According to datasheet, the registers space of SDHC controller is 1Kb,
not '0x1000', the correct value should be '0x400'. Bracket interrupt
numbers individually per recommendations.
Signed-off-by: Roman Volkov <rvolkov@v1ros.org>
Add support for the ARM, AHB, APB and DDR clocks found on the
WM8505, WM8650, WM8750 and WM8850 SoCs.
These clocks are gateable, but the enable part of the clock definition
is left out as there are no users for these clocks, and we don't want
them being disabled at boot, but it does provide users the ability to
check the current rate of these clocks.
Signed-off-by: Tony Prisk <linux@prisktech.co.nz>
Add the missing devicetree nodes for PLL's found on the WM8505, WM8650
and WM8850 SoCs.
Missing aliases for uarts on vt8500, wm8505, wm8650 added.
Nodes incorrectly labelled uart@.., changed to serial@... on all SoCs.
Set each uarts default status = "disabled" as they generally don't exist.
For each board file, we only need to enable uart0 as no other uarts are
physically present on any of these boards.
vt8500, wm8650 and wm8850 have no cpu node specified.
wm8505 has a cpu node which contains an invalid compatible string, and
is missing the other required properties.
Pull ARM SoC driver changes from Olof Johansson:
"This is a rather large set of patches for device drivers that for one
reason or another the subsystem maintainer preferred to get merged
through the arm-soc tree. There are both new drivers as well as
existing drivers that are getting converted from platform-specific
code into standalone drivers using the appropriate subsystem specific
interfaces.
In particular, we can now have pinctrl, clk, clksource and irqchip
drivers in one file per driver, without the need to call into platform
specific interface, or to get called from platform specific code, as
long as all information about the hardware is provided through a
device tree.
Most of the drivers we touch this time are for clocksource. Since now
most of them are part of drivers/clocksource, I expect that we won't
have to touch these again from arm-soc and can let the clocksource
maintainers take care of these in the future.
Another larger part of this series is specific to the exynos platform,
which is seeing some significant effort in upstreaming and
modernization of its device drivers this time around, which
unfortunately is also the cause for the churn and a lot of the merge
conflicts.
There is one new subsystem that gets merged as part of this series:
the reset controller interface, which is a very simple interface for
taking devices on the SoC out of reset or back into reset. Patches to
use this interface on i.MX follow later in this merge window, and we
are going to have other platforms (at least tegra and sirf) get
converted in 3.11. This will let us get rid of platform specific
callbacks in a number of platform independent device drivers."
* tag 'drivers-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (256 commits)
irqchip: s3c24xx: add missing __init annotations
ARM: dts: Disable the RTC by default on exynos5
clk: exynos5250: Fix parent clock for sclk_mmc{0,1,2,3}
ARM: exynos: restore mach/regs-clock.h for exynos5
clocksource: exynos_mct: fix build error on non-DT
pinctrl: vt8500: wmt: Fix checking return value of pinctrl_register()
irqchip: vt8500: Convert arch-vt8500 to new irqchip infrastructure
reset: NULL deref on allocation failure
reset: Add reset controller API
dt: describe base reset signal binding
ARM: EXYNOS: Add arm-pmu DT binding for exynos421x
ARM: EXYNOS: Add arm-pmu DT binding for exynos5250
ARM: EXYNOS: Enable PMUs for exynos4
irqchip: exynos-combiner: Correct combined IRQs for exynos4
irqchip: exynos-combiner: Add set_irq_affinity function for combiner_irq
ARM: EXYNOS: fix compilation error introduced due to common clock migration
clk: exynos5250: Fix divider values for sclk_mmc{0,1,2,3}
clk: exynos4: export clocks required for fimc-is
clk: samsung: Fix compilation error
clk: tegra: fix enum tegra114_clk to match binding
Pull ARM SoC device-tree updates from Olof Johansson:
"Part 1 of device-tree updates for 3.10. The bulk of the churn in this
branch is due to i.MX moving from C-defined pin control over to device
tree, which is a one-time conversion that will allow greater
flexibility down the road.
Besides that, there's PCI-e bindings for Marvell mvebu platforms and a
handful of cleanups to tegra due to the new include file functionality
of the device tree compiler"
* tag 'dt-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (113 commits)
arm: mvebu: PCIe Device Tree informations for Armada XP GP
arm: mvebu: PCIe Device Tree informations for Armada 370 DB
arm: mvebu: PCIe Device Tree informations for Armada 370 Mirabox
arm: mvebu: PCIe Device Tree informations for Armada XP DB
arm: mvebu: PCIe Device Tree informations for OpenBlocks AX3-4
arm: mvebu: add PCIe Device Tree informations for Armada XP
arm: mvebu: add PCIe Device Tree informations for Armada 370
ARM: sunxi: unify osc24M_fixed and osc24M
arm: vt8500: Add SDHC support to WM8505 DT
ARM: dts: Add a 64 bits version of the skeleton device tree
ARM: mvebu: Add Device Bus and CFI flash memory support to defconfig
ARM: mvebu: Add support for NOR flash device on Openblocks AX3 board
ARM: mvebu: Add support for NOR flash device on Armada XP-GP board
ARM: mvebu: Add Device Bus support for Armada 370/XP SoC
ARM: dts: imx6dl-wandboard: Add USB Host support
ARM: dts: imx51 cpu node
ARM: dts: Add missing imx27-phytec-phycore dtb target
ARM: dts: Add NFC support for i.MX27 Phytec PCM038 module
ARM: i.MX51: Add PATA support
ARM: dts: Add initial support for Wandboard Dual-Lite
This patch adds the required node for the SDHC controller on WM8505 SoCs.
Now that a display timing binding is available, convert our almost identical
binding to use the standard binding.
This patch converts the vt8500 and wm8505 framebuffer drivers and
associated dts/dtsi files to use the standard binding as defined in
bindings/video/display-timing.txt.
There are two side-effects of making this conversion:
1) The fb node should now be in the board file, rather than the soc file as
the display-timing node is a child of the fb node.
2) We still require a bits per pixel property to initialize the framebuffer
for the different lcd panels. Rather than including this as part of the
display timing, it is moved into the framebuffer node.
I have also taken the opportunity to alphabetise the includes of each
driver to avoid double-ups.
Signed-off-by: Tomi Valkeinen <tomi.valkeinen@ti.com>
Remove the gpio related devicetree nodes as these are no longer required
with the move to a combined pinctrl/gpio driver.
This patch adds pinctrl nodes to the VIA VT8500 and Wondermedia SoC dtsi
files to support the pinctrl driver.
UART modules on Wondermedia SoCs are connected via a gated clock
source, rather than directly to the 24Mhz reference clock. While
uboot enables UART0 for debugging, other UART ports are unavailable
until the clock is enabled.
This patch checks that a valid clock is actually passed from devicetree,
enables the clock in probe. This change removes the fallback when a
clock was not specified as it doesn't apply any longer (and would only
work if the UART clock was already enabled).
DTSI files are updated for VT8500, WM8505 and WM8650.
EHCI and UHCI devices in wm8505.dtsi should use IRQ 1 & 0
respectively - not 43 as used on newer models.
Add device tree files for VT8500, WM8505 and WM8650 SoC's and
reference boards.
