Accessing the NOR flash memory from the kernel will disrupt CPU sleep/
idles states and CPU hotplugging. We need to disable this DT node by
default. Setups that want to access the flash can modify this entry to
enable the flash again but also ensuring to disable CPU idle states and
CPU hotplug.
The platform firmware assumes the flash is always in read mode while
Linux kernel driver leaves NOR flash in "read id" mode after
initialization. If it gets used actively, it can be in some other state.
So far we had not seen this issue as the NOR flash drivers in kernel
were not enabled by default. However it was enable in multi_v7 config by
Commit 5f068190cc10 ("ARM: multi_v7_defconfig: Enable support for CFI NOR FLASH")
So, let's mark the NOR flash disabled so that the platform can boot
again. This based on:
Commit 980bbff018f6 ("ARM64: juno: disable NOR flash node by default")
Cc: Liviu Dudau <liviu.dudau@arm.com>
Cc: Lorenzo Pieralisi <lorenzo.pieralisi@arm.com>
Signed-off-by: Sudeep Holla <sudeep.holla@arm.com>
CoreSight DT bindings have been updated, thus the old compatible strings
are obsolete and the drivers will report warning if DTS uses these
obsolete strings.
This patch switches to the new bindings for CoreSight dynamic funnel and
static replicator, so can dismiss warning during initialisation.
Reviewed-by: Mathieu Poirier <mathieu.poirier@linaro.org>
Acked-by: Suzuki K Poulose <suzuki.poulose@arm.com>
Signed-off-by: Leo Yan <leo.yan@linaro.org>
A CPUfreq driver, like the ARM big.LITTLE driver used on the TC2 board,
which provide the Energy Model with power cost information via the
PM_OPP of_dev_pm_opp_get_cpu_power() function, do need the
dynamic-power-coefficient (C) in the device tree.
Method used to obtain the C value:
C is computed by measuring energy (E) consumption of a frequency domain
(FD) over a 10s runtime (t) sysbench workload running at each Operating
Performance Point (OPP) affine to 1 or 2 CPUs of that FD while the other
CPUs of the system are hotplugged out.
By definition all CPUs of a FD have the the same micro-architecture. An
OPP is characterized by a certain frequency (f) and voltage (V) value.
The corresponding power values (P) are calculated by dividing the delta
of the E values between the runs with 2 and 1 CPUs by t.
With n data tuples (P, f, V), n equal to number of OPPs for this
frequency domain, we can solve C by:
P = Pstat + Pdyn
P = Pstat + CV²f
Cx = (Px - P1)/(Vx²fx - V1²f1) with x = {2, ..., n}
The C value is the arithmetic mean out of {C2, ..., Cn}.
Signed-off-by: Dietmar Eggemann <dietmar.eggemann@arm.com>
Signed-off-by: Quentin Perret <quentin.perret@arm.com>
git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-integrator into next/dt
Versatile Express DTS update for DRM:
This updates the Versatile Express family DTS files to
contain the correct and detailed information required
for the PL11x DRM driver to work properly.
* tag 'vexpress-drm-arm-soc' of git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-integrator:
ARM: dts: Modernize the Vexpress PL111 integration
The Versatile Express was submitted with the actual display
bridges unconnected (but defined in the device tree) and
mock "panels" encoded in the device tree node of the PL111
controller.
This doesn't even remotely describe the actual Versatile
Express hardware. Exploit the SiI9022 bridge by connecting
the PL111 pads to it, making it use EDID or fallback values
to drive the monitor.
The also has to use the reserved memory through the
CMA pool rather than by open coding a memory region and
remapping it explicitly in the driver. To achieve this,
a reserved-memory node must exist in the root of the
device tree, so we need to pull that out of the
motherboard .dtsi include files, and push it into each
top-level device tree instead.
We do the same manouver for all the Versatile Express
boards, taking into account the different location of the
video RAM depending on which chip select is used on
each platform.
This plays nicely with the new PL111 DRM driver and
follows the standard ways of assigning bridges and
memory pools for graphics.
Cc: Sudeep Holla <sudeep.holla@arm.com>
Cc: Mali DP Maintainers <malidp@foss.arm.com>
Cc: Robin Murphy <robin.murphy@arm.com>
Tested-by: Liviu Dudau <liviu.dudau@arm.com>
Switch to the new coresight bindings
Cc: Mathieu Poirier <mathieu.poirier@linaro.org>
Signed-off-by: Suzuki K Poulose <suzuki.poulose@arm.com>
[sudeep.holla: updated title and fixed couple of remaining dtc warnings]
The latest DTC throws warnings for character '_' in the node names.
Warning (node_name_chars_strict): /pmu_a15: Character '_' not recommended in node name
Warning (node_name_chars_strict): /pmu_a7: Character '_' not recommended in node name
The general recommendation is to use character '-' for all the node names.
This patch fixes the warnings following the recommendation.
Acked-by: Liviu Dudau <liviu.dudau@arm.com>
It is a bit unorthodox to just include a file in the middle of a another
DTS file, it breaks the pattern from other device trees and also makes
it really hard to reference things across the files with phandles.
Restructure the include for the Versatile Express motherboards to happen
at the top of the file, reference the target nodes directly, and indent
the motherboard .dtsi files to reflect their actual depth in the
hierarchy.
This is a purely syntactic change that result in the same DTB files from
the DTS/DTSI files.
Philippe Ombredanne.
How this work was done:
the use cases:
lines of source
lines).
identifiers to apply.
COPYING file license applied.
GPL-2.0 11139
the concluded license(s).
in time.
they are related.
in about 15000 files.
correct identifier.
version early this week with:
license ids and scores
generate the patches.
This patch fixes the following set of warnings on vexpress platforms:
sysreg@010000 simple-bus unit address format error, expected "10000"
sysctl@020000 simple-bus unit address format error, expected "20000"
i2c@030000 simple-bus unit address format error, expected "30000"
aaci@040000 simple-bus unit address format error, expected "40000"
mmci@050000 simple-bus unit address format error, expected "50000"
kmi@060000 simple-bus unit address format error, expected "60000"
kmi@070000 simple-bus unit address format error, expected "70000"
uart@090000 simple-bus unit address format error, expected "90000"
uart@0a0000 simple-bus unit address format error, expected "a0000"
uart@0b0000 simple-bus unit address format error, expected "b0000"
uart@0c0000 simple-bus unit address format error, expected "c0000"
wdt@0f0000 simple-bus unit address format error, expected "f0000"
The GICv2 CPU interface registers span across 8K, not 4K as indicated in
the DT. Only the GICC_DIR register is located after the initial 4K
boundary, leaving a functional system but without support for separately
EOI'ing and deactivating interrupts.
After this change the system supports split priority drop and interrupt
deactivation.
Acked-by: Marc Zyngier <marc.zyngier@arm.com>
Signed-off-by: Christoffer Dall <christoffer.dall@linaro.org>
[sudeep.holla@arm.com: included same fix for tc1 platform too]
Add TC2 cpu capacity information.
Cc: Rob Herring <robh+dt@kernel.org>
Cc: Pawel Moll <pawel.moll@arm.com>
Cc: Mark Rutland <mark.rutland@arm.com>
Cc: Ian Campbell <ijc+devicetree@hellion.org.uk>
Cc: Kumar Gala <galak@codeaurora.org>
Cc: devicetree@vger.kernel.org
Signed-off-by: Juri Lelli <juri.lelli@arm.com>
The VExpress development platform has an external expansion bus which
can be used for additional hardware (e.g. LogicTile Express daughter
boards).
Add this bus to the VExpress CoreTile device-trees.The bus is described
for a CoreTile occupying site 1.
Acked-by: Liviu Dudau <Liviu.Dudau@arm.com>
Signed-off-by: Brian Starkey <brian.starkey@arm.com>
Commit b993734718c0 ("scripts/dtc: Update to upstream version 53bf130b1cdd")
added warnings on node name unit-address presence/absence mismatch in
the device trees.
This patch fixes those warning on all the vexpress platforms where
unit-address is present in node name while the reg/ranges property is
not present.
The CCI device node was added to vexpress CA15_A7(i.e. TC2) much before
the CCI PMU support and binding was added. This patch adds the missing
PMU node so that CCI PMUs can be used on TC2.
Acked-by: Punit Agrawal <punit.agrawal@arm.com>
Signed-off-by: Kevin Hilman <khilman@linaro.org>
The dts for the CoreTile Express A15x2 A7x3 (TC2) only describes the
PMUs of the Cortex-A15 CPUs, and not the Cortex-A7 CPUs.
Now that we have a mechanism for describing disparate PMUs and their
interrupts in device tree, this patch makes use of these to describe the
PMUs for all CPUs in the system. For consistency, the existing A15 PMU
interrupt-affinity property is reflowed across two lines.
Signed-off-by: Mark Rutland <mark.rutland@arm.com>
Acked-by: Will Deacon <will.deacon@arm.com>
Acked-by: Sudeep Holla <sudeep.holla@arm.com>
Commit 9fd85eb502a7 ("ARM: pmu: add support for interrupt-affinity
property") added an optional "interrupt-affinity" property, to specify
the CPU affinity for each SPI listed in the interrupts property.
Without this property, we get this boot warning:
CPU PMU: Failed to parse <no-node>/interrupt-affinity[0]
This patch adds interrupt-affinity to the PMU node in the
vexpress-ca15_a7(a.k.a TC2) device tree.
The coresight-default-sink configuration option has been
removed from the framework. As such remove it from DT and bindings.
Signed-off-by: Kaixu Xia <xiakaixu@huawei.com>
Signed-off-by: Mathieu Poirier <mathieu.poirier@linaro.org>
Support for the 2 PTMs, 3 ETMs, funnel, TPIU and replicator
connected to the ETB are included. Proper handling of the
ITM and the replicator linked to it along with the CTIs
and SWO are not included.
With the introduction of DT based idle states, CPUidle drivers for ARM
can now initialize idle states data through properties in the device tree.
This patch adds code to the big.LITTLE CPUidle driver to dynamically
initialize idle states data through the updated device tree source file.
Cc: Chander Kashyap <k.chander@samsung.com>
Acked-by: Catalin Marinas <catalin.marinas@arm.com>
Acked-by: Daniel Lezcano <daniel.lezcano@linaro.org>
Signed-off-by: Lorenzo Pieralisi <lorenzo.pieralisi@arm.com>
Signed-off-by: Daniel Lezcano <daniel.lezcano@linaro.org>
Components of the Versatile Express platform (configuration
microcontrollers on motherboard and daughterboards in particular)
talk to each other over a custom configuration bus. They
provide miscellaneous functions (from clock generator control
to energy sensors) which are represented as platform devices
(and Device Tree nodes). The transactions on the bus can
be generated by different "bridges" in the system, some
of which are universal for the whole platform (for the price
of high transfer latencies), others restricted to a subsystem
(but much faster).
Until now drivers for such functions were using custom "func"
API, which is being replaced in this patch by regmap calls.
This required:
* a rework (and move to drivers/bus directory, as suggested
by Samuel and Arnd) of the config bus core, which is much
simpler now and uses device model infrastructure (class)
to keep track of the bridges; non-DT case (soon to be
retired anyway) is simply covered by a special device
registration function
* the new config-bus driver also takes over device population,
so there is no need for special matching table for
of_platform_populate nor "simple-bus" hack in the arm64
model dtsi file (relevant bindings documentation has
been updated); this allows all the vexpress devices
fit into normal device model, making it possible
to remove plenty of early inits and other hacks in
the near future
* adaptation of the syscfg bridge implementation in the
sysreg driver, again making it much simpler; there is
a special case of the "energy" function spanning two
registers, where they should be both defined in the tree
now, but backward compatibility is maintained in the code
* modification of the relevant drivers:
* hwmon - just a straight-forward API change
* power/reset driver - API change
* regulator - API change plus error handling
simplification
* osc clock driver - this one required larger rework
in order to turn in into a standard platform driver
Signed-off-by: Pawel Moll <pawel.moll@arm.com>
Acked-by: Mark Brown <broonie@linaro.org>
Acked-by: Lee Jones <lee.jones@linaro.org>
Acked-by: Guenter Roeck <linux@roeck-us.net>
Acked-by: Mike Turquette <mturquette@linaro.org>
Pull ARM SoC late changes from Kevin Hilman:
"These are changes that arrived a little late before the merge window,
or had dependencies on previous branches.
Highlights:
- ux500: misc. cleanup, fixup I2C devices
- exynos: DT updates for RTC; PM updates
- at91: DT updates for NAND; new platforms added to generic defconfig
- sunxi: DT updates: cubieboard2, pinctrl driver, gated clocks
- highbank: LPAE fixes, select necessary ARM errata
- omap: PM fixes and improvements; OMAP5 mailbox support
- omap: basic support for new DRA7xx SoCs"
* tag 'late-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (60 commits)
ARM: dts: vexpress: Add CCI node to TC2 device-tree
ARM: EXYNOS: Skip C1 cpuidle state for exynos5440
ARM: EXYNOS: always enable PM domains support for EXYNOS4X12
ARM: highbank: clean-up some unused includes
ARM: sun7i: Enable the A20 clocks in the DTSI
ARM: sun6i: Enable clock support in the DTSI
ARM: sun5i: dt: Use the A10s gates in the DTSI
ARM: at91: at91_dt_defconfig: enable rm9200 support
ARM: dts: add ADC device tree node for exynos5420/5250
ARM: dts: Add RTC DT node to Exynos5420 SoC
ARM: dts: Update the "status" property of RTC DT node for Exynos5250 SoC
ARM: dts: Fix the RTC DT node name for Exynos5250
irqchip: mmp: avoid to include irqs head file
ARM: mmp: avoid to include head file in mach-mmp
irqchip: mmp: support irqchip
irqchip: move mmp irq driver
ARM: OMAP: AM33xx: clock: Add RNG clock data
ARM: OMAP: TI81XX: add always-on powerdomain for TI81XX
ARM: OMAP4: clock: Lock PLLs in the right sequence
ARM: OMAP: AM33XX: hwmod: Add hwmod data for debugSS
The Versatile Express V2P-CA15_A7 (aka TC2) has a CCI-400 which is
needed to get Multi-Cluster Power Management (MCPM) working.
Signed-off-by: Jon Medhurst <tixy@linaro.org>
Acked-by: Pawel Moll <pawel.moll@arm.com>
Acked-by: Lorenzo Pieralisi <lorenzo.pieralisi@arm.com>
SCC (Serial Configuration Controller) is used to set initial
conditions for the test chip (TC2). Its registers are also mapped
in normal address space and used to obtain runtime information
and for power management.
The ARM perf core code used to rely on the pmu node being
compatible with "arm,cortex-a9-pmu", even when the PMUs
of the different Cortex-A processors are not really
compatible... This is no longer required and actually
became harmful, so remove all the offending values
from Versatile Express DTS files.
As the wdt nodes have the gic as their interrupt-parent, their
interrupts property should be 3 cells in format described in the gic
devicetree binding document.
This patch fixes the interrupts property in the wdt nodes to be in the
correct format.
As the kernel is able to cope with multiple clusters,
uncomment the A7 cores in the Device Tree for V2P-CA15_A7
tile, making all 5 cores available to the user.
The way the VE motherboard Device Trees were constructed
enforced naming and structure of daughterboard files. This
patch makes it possible to simply include the motherboard
description anywhere in the main Device Tree and retires
the "arm,v2m-timer" alias - any of the motherboard SP804
timers will be used instead.
Add description of all functions provided by Versatile Express
motherboard and daughterboards configuration controllers and
clock dependencies between devices.
This patch adds Device Tree file for the CoreTile Express
A15x2 A7x3 (V2P-CA15_CA7).
Note that the A7 cpu nodes are commented out, as the
big.LITTLE-relevant patches are not upstreamed yet. Till
this time one can use the board with two A15 cores only,
keeping the A7s in reset by adding the following setting
to the board.txt file in Versatile Express configuration
tree:
SCC: 0x018 0x00001FFF
