The license text has been mangled at some point then copy pasted across
multiple files. Restore it to what it should be.
Note that this is not intended as a license change.
Acked-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de>
Acked-by: Afzal Mohammed <afzal.mohd.ma@gmail.com>
Acked-by: Michael Trimarchi <michael@amarulasolutions.com>
Acked-by: Stefan Agner <stefan@agner.ch>
Signed-off-by: Alexandre Belloni <alexandre.belloni@free-electrons.com>
Enable DMA for DSPI on Vybrid.
Signed-off-by: Sanchayan Maity <maitysanchayan@gmail.com>
Pull ARM SoC late DT updates from Arnd Bergmann:
"This is a collection of a few late fixes and other misc stuff that had
dependencies on things being merged from other trees.
The Renesas R-Car power domain handling, and the Nvidia Tegra USB
support both hand notable changes that required changing the DT
binding in a way that only provides compatibility with old DT blobs on
new kernels but not vice versa. As a consequence, the DT changes are
based on top of the driver changes and are now in this branch.
For NXP i.MX and Samsung Exynos, the changes in here depend on other
changes that got merged through the clk maintainer tree"
* tag 'armsoc-late' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (35 commits)
ARM: dts: exynos: Add support of Bus frequency using VDD_INT for exynos5422-odroidxu3
ARM: dts: exynos: Add bus nodes using VDD_INT for Exynos542x SoC
ARM: dts: exynos: Add NoC Probe dt node for Exynos542x SoC
ARM: dts: exynos: Add support of bus frequency for exynos4412-trats/odroidu3
ARM: dts: exynos: Expand the voltage range of buck1/3 regulator for exynos4412-odroidu3
ARM: dts: exynos: Add support of bus frequency using VDD_INT for exynos3250-rinato
ARM: dts: exynos: Add exynos4412-ppmu-common dtsi to delete duplicate PPMU nodes
ARM: dts: exynos: Add bus nodes using VDD_MIF for Exynos4210
ARM: dts: exynos: Add bus nodes using VDD_INT for Exynos4x12
ARM: dts: exynos: Add bus nodes using VDD_MIF for Exynos4x12
ARM: dts: exynos: Add bus nodes using VDD_INT for Exynos3250
ARM: dts: exynos: Add DMC bus frequency for exynos3250-rinato/monk
ARM: dts: exynos: Add DMC bus node for Exynos3250
ARM: tegra: Enable XUSB on Nyan
ARM: tegra: Enable XUSB on Jetson TK1
ARM: tegra: Enable XUSB on Venice2
ARM: tegra: Add Tegra124 XUSB controller
ARM: tegra: Move Tegra124 to the new XUSB pad controller binding
ARM: dts: r8a7794: Use SYSC "always-on" PM Domain
ARM: dts: r8a7793: Use SYSC "always-on" PM Domain
The NAND flash memory populated on Colibri VF61 allows faster NAND
timings than the flash memory on VF50. Additionally, due to divider
limitations, VF61 did clock the flash even slower than VF50. Assign
the NFC clock in the module specific device trees vf500-colibri.dtsi
and vf610-colibri.dtsi respectively.
This increases raw read speed on Colibri VF61 by about 20%.
Signed-off-by: Stefan Agner <stefan@agner.ch>
The Vybrid based Colibri modules provide a on-module PHY which is
connected to the second FEC instance FEC1. Since the on-module
Ethernet port is considered as primary ethernet interface, alias
fec1 as ethernet0. This also makes sure that the first MAC address
provided by the boot loader gets assigned to the FEC instance used
for the on-module PHY.
Enable dcu node which is used by the DCU DRM driver. Assign the 5.7"
EDT panel with VGA resolution which Toradex sells often with the
evaluation board.
Add pinmux for UART_A RTS, CTS pin's.
Signed-off-by: Bhuvanchandra DV <bhuvanchandra.dv@toradex.com>
The Colibri standard does not define a pin for SD-Card write-
protection. Use the disable-wp property to indicate that there
is no physical WP line present.
Colibri modules need to be powered using the power pins 3V3 and
AVDD_AUDIO. Add fixed regulators which represent this power rails.
Potentially, those power rails could be switched on a carrier
board. A carrier board device tree could add a own regulator with
a GPIO, and reference that regulator in a vin-supply property of
those new module level system regulators.
Assign Ethernet clock parents explicitly. The Colibri VF61
uses the 50MHz Ethernet clock provided by PLL5.
The Vybrid SoC has two ethernet interfaces (fec0 and fec1) which
use the same clock source (VF610_CLK_ENET). Therefore this parent
configuration affects multiple consumer devices and need to be
specified in the clock provider node.
GPLv2-only devicetrees make reuse difficult for software components
licensed under a different license.
The consensus is that a GPL/X11 dual-license should allow all necessary
uses, so relicense the vf*colibri* files to this combination.
CCs were acquired using:
git shortlog -sne --no-merges arch/arm/boot/dts/vf*colibri*
Acked-by: Cory Tusar <cory.tusar@pid1solutions.com>
Acked-by: Sanchayan Maity <maitysanchayan@gmail.com>
Acked-by: Bhuvanchandra DV <bhuvanchandra.dv@toradex.com>
Use pwm-backlight driver 'enable-gpios' property for backlight on/off
control.
Add Colibri standard pinmux for FlexCAN controller instances. CAN
is not a standard Colibri feature, but the datasheet predefines
pins which provide CAN (compatible across some modules). Hence,
add the pinmux on module level.
Enable NAND access by adding pinmux and NAND flash controller node
to device tree. The NAND chips currently used on the Colibri VF61
requires 8-bit ECC per 512 byte page, hence specify 32-bit ECC
strength per 2k page size.
Reviewed-by: Brian Norris <computersforpeace@gmail.com>
This commit includes a minor nomenclature fixup for boards based on the
Freescale VF610 SoC and which make use of the alternate "RMII1_RXD1"
functionality for pin PTC12. This brings the macro name in-line with
both the datasheet and other similar macros.
Signed-off-by: Cory Tusar <cory.tusar@pid1solutions.com>
MCP2515 CAN controller is available on Colibri Evaluation board.
Hence enable MCP2515 CAN.
On Vybrid, all peripherals are numbered starting with zero,
including the GPIO and PORT module. However, the labels of the
corresponding device tree nodes start with one, which is confusing.
Fix that by renaming the labels of the gpio nodes in the device
tree.
On the Colibri module, the RMII clock for the Ethernet PHY is
generated by the SoC. This patch adds that missing pin to the
pinctrl of FEC1. Because the boot loader initializes this pin,
ethernet worked even without this pin so far.
Add structure of USB supply logic. The USB hosts power enable
regulator is needed to control VBUS supply on the Colibri carrier
board.
Since restructuring of the device tree files, the USB misc/phy
nodes are disabled by default. Hence we need to enable those
explicitly when USB is used.
Use GPIO support by adding SD card detection configuration and
GPIO pinmux for Colibri's standard GPIO pins. Attach the GPIO
pins to the iomuxc node to get the GPIO pin settings applied.
Add Colibri VF50 device tree files vf500-colibri.dtsi and
vf500-colibri-eval-v3.dts, in line with the Colibri VF61 device tree
files. However, to minimize dupplication we also add vf-colibri.dtsi
and vf-colibri-eval-v3.dtsi which contain the common device tree
nodes.
