path: root/arch/arm/boot/dts/vf610-cosmic.dts
2019-05-30treewide: Replace GPLv2 boilerplate/reference with SPDX - rule 152Thomas Gleixner
Based on 1 normalized pattern(s): this program is free software you can redistribute it and or modify it under the terms of the gnu general public license as published by the free software foundation either version 2 of the license or at your option any later version extracted by the scancode license scanner the SPDX license identifier GPL-2.0-or-later has been chosen to replace the boilerplate/reference in 3029 file(s). Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Reviewed-by: Allison Randal <allison@lohutok.net> Cc: linux-spdx@vger.kernel.org Link: https://lkml.kernel.org/r/20190527070032.746973796@linutronix.de Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-12-10ARM: dts: vf: Fix memory node duplicationFabio Estevam
Boards based on vf500/vf600 have duplicate memory nodes: - One coming from the board dts file: memory@ - One coming from the vf500.dtsi/vf610m4.dtsi files. Fix the duplication by removing the memory node from the dtsi file and by adding 'device_type = "memory";' in the board dts. Reported-by: Rob Herring <robh@kernel.org> Signed-off-by: Fabio Estevam <festevam@gmail.com> Reviewed-by: Stefan Agner <stefan@agner.ch> Signed-off-by: Shawn Guo <shawnguo@kernel.org>
2018-03-08ARM: dts: vf: Add memory node unit nameFabio Estevam
Include memory node unit name in order to fix the following W=1 warnings: Warning (unit_address_vs_reg): Node /memory has a reg or ranges property, but no unit name Signed-off-by: Fabio Estevam <fabio.estevam@nxp.com> Reviewed-by: Stefan Agner <stefan@agner.ch> Signed-off-by: Shawn Guo <shawnguo@kernel.org>
2015-06-03ARM: dts: vf610: Nomenclature fixup for PTC12 pin used in RMII mode.Cory Tusar
This commit includes a minor nomenclature fixup for boards based on the Freescale VF610 SoC and which make use of the alternate "RMII1_RXD1" functionality for pin PTC12. This brings the macro name in-line with both the datasheet and other similar macros. Signed-off-by: Cory Tusar <cory.tusar@pid1solutions.com> Acked-by: Stefan Agner <stefan@agner.ch> Signed-off-by: Shawn Guo <shawn.guo@linaro.org>
2014-12-09Merge tag 'dt-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull ARM SoC DT updates from Arnd Bergmann: "The DT branch adds a lot of new stuff for additional SoC and board support. The branch is the largest one and contains 513 out of the total 972 non-merge arm-soc changesets for 3.19. Most of the changes are about enabling additional on-chip devices for existing machines, but there are also an unusual number of new SoC types being added this time: - AMLogic Meson8 - ARM Realview in DT mode - Allwinner A80 - Broadcom BCM47081 - Broadcom Cygnus - Freescale LS1021A - Freescale Vybrid 500 series - Mediatek MT6592, MT8127, MT8135 - STMicroelectronics STiH410 - Samsung Exynos4415 The level of support for the above differs widely, some are just stubs with nothing more than CPU, memory and a UART, but others are fairly complete. As usual, these get extended over time. There are also many new boards getting added, this is the list of model strings that are showing up in new dts files: - ARM RealView PB1176 - Altera SOCFPGA Arria 10 - Asus RT-N18U (BCM47081) - Buffalo WZR-1750DHP (BCM4708) - Buffalo WZR-600DHP2 (BCM47081) - Cygnus Enterprise Phone (BCM911360_ENTPHN) - D-Link DIR-665 - Google Spring - IGEP COM MODULE Rev. G (TI OMAP AM/DM37x) - IGEPv2 Rev. F (TI OMAP AM/DM37x) - LS1021A QDS Board - LS1021A TWR Board - LeMaker Banana Pi - MarsBoard RK3066 - MediaTek MT8127 Moose Board - MediaTek MT8135 evaluation board - Mele M3 - Merrii A80 Optimus Board - Netgear R6300 V2 (BCM4708) - Nomadik STN8815NHK - NovaTech OrionLXm - Olimex A20-OLinuXino-LIME2 - Raspberry Pi Model B+ - STiH410 B2120 - Samsung Monk board - Samsung Rinato board - Synology DS213j - Synology DS414 - TBS2910 Matrix ARM mini PC - TI AM5728 BeagleBoard-X15 - Toradex Colibri VF50 on Colibri Evaluation Board - Zynq ZYBO Development Board Other notable changes include: - exynos: cleanup of existing dts files - mvebu: improved pinctrl support for Armada 370/XP - nomadik: restructuring dts files - omap: added CAN bus support - shmobile: added clock support for some SoCs - shmobile: added sound support for some SoCs - sirf: reset controller support - sunxi: continuing the relicensing under dual GPL/MIT - sunxi: lots of new on-chip device support - sunxi: working simplefb support (long awaited) - various: provide stdout-path property for earlycon" * tag 'dt-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (510 commits) ARM: dts: rk3288: add arm,cpu-registers-not-fw-configured Revert "ARM: dts: rockchip: temporarily disable smp on rk3288" ARM: BCM5301X: Add DT for Buffalo WZR-600DHP2 ARM: BCM5301X: Add DT for Asus RT-N18U ARM: BCM5301X: Add DT for Buffalo WZR-1750DHP ARM: BCM5301X: Add DT for Netgear R6300 V2 ARM: BCM5301X: Add buttons for Netgear R6250 ARM: dts: rockchip: Add input voltage supply regulators in pmic for Marsboard ARM: BCM5301X: Add IRQs to Broadcom's bus-axi in DTS file arm: dts: zynq: Add Digilent ZYBO board arm: dts: zynq: Move crystal freq. to board level doc: dt: vendor-prefixes: Add Digilent Inc Documentation: devicetree: Fix Xilinx VDMA specification ARM: dts: rockchip: set FIFO size for SDMMC, SDIO and EMMC on rk3066 and rk3188 ARM: dts: rockchip: add label property for leds on Radxa Rock ARM: BCM5301X: Add LEDs for Netgear R6250 V1 ARM: BCM5301X: Add Broadcom's bus-axi to the DTS file ARM: dts: add sysreg phandle to i2c device nodes for exynos ARM: dts: Remove unused bootargs from exynos3250-rinato ARM: dts: add board dts file for Exynos3250-based Monk board ...
2014-11-23ARM: dts: vf610: assign oscillator to clock moduleStefan Agner
The clock controller module (CCM) has several clock inputs, which are connected to external crystal oscillators. To reflect this, assign these fixed clocks to the CCM node directly. This especially resolves initialization order dependencies we had with the earlier initialization code: When resolving of the fixed clocks failed in clk-vf610, the code created fixed clocks with a rate of 0. Signed-off-by: Stefan Agner <stefan@agner.ch> Signed-off-by: Shawn Guo <shawn.guo@linaro.org>
2014-11-05ARM: dts: vf610: add SD node to cosmic dtsOlof Johansson
Driver has been there since a while back, but the dts never seems to have been updated with the node (nor pinctrl). Do so now. Cc: Matt Porter <mporter@linaro.org> Acked-by: Shawn Guo <shawn.guo@linaro.org> Acked-by: Stefan Agner <stefan@agner.ch> Signed-off-by: Olof Johansson <olof@lixom.net>
2014-02-09ARM: dts: vf610: make pinctrl nodes board specificShawn Guo
Currently, all pinctrl setting nodes are defined in <soc>.dtsi, so that boards that share the same pinctrl setting do not have to define it time and time again in <board>.dts. However, along with the devices and use cases being added continuously, the pinctrl setting nodes under iomuxc becomes more than expected. This bloats device tree blob for particular board unnecessarily since only a small subset of those pinctrl setting nodes will be used by the board. It impacts not only the DTB file size but also the run-time device tree lookup efficiency. The patch moves all the pinctrl data into individual boards as needed. With the changes, the pinctrl setting nodes becomes local to particular board, and it makes no sense to continue numbering the setting for given peripheral. Thus, all the pinctrl phandler name gets updated to have only peripheral name in there. Signed-off-by: Shawn Guo <shawn.guo@linaro.org> Acked-by: Fugang Duan <B38611@freescale.com>
2013-09-26ARM: dts: add initial VF610 Cosmic/Cosmic+ board supportMatt Porter
Add initial PHYTEC VF610 Cosmic/Cosmic+ board support with UART and FEC enabled. Signed-off-by: Matt Porter <matt.porter@linaro.org> Signed-off-by: Shawn Guo <shawn.guo@linaro.org>
