Use early console instead of earlyprintk which is supposed to use for
very early debugging (DEBUG_LL).
parallella - Remove linux,stdout-path.
Use stdout-path to identify kernel console
Acked-by: Mark Rutland <mark.rutland@arm.com>
Add aliases node to DTs.
Add USB nodes to zc702, zc706 and zed device trees.
Signed-off-by: Soren Brinkmann <soren.brinkmann@xilinx.com>
The fact that all supported boards use the same 33MHz crystal is a
co-incidence. The Zynq PS support a range of crystal freqs so the
hardcoded setting should be removed from the dtsi. Re-implement it
on the board level.
This prepares support for Zynq boards with different crystal
frequencies (e.g. the Digilent ZYBO).
Acked-by: Soren Brinkmann <soren.brinkmann@xilinx.com>
Signed-off-by: Peter Crosthwaite <crosthwaite.peter@gmail.com>
Add missing Ethernet phys to Zynq DTs.
Aling compatible property with others and have xlnx,zynq-zed
in compatible list too.
Be align with the rest of zynq DTS and have 0
written as 0x0.
Add this year to the header.
The used PHYs should be qualified as 'rgmii-id' instead of just 'rgmii'.
For the Zed board this seems to make a difference between working and
broken Ethernet.
Add nodes for the Arasan SDHCI controller to Zynq dts files.
The zynq includes a Cadence GEM IP core. This is compatible with the macb driver.
Add it to the zynq-7000 DT.
Signed-off-by: Steffen Trumtrar <s.trumtrar@pengutronix.de>
Cc: Michal Simek <michal.simek@xilinx.com>
Cc: Josh Cartwright <josh.cartwright@ni.com>
[soren: rebased to current Linus tree, added zc706 + zed support, moved phy-mode property to board level dtses]
Add a DT fragment for the Zed Zynq platform and a corresponding
target to the Makefile
Reviewed-by: Steffen Trumtrar <s.trumtrar@pengutronix.de>
