path: root/arch/arm/boot/dts/vf610m4-colibri.dts
2017-01-10ARM: dts: imx/vf: Correct license textAlexandre Belloni
The license text has been mangled at some point then copy pasted across multiple files. Restore it to what it should be. Note that this is not intended as a license change. Reviewed-by: Heiko Schocher <hs@denx.de> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> Acked-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de> Acked-by: Afzal Mohammed <afzal.mohd.ma@gmail.com> Acked-by: Michael Trimarchi <michael@amarulasolutions.com> Acked-by: Stefan Agner <stefan@agner.ch> Signed-off-by: Alexandre Belloni <alexandre.belloni@free-electrons.com> Signed-off-by: Shawn Guo <shawnguo@kernel.org>
2015-05-20ARM: dts: add support for Vybrid running on Cortex-M4Stefan Agner
This adds an initial device tree to run Linux on the Cortex-M4 on the Vybrid based Colibri VF61 module. Signed-off-by: Stefan Agner <stefan@agner.ch> Signed-off-by: Arnd Bergmann <arnd@arndb.de>
