller portions and define the device in a form of MFD
cells:
* LEDs code has been completely removed and replaced with
"gpio-leds" nodes in the tree (referencing dedicated
GPIO subnodes in sysreg - bindings documentation updated);
this also better fits the reality as some variants of the
motherboard don't have all the LEDs populated
* syscfg bridge code has been extracted into a separate
driver (placed in drivers/misc for no better place)
* all the ID & MISC registers are defined as sysconf
making them available for other drivers should they need
to use them (and also to the user via /sys/kernel/debug/regmap
which can be helpful in platform debugging)
Acked-by: Lee Jones <lee.jones@linaro.org>
The way the VE motherboard Device Trees were constructed
enforced naming and structure of daughterboard files. This
patch makes it possible to simply include the motherboard
description anywhere in the main Device Tree and retires
the "arm,v2m-timer" alias - any of the motherboard SP804
timers will be used instead.
Add description of all functions provided by Versatile Express
motherboard and daughterboards configuration controllers and
clock dependencies between devices.
SMSC driver requires "vdd33a" and "vddvario" regulator supplies now.
Add fixed regulator describing 3V3 power line (in both motherboard's
Device Trees and the non-DT code) and force fixed regulator config
option if regulators framework is enabled.
This patch adds support for RS1 memory map based Versatile Express
motherboard.
