path: root/arch/arm/boot/dts/zynq-zybo.dts
2018-07-19ARM: dts: zynq: correct and improve the model property of dt filesLuis Araneda
Replace the current value of the model property by a more accurate description of each board (which includes the manufacturer), as some of the boards had the same value ("Xilinx Zynq") Signed-off-by: Luis Araneda <luaraneda@gmail.com> Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2018-07-19ARM: dts: zynq: Add mmc alias for zc702/zc706/zed/zyboMichal Simek
Add missing mmc alias. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2018-03-08arm: dts: zynq: Use SPDX-License-IdentifierMichal Simek
Follow trend and use the SPDX License description. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2017-08-21arm: zynq: Remove earlycon from bootargsMichal Simek
Earlyconsole is used for early kernel debugging that's why this option shouldn't be enabled by default. Earlyconsole is partially copying the part of the bootlog after "bootconsole [uart0] disabled". Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2017-08-21arm: zynq: Use C pre-processor for includes in dtsMichal Simek
Change the dtsi include code to use the C pre-processor #include instead of the device tree /include/. This brings all Zynq device trees inline with each other. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2017-08-21arm: zynq: Add device-type property for zynq ethernet phy nodesSai Pavan Boddu
Mention device-type = "ethernet-phy", as qemu will need this in absence of compatible. Signed-off-by: Sai Pavan Boddu <saipava@xilinx.com> Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2016-11-16ARM: zynq: Fix W=1 dtc 1.4 warningsMichal Simek
The patch removes these warnings reported by dtc 1.4: Warning (unit_address_vs_reg): Node /pmu has a reg or ranges property, but no unit name Warning (unit_address_vs_reg): Node /fixedregulator@0 has a unit name, but no reg property Warning (unit_address_vs_reg): Node /memory has a reg or ranges property, but no unit name Signed-off-by: Michal Simek <michal.simek@xilinx.com> Reviewed-by: Julia Cartwright <julia@ni.com> Series-to: arm-soc
2016-02-25ARM: zynq: Use earlycon instead of earlyprintkMichal Simek
Use early console instead of earlyprintk which is supposed to use for very early debugging (DEBUG_LL). Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2016-02-09ARM: dts: zynq: Enable USB and USB PHY for ZYBONathan Rossi
Setup the USB controller and configure it to operate in host mode. Additionally add the USB phy node for the ZYBO, including reset gpio which is connected to a external MIO pin. Signed-off-by: Nathan Rossi <nathan@nathanrossi.com> Cc: Rob Herring <robh+dt@kernel.org> Cc: Mark Rutland <mark.rutland@arm.com> Cc: Michal Simek <michal.simek@xilinx.com> Cc: Sören Brinkmann <soren.brinkmann@xilinx.com> Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2015-05-28ARM: dts: zynq: Fix stdout-path and bootargsMichal Simek
parallella - Remove linux,stdout-path. Use stdout-path to identify kernel console Signed-off-by: Michal Simek <michal.simek@xilinx.com> Acked-by: Mark Rutland <mark.rutland@arm.com>
2015-05-28ARM: dts: zynq: Add missing alias node for zybo and parallellaMichal Simek
Add missing alias node. Signed-off-by: Michal Simek <michal.simek@xilinx.com> Reviewed-by: Andreas Färber <afaerber@suse.de>
2014-12-01arm: dts: zynq: Add Digilent ZYBO boardPeter Crosthwaite
Add a DTS describing the Digilent ZYBO board. Similar to ZED but with a 50MHz crystal instead of 33MHz. Acked-by: Soren Brinkmann <soren.brinkmann@xilinx.com> Signed-off-by: Peter Crosthwaite <crosthwaite.peter@gmail.com> Signed-off-by: Michal Simek <michal.simek@xilinx.com>
