Follow trend and use the SPDX License description.
This will simplify dt overlay structure for the whole PL.
Drop the space before/after '<' and '>'; and
separate the entries to be a bit more readable.
Reported-by: Julia Cartwright <julia@ni.com>
Series-to: arm-soc
Series-cc: julia@ni.com
The patch removes these warnings reported by dtc 1.4:
Warning (unit_address_vs_reg): Node /pmu has a reg or ranges property,
but no unit name
Warning (unit_address_vs_reg): Node /fixedregulator@0 has a unit name,
but no reg property
Warning (unit_address_vs_reg): Node /memory has a reg or ranges
property, but no unit name
Reviewed-by: Julia Cartwright <julia@ni.com>
Series-to: arm-soc
Based on
"ARM: dts: explicitly mark skeleton.dtsi as deprecated"
(sha1: 9c0da3cc61f1233c2782e2d3d91e3d0707dd4ba5)
skeleton.dtsi is deprecated.
Move address and size-cells directly to zynq-7000.dtsi.
By adding labels to the cpu nodes in the dtsi, a dts that
includes it can change the OPPs by referencing the cpu0
through the label.
Signed-off-by: Moritz Fischer <moritz.fischer@ettus.com>
Reviewed-by: Sören Brinkmann <soren.brinkmann@xilinx.com>
The SLCR (System-Level Control Registers) block is an MFD (Multi
Function Device) rather than a bus.
"simple-mfd" seems a more suitable compatible string than "simple-bus".
GPIO can be used as interrupt-controller. Add the missing properties to
the GPIO node.
Signed-off-by: Soren Brinkmann <soren.brinkmann@xilinx.com>
Reviewed-by: Moritz Fischer <moritz.fischer@ettus.com>
Added addtional nodes required for FPGA Manager operation
of the Xilinx Zynq Devc configuration interface.
Add pl310 interrupt to the Zynq devicetree.
Signed-off-by: Alex Wilson <alex.david.wilson@gmail.com>
Add OCM node for all zynq boards. OCM location
can changed but for all current boards this
is the location where OCM is.`
Use the new zynq binding for macb ethernet, since it will disable half
duplex gigabit like the Zynq TRM says to do. Also allow the compatible
cadence gem binding that won't disable half duplex but works otherwise.
Signed-off-by: Nathan Sullivan <nathan.sullivan@ni.com>
Acked-by: Sören Brinkmann <soren.brinkmann@xilinx.com>
Based on:
"devicetree: Add Cadence WDT devicetree bindings documentation"
(sha1: 191891c0378f44aec8e06e889a08d0b76fe6c5cb)
- compatible string is cdns,wdt-r1p2
- remove device_type property
- remove int reset property (reset-on-timeout is bool)
Series-to: arm-soc
Add pinctrl descriptions to the zc702 and zc706 device trees.
Tested-by: Andreas Färber <afaerber@suse.de>
Add USB nodes to zc702, zc706 and zed device trees.
next/dt
Pull "arm: Xilinx Zynq dt patches for v3.19" from Michal Simek:
- Declare Digilent and vendor
- Add Zybo board support
- Fix VDMA documentation to be align with the driver
* tag 'zynq-dt-for-3.19' of https://github.com/Xilinx/linux-xlnx:
arm: dts: zynq: Add Digilent ZYBO board
arm: dts: zynq: Move crystal freq. to board level
doc: dt: vendor-prefixes: Add Digilent Inc
Documentation: devicetree: Fix Xilinx VDMA specification
The fact that all supported boards use the same 33MHz crystal is a
co-incidence. The Zynq PS support a range of crystal freqs so the
hardcoded setting should be removed from the dtsi. Re-implement it
on the board level.
This prepares support for Zynq boards with different crystal
frequencies (e.g. the Digilent ZYBO).
Acked-by: Soren Brinkmann <soren.brinkmann@xilinx.com>
Signed-off-by: Peter Crosthwaite <crosthwaite.peter@gmail.com>
sed -i 's/}\ ;/};/g'
Add the cadence watchdog node to the Zynq devicetree.
Add missing reference for memory-controller.
Add missing reference for ADC node.
By in sync with others node and add also baseaddr
to the node name.
Due to dependencies between timer and CPU frequency, only changes by
powers of two are allowed. The clocksource driver prevents other
changes, but with cpufreq and its governors it can result in being
spammed with error messages constantly. Hence, remove the 222 MHz OPP.
The size of the GEM's register area is only 0x1000 bytes.
Pull ARM SoC DT updates from Arnd Bergmann:
"As usual, this is the largest branch, though this time a little under
half of the total changes with 307 individual non-merge changesets.
The largest changes are the addition of new machines, in particular
the Tegra based Chromebook, the Renesas r8a7794 SoC, and DT support
for the old i.MX1 platform.
Other changes include
- at91: various sam9 and sama5 updates
- exynos: much extended Peach Pi/Pit (Chromebook 2) support
- keystone: new peripherals
- meson: added DT for meson6 SoC
- mvebu: new device support for Armada 370/375
- qcom: improved support for IPQ8064 and MSM8x60
- rockchip: much improved support for rk3288
- shmobile: lots of updates all over the place
- sunxi: dts license change
- sunxi: more a23 device support
- vexpress: CLCD DT description"
* tag 'dt-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (308 commits)
ARM: DTS: meson: update DTSI to add watchdog node
ARM: dts: keystone-k2l: fix mdio io start address
ARM: dts: keystone-k2e: fix mdio io start address
ARM: dts: keystone-k2e: update usb1 node for dma properties
ARM: dts: keystone: fix io range for usb_phy0
Revert "Merge tag 'hix5hd2-dt-for-3.18' of git://github.com/hisilicon/linux-hisi into next/dt"
Revert "ARM: dts: hix5hd2: add wdg node"
ARM: dts: add rk3288 i2s controller
ARM: vexpress: Add CLCD Device Tree properties
ARM: bcm2835: add I2S pinctrl to device tree
ARM: meson: documentation: add bindings documentation
ARM: meson: dts: add basic Meson/Meson6/Meson6-atv1200 DTSI/DTS
ARM: dts: mt6589: Change compatible string for GIC
ARM: dts: mediatek: Add compatible property for aquaris5
ARM: dts: mt6589-aquaris5: Add boot argument earlyprintk
ARM: dts: mt6589: Fix typo in GIC unit address
ARM: dts: Build dtb for Mediatek board
ARM: dts: keystone: fix bindings for pcie and usb clock nodes
ARM: dts: keystone: k2l: Fix chip selects for SPI devices
ARM: dts: keystone: add dsp gpio controllers nodes
Add the DDR controller to the Zynq devicetree.
Acked-by: Daniel Lezcano <daniel.lezcano@linaro.org>
Remove space before semicolon.
sed -i 's/}\ ;/};/g' arch/arm/boot/dts/zynq-*
Move the GEM's size and address cells properties to the common
dtsi file.
Cc: Andreas Färber <afaerber@suse.de>
Reviewed-by: Andreas Färber <afaerber@suse.de>
Add node describing Zynq's CAN controller.
Reviewed-by: Soren Brinkmann <soren.brinkmann@xilinx.com>
Signed-off-by: Andreas Färber <afaerber@suse.de>
Add node describing Zynq's GPIO controller.
Add node for the Xilinx A/D Converter.
Cc: Lars-Peter Clausen <lars@metafoo.de>
The Zynq UART is Cadence IP and the driver has been renamed accordingly.
Migrate the DT to use the new binding for the UART driver.
Acked-by: Peter Crosthwaite <peter.crosthwaite@xilinx.com>
Acked-by: Rob Herring <robh@kernel.org>
Tested-by: Michal Simek <michal.simek@xilinx.com>
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc into next
Pull ARM SoC devicetree updates from Olof Johansson:
"As with previous release, this continues to be among the largest
branches we merge, with lots of new contents.
New things for this release are among other things:
- DTSI contents for the new SoCs supported in 3.16 (see SoC pull request)
- Qualcomm APQ8064 and APQ8084 SoCs and eval boards
- Nvidia Jetson TK1 development board (Tegra T124-based)
Two new SoCs that didn't need enough new platform code to stand out
enough for me to notice when writing the SoC tag, but that adds new DT
contents are:
- TI DRA72
- Marvell Berlin 2Q"
* tag 'dt-for-3.16' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (500 commits)
ARM: dts: add secure firmware support for exynos5420-arndale-octa
ARM: dts: add pmu sysreg node to exynos3250
ARM: dts: correct the usb phy node in exynos5800-peach-pi
ARM: dts: correct the usb phy node in exynos5420-peach-pit
ARM: dts: add dts files for exynos5410 and exynos5410-smdk5410
ARM: dts: add dts files for exynos3250 SoC
ARM: dts: add mfc node for exynos5800
ARM: dts: add Vbus regulator for USB 3.0 on exynos5800-peach-pi
ARM: dts: enable fimd for exynos5800-peach-pi
ARM: dts: enable display controller for exynos5800-peach-pi
ARM: dts: enable hdmi for exynos5800-peach-pi
ARM: dts: add dts file for exynos5800-peach-pi board
ARM: dts: add dts file for exynos5800 SoC
ARM: dts: add dts file for exynos5260-xyref5260 board
ARM: dts: add dts files for exynos5260 SoC
ARM: dts: update watchdog node name in exynos5440
ARM: dts: use key code macros on Origen and Arndale boards
ARM: dts: enable RTC and WDT nodes on Origen boards
ARM: dts: qcom: Add APQ8084-MTP board support
ARM: dts: qcom: Add APQ8084 SoC support
next/soc
Merge "Xilinx Zynq changes for v3.16" from Michal Simek:
arm: Xilinx Zynq cleanup patches for v3.16
- Add support for BIG Endian
- Add SOC_BUS support
- Sort Kconfig options
- Fix early console
* tag 'zynq-cleanup-for-3.16' of git://git.xilinx.com/linux-xlnx:
ARM: zynq: Enable big-endian
ARM: zynq: Fix uart0 early console virtual address
clocksource: cadence_ttc: Use readl/writel_relaxed instead of __raw
ARM: zynq: Sort Kconfig options
ARM: zynq: Add support for SOC_BUS
Provide information through SOC_BUS to user space.
Silicon revision is provided through devcfg device.
To silence the warning
cpufreq_cpu0: failed to get cpu0 regulator: -19
from the cpufreq driver regarding a missing regulator,
add a fixed regulator to the DT.
Zynq does not support voltage scaling and the CPU rail should always be
supplied with 1 V, hence it is added in the SOC-level dtsi.
- Use generic node names
- Fix up some weird formatting and white spaces
- Update copyright info
This is likely a copy-and-paste error from the
ARM GIC documentation, that has already been fixed.
address-cells should have been set to 0, as with the size
cells. As having those properties set to 0 is the
same thing as not specifying them, drop them completely.
Signed-off-by: Lucas Stach <l.stach@pengutronix.de>
Specify the 'clock-latency' property to avoid certain cpufreq governors
from refusing to work with the following error:
ondemand governor failed, too long transition latency of HW, fallback to performance governor
Reported-by: Mike Looijmans <mike.looijmans@topic.nl>
Tested-by: Mike Looijmans <mike.looijmans@topic.nl>
Pull ARM SoC late cleanups from Arnd Bergmann:
"These could not be part of the first cleanup branch, because they
either came too late in the cycle, or they have dependencies on other
branches. Important changes are:
- The integrator platform is almost multiplatform capable after some
reorganization (Linus Walleij)
- Minor cleanups on Zynq (Michal Simek)
- Lots of changes for Exynos and other Samsung platforms, including
further preparations for multiplatform support and the clocks
bindings are rearranged"
* tag 'tags/cleanup2-3.15' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (54 commits)
devicetree: fix newly added exynos sata bindings
ARM: EXYNOS: Fix compilation error in cpuidle.c
ARM: S5P64X0: Explicitly include linux/serial_s3c.h in mach/pm-core.h
ARM: EXYNOS: Remove hardware.h file
ARM: SAMSUNG: Remove hardware.h inclusion
ARM: S3C24XX: Remove invalid code from hardware.h
dt-bindings: clock: Move exynos-audss-clk.h to dt-bindings/clock
ARM: dts: Keep some essential LDOs enabled for arndale-octa board
ARM: dts: Disable MDMA1 node for arndale-octa board
ARM: S3C64XX: Fix build for implicit serial_s3c.h inclusion
serial: s3c: Fix build of header without serial_core.h preinclusion
ARM: EXYNOS: Allow wake-up using GIC interrupts
ARM: EXYNOS: Stop using legacy Samsung PM code
ARM: EXYNOS: Remove PM initcalls and useless indirection
ARM: EXYNOS: Fix abuse of CONFIG_PM
ARM: SAMSUNG: Move s3c_pm_check_* prototypes to plat/pm-common.h
ARM: SAMSUNG: Move common save/restore helpers to separate file
ARM: SAMSUNG: Move Samsung PM debug code into separate file
ARM: SAMSUNG: Consolidate PM debug functions
ARM: SAMSUNG: Use debug_ll_addr() to get UART base address
Pull ARM SoC device tree changes from Arnd Bergmann:
"A large part of the arm-soc patches are nowadays DT changes, adding
support for new SoCs, boards and devices without changing kernel
source. The plan is still to move the devicetree files out of the
kernel tree and reduce the amount of churn going on here, but we keep
finding reasons to delay doing that.
Changes are really all over the place, with little sticking out
particularly. We have contributions from a total of 116 people in
this branch.
Unfortunately, the size of this branch also causes a significant
number of conflicts at the moment, typically when subsystem
maintainers merge patches that change the driver at the same time as
the dts files. In most cases this could be avoided because the dts
changes are supposed to be compatible in both ways, and we are asking
everyone to send ARM dts changes through our tree only"
* tag 'dt-3.15' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (541 commits)
dts: stmmac: Document the clocks property in the stmmac base document
dts: socfpga: Add DTS entry for adding the stmmac glue layer for stmmac.
ARM: STi: stih41x: Add support for the FSM Serial Flash Controller
ARM: STi: stih416: Add support for the FSM Serial Flash Controller
ARM: tegra: fix Dalmore pinctrl configuration
ARM: dts: keystone: use common "ti,keystone" compatible instead of -evm
ARM: dts: k2hk-evm: set ubifs partition size for 512M NAND
ARM: dts: Build all keystone dt blobs
ARM: dts: keystone: Fix control register range for clktsip
ARM: dts: keystone: Fix domain register range for clkfftc1
ARM: dts: bcm28155-ap: leave camldo1 on to fix reboot
ARM: dts: add bcm590xx pmu support and enable for bcm28155-ap
ARM: dts: bcm21664: Add device tree files.
ARM: DT: bcm21664: Device tree bindings
ARM: efm32: properly namespace i2c location property
ARM: efm32: fix unit address part in USART2 device nodes' names
ARM: mvebu: Enable NAND controller in Armada 385-DB
ARM: mvebu: Add support for NAND controller in Armada 38x SoC
ARM: mvebu: Add the Core Divider clock to Armada 38x SoCs
ARM: mvebu: Add a 2 GHz fixed-clock on Armada 38x SoCs
The generic cpufreq-cpu0 driver can scale the CPU frequency on Zynq
SOCs. Add the required platform device to the BSP and appropriate
OPPs to the dts.
Cc: Rob Herring <robh+dt@kernel.org>
Cc: Pawel Moll <pawel.moll@arm.com>
Cc: Mark Rutland <mark.rutland@arm.com>
Cc: Ian Campbell <ijc+devicetree@hellion.org.uk>
Cc: Kumar Gala <galak@codeaurora.org>
Cc: devicetree@vger.kernel.org
Signed-off-by: Daniel Lezcano <daniel.lezcano@linaro.org>
Acked-by: Michal Simek <michal.simek@xilinx.com>
The clkc has its registers in the range of the slcr.
Instead of passing around the slcr base address pointer, let the clkc get the
address from the DT.
This prepares the slcr to be a real driver with multiple memory ranges
(slcr, clocks, pinctrl,...)
Signed-off-by: Steffen Trumtrar <s.trumtrar@pengutronix.de>
Split the slcr into an early part for unlocking and cpu starting
and a later syscon driver.
Also add "syscon" compatible property for slcr.
