path: root/arch/arm/boot/dts/wm8850.dtsi
2014-04-23net: via-rhine: add OF bus bindingAlexey Charkov
This should make the driver usable with VIA/WonderMedia ARM-based Systems-on-Chip integrated Rhine III adapters. Note that these are always in MMIO mode, and don't have any known EEPROM. Signed-off-by: Alexey Charkov <alchark@gmail.com> Acked-by: Rob Herring <robh@kernel.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-06-04dts: vt8500: Correct reference clock on WM8850 SoCsTony Prisk
WM8850 SoCs use a 24Mhz reference clock for the PLLs but the SoC file currently parents all PLLs to the 25Mhz reference clock. This patch corrects the PLL parent clock references. Signed-off-by: Tony Prisk <linux@prisktech.co.nz>
2013-05-12dts: vt8500: Add ARM, AHB, APB and DDR clock nodes to SoC filesTony Prisk
Add support for the ARM, AHB, APB and DDR clocks found on the WM8505, WM8650, WM8750 and WM8850 SoCs. These clocks are gateable, but the enable part of the clock definition is left out as there are no users for these clocks, and we don't want them being disabled at boot, but it does provide users the ability to check the current rate of these clocks. Signed-off-by: Tony Prisk <linux@prisktech.co.nz>
2013-05-12dts: vt8500: Populate missing PLL nodesTony Prisk
Add the missing devicetree nodes for PLL's found on the WM8505, WM8650 and WM8850 SoCs. Signed-off-by: Tony Prisk <linux@prisktech.co.nz>
2013-05-12dts: clk: vt8500: Update SoC dtsi to use WM8850 PLLTony Prisk
clocks Change the WM8850 SoC dtsi to use the new wm8850 specific PLL clock binding. Previously, the WM8850 used the wm8750 pll clock which is actually different to the wm8850 pll clock. Signed-off-by: Tony Prisk <linux@prisktech.co.nz>
2013-05-12dts: vt8500: Update serial nodes and disable by default in SoC filesTony Prisk
Missing aliases for uarts on vt8500, wm8505, wm8650 added. Nodes incorrectly labelled uart@.., changed to serial@... on all SoCs. Set each uarts default status = "disabled" as they generally don't exist. For each board file, we only need to enable uart0 as no other uarts are physically present on any of these boards. Signed-off-by: Tony Prisk <linux@prisktech.co.nz>
2013-05-12dts: vt8500: Fix invalid/missing cpu nodes for soc files.Tony Prisk
vt8500, wm8650 and wm8850 have no cpu node specified. wm8505 has a cpu node which contains an invalid compatible string, and is missing the other required properties. Signed-off-by: Tony Prisk <linux@prisktech.co.nz>
2013-05-04Merge tag 'drivers-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull ARM SoC driver changes from Olof Johansson: "This is a rather large set of patches for device drivers that for one reason or another the subsystem maintainer preferred to get merged through the arm-soc tree. There are both new drivers as well as existing drivers that are getting converted from platform-specific code into standalone drivers using the appropriate subsystem specific interfaces. In particular, we can now have pinctrl, clk, clksource and irqchip drivers in one file per driver, without the need to call into platform specific interface, or to get called from platform specific code, as long as all information about the hardware is provided through a device tree. Most of the drivers we touch this time are for clocksource. Since now most of them are part of drivers/clocksource, I expect that we won't have to touch these again from arm-soc and can let the clocksource maintainers take care of these in the future. Another larger part of this series is specific to the exynos platform, which is seeing some significant effort in upstreaming and modernization of its device drivers this time around, which unfortunately is also the cause for the churn and a lot of the merge conflicts. There is one new subsystem that gets merged as part of this series: the reset controller interface, which is a very simple interface for taking devices on the SoC out of reset or back into reset. Patches to use this interface on i.MX follow later in this merge window, and we are going to have other platforms (at least tegra and sirf) get converted in 3.11. This will let us get rid of platform specific callbacks in a number of platform independent device drivers." * tag 'drivers-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (256 commits) irqchip: s3c24xx: add missing __init annotations ARM: dts: Disable the RTC by default on exynos5 clk: exynos5250: Fix parent clock for sclk_mmc{0,1,2,3} ARM: exynos: restore mach/regs-clock.h for exynos5 clocksource: exynos_mct: fix build error on non-DT pinctrl: vt8500: wmt: Fix checking return value of pinctrl_register() irqchip: vt8500: Convert arch-vt8500 to new irqchip infrastructure reset: NULL deref on allocation failure reset: Add reset controller API dt: describe base reset signal binding ARM: EXYNOS: Add arm-pmu DT binding for exynos421x ARM: EXYNOS: Add arm-pmu DT binding for exynos5250 ARM: EXYNOS: Enable PMUs for exynos4 irqchip: exynos-combiner: Correct combined IRQs for exynos4 irqchip: exynos-combiner: Add set_irq_affinity function for combiner_irq ARM: EXYNOS: fix compilation error introduced due to common clock migration clk: exynos5250: Fix divider values for sclk_mmc{0,1,2,3} clk: exynos4: export clocks required for fimc-is clk: samsung: Fix compilation error clk: tegra: fix enum tegra114_clk to match binding ...
2013-04-04video: fb: vt8500: Convert framebuffer drivers to standardized bindingTony Prisk
Now that a display timing binding is available, convert our almost identical binding to use the standard binding. This patch converts the vt8500 and wm8505 framebuffer drivers and associated dts/dtsi files to use the standard binding as defined in bindings/video/display-timing.txt. There are two side-effects of making this conversion: 1) The fb node should now be in the board file, rather than the soc file as the display-timing node is a child of the fb node. 2) We still require a bits per pixel property to initialize the framebuffer for the different lcd panels. Rather than including this as part of the display timing, it is moved into the framebuffer node. I have also taken the opportunity to alphabetise the includes of each driver to avoid double-ups. Signed-off-by: Tony Prisk <linux@prisktech.co.nz> Signed-off-by: Tomi Valkeinen <tomi.valkeinen@ti.com>
2013-04-04arm: vt8500: Remove gpio devicetree nodesTony Prisk
Remove the gpio related devicetree nodes as these are no longer required with the move to a combined pinctrl/gpio driver. Signed-off-by: Tony Prisk <linux@prisktech.co.nz> Acked-by: Linus Walleij <linus.walleij@linaro.org>
2013-04-04arm: dts: vt8500: Update Wondermedia SoC dtsi files for pinctrl driverTony Prisk
This patch adds pinctrl nodes to the VIA VT8500 and Wondermedia SoC dtsi files to support the pinctrl driver. Signed-off-by: Tony Prisk <linux@prisktech.co.nz> Acked-by: Linus Walleij <linus.walleij@linaro.org>
2013-01-21dts: vt8500: Add initial dts support for WM8850Tony Prisk
This patch adds a soc dtsi for the Wondermedia WM8850. A board dts file is also included for the W70v2 tablet, with support for all the drivers currently in mainline. Signed-off-by: Tony Prisk <linux@prisktech.co.nz> Signed-off-by: Olof Johansson <olof@lixom.net>
