[ Upstream commit bb5cce12ac717c7462217cd493ed701d12d6dbce ]
The Arm Ltd. boards were using an outdated address convention in the DT
node names, by separating the high from the low 32-bits of an address by
a comma.
Remove the comma from the node name suffix to be DT spec compliant.
Link: https://lore.kernel.org/r/20200513103016.130417-3-andre.przywara@arm.com
Signed-off-by: Andre Przywara <andre.przywara@arm.com>
Signed-off-by: Sudeep Holla <sudeep.holla@arm.com>
Commit b24413180f56 ("License cleanup: add SPDX GPL-2.0 license
identifier to files with no license") seem to have missed this
one file.
We should set up the partitions in the right way so we will find out
what is in the flash.
The ARM Firmware Suite now has its own compatible and proper device
tree bindings to trigger discovery of the flash contents, and Linux
supports handling the new type of AFS partitions.
Based on commit 7f8e78ca90e2 ("arm64: dts: juno: set the right partition
type for NOR flash")
Cc: Liviu Dudau <liviu.dudau@arm.com>
Cc: Lorenzo Pieralisi <lorenzo.pieralisi@arm.com>
Accessing the NOR flash memory from the kernel will disrupt CPU sleep/
idles states and CPU hotplugging. We need to disable this DT node by
default. Setups that want to access the flash can modify this entry to
enable the flash again but also ensuring to disable CPU idle states and
CPU hotplug.
The platform firmware assumes the flash is always in read mode while
Linux kernel driver leaves NOR flash in "read id" mode after
initialization. If it gets used actively, it can be in some other state.
So far we had not seen this issue as the NOR flash drivers in kernel
were not enabled by default. However it was enable in multi_v7 config by
Commit 5f068190cc10 ("ARM: multi_v7_defconfig: Enable support for CFI NOR FLASH")
So, let's mark the NOR flash disabled so that the platform can boot
again. This based on:
Commit 980bbff018f6 ("ARM64: juno: disable NOR flash node by default")
Vexpress motherboard MMCI requires dedicated interrupts for CMD and PIO,
which obviously should be expressed as a list. Current form uses tuple
and it works fine since interrupt-cells equal to 1.
Reported-by: Vladimir Murzin <vladimir.murzin@arm.com>
Reviewed-by: Vladimir Murzin <vladimir.murzin@arm.com>
The Versatile Express was submitted with the actual display
bridges unconnected (but defined in the device tree) and
mock "panels" encoded in the device tree node of the PL111
controller.
This doesn't even remotely describe the actual Versatile
Express hardware. Exploit the SiI9022 bridge by connecting
the PL111 pads to it, making it use EDID or fallback values
to drive the monitor.
The also has to use the reserved memory through the
CMA pool rather than by open coding a memory region and
remapping it explicitly in the driver. To achieve this,
a reserved-memory node must exist in the root of the
device tree, so we need to pull that out of the
motherboard .dtsi include files, and push it into each
top-level device tree instead.
We do the same manouver for all the Versatile Express
boards, taking into account the different location of the
video RAM depending on which chip select is used on
each platform.
This plays nicely with the new PL111 DRM driver and
follows the standard ways of assigning bridges and
memory pools for graphics.
Cc: Sudeep Holla <sudeep.holla@arm.com>
Cc: Mali DP Maintainers <malidp@foss.arm.com>
Cc: Robin Murphy <robin.murphy@arm.com>
Tested-by: Liviu Dudau <liviu.dudau@arm.com>
Commit 2cff6dba57b7 ("ARM: dts: vexpress: fix node name unit-address presence warnings")
removed the unit address as there was no associated reg property in
these sysreg nodes.
Also the latest DTC throws warnings for character '_' in the node names.
Warning (node_name_chars_strict): /sysreg@10000/sys_led: Character '_' not recommended in node name
Warning (node_name_chars_strict): /sysreg@10000/sys_mci: Character '_' not recommended in node name
Warning (node_name_chars_strict): /sysreg@10000/sys_flash: Character '_' not recommended in node name
The correct way to fix this as well as the original unit-address presence
warnings is to use the standard gpio controller binding and specify the
reg properties as per the hardware as it was before.
However note that Vexpress sysreg MFD driver will still continue to use
the hardcoded values for compatibility reasons.
Acked-by: Liviu Dudau <liviu.dudau@arm.com>
Suggested-by: Rob Herring <robh@kernel.org>
Reviewed-by: Rob Herring <robh@kernel.org>
It is a bit unorthodox to just include a file in the middle of a another
DTS file, it breaks the pattern from other device trees and also makes
it really hard to reference things across the files with phandles.
Restructure the include for the Versatile Express motherboards to happen
at the top of the file, reference the target nodes directly, and indent
the motherboard .dtsi files to reflect their actual depth in the
hierarchy.
This is a purely syntactic change that result in the same DTB files from
the DTS/DTSI files.
This patch fixes the following set of warnings on vexpress platforms:
sysreg@010000 simple-bus unit address format error, expected "10000"
sysctl@020000 simple-bus unit address format error, expected "20000"
i2c@030000 simple-bus unit address format error, expected "30000"
aaci@040000 simple-bus unit address format error, expected "40000"
mmci@050000 simple-bus unit address format error, expected "50000"
kmi@060000 simple-bus unit address format error, expected "60000"
kmi@070000 simple-bus unit address format error, expected "70000"
uart@090000 simple-bus unit address format error, expected "90000"
uart@0a0000 simple-bus unit address format error, expected "a0000"
uart@0b0000 simple-bus unit address format error, expected "b0000"
uart@0c0000 simple-bus unit address format error, expected "c0000"
wdt@0f0000 simple-bus unit address format error, expected "f0000"
Commit b993734718c0 ("scripts/dtc: Update to upstream version 53bf130b1cdd")
added warnings on node name unit-address presence/absence mismatch in
the device trees.
This patch fixes those warning on all the vexpress platforms where
unit-address is present in node name while the reg/ranges property is
not present.
The compatible string "simple-bus" is well defined in ePAPR, while
I see no documentation for the "arm,amba-bus" arnywhere in ePAPR or
Documentation/devicetree/.
DT is also used by other projects than Linux kernel. It is not a
good idea to rely on such an unofficial binding.
This commit
- replaces "arm,amba-bus" with "simple-bus"
- drops "arm,amba-bus" where it is used along with "simple-bus"
The sp810 clk driver is calling the clk consumer APIs from
clk_prepare ops to change the parent to a 1 MHz fixed rate clock
for each of the clocks that the driver provides. Use
assigned-clock-parents for this instead of doing it in the driver
to avoid using the consumer API in provider code. This also
allows us to remove the usage of clk provider APIs that take a
struct clk as an argument from the sp810 driver.
Cc: Pawel Moll <pawel.moll@arm.com>
Cc: Linus Walleij <linus.walleij@linaro.org>
Tested-by: Sudeep Holla <sudeep.holla@arm.com>
Signed-off-by: Stephen Boyd <sboyd@codeaurora.org>
... for V2M-P1 motherboard CLCD (limited to 640x480 16bpp and using
dedicated video RAM bank) and for V2P-CA9 (up to 1024x768 16bpp).
Signed-off-by: Pawel Moll <pawel.moll@arm.com>
This patch - finally, after over 6 months! :-( - addresses
Samuel's request to split the vexpress-sysreg driver into
smaller portions and define the device in a form of MFD
cells:
* LEDs code has been completely removed and replaced with
"gpio-leds" nodes in the tree (referencing dedicated
GPIO subnodes in sysreg - bindings documentation updated);
this also better fits the reality as some variants of the
motherboard don't have all the LEDs populated
* syscfg bridge code has been extracted into a separate
driver (placed in drivers/misc for no better place)
* all the ID & MISC registers are defined as sysconf
making them available for other drivers should they need
to use them (and also to the user via /sys/kernel/debug/regmap
which can be helpful in platform debugging)
Acked-by: Lee Jones <lee.jones@linaro.org>
The way the VE motherboard Device Trees were constructed
enforced naming and structure of daughterboard files. This
patch makes it possible to simply include the motherboard
description anywhere in the main Device Tree and retires
the "arm,v2m-timer" alias - any of the motherboard SP804
timers will be used instead.
Add description of all functions provided by Versatile Express
motherboard and daughterboards configuration controllers and
clock dependencies between devices.
SMSC driver requires "vdd33a" and "vddvario" regulator supplies now.
Add fixed regulator describing 3V3 power line (in both motherboard's
Device Trees and the non-DT code) and force fixed regulator config
option if regulators framework is enabled.
This patch adds support for RS1 memory map based Versatile Express
motherboard.
