Do not rely on reset/boot defaults and use a default GPIO setting
with pull-up enabled.
Signed-off-by: Stefan Agner <stefan@agner.ch>
(cherry picked from commit 10d11dad4a4e343652fca86bda3b10684be30d4e)
For soc level of clocks which are input to Clock Control Module, clock
driver expects them to be under 'clocks' container node. But for board
level clocks, this container is not really necessary. Let's drop it and
use an unique name for fixed rate clock, so that 'reg' property can be
saved as well.
Acked-By: Lothar Waßmann <LW@KARO-electronics.de>
(cherry picked from commit 8799b5d5c76c5fc53a83cc86f16fb7f74bad923d)
Remove unnecessary #address-cells/#size-cells to fix the following
DTC warnings:
arch/arm/boot/dts/imx6q-novena.dtb: Warning (avoid_unnecessary_addr_size): /soc/aips-bus@2100000/i2c@21a0000/stmpe811@44: unnecessary #address-cells/#size-cells without "ranges" or child "reg"
Signed-off-by: Fabio Estevam <fabio.estevam@nxp.com>
(cherry picked from commit c099a5e5750bfad6b48f5216580813014779628a)
Add Colibri UART_A as default serial console.
Reviewed-by: Fabio Estevam <fabio.estevam@nxp.com>
(cherry picked from commit f10acffc550ddf651968330b2b4d08b9c1aa75a9)
Add support for the Computer on Module Colibri iMX6ULL and its
Bluetooth/Wifi variant along with the development/evaluation carrier
board device trees. Follow the usual hierarchic include model,
maintaining shared configuration in imx6ull-colibri.dtsi and
imx6ull-colibri-eval-v3.dtsi respectively.
(cherry picked from commit c2e4987e0e02095ed3d19e958b3891954ef38243)
Add support for the Computer on Module Colibri iMX7D 1GB along
with the Colibri Evaluation Board device trees. Follow the usual
hierarchic include model, maintaining shared configuration in
imx7-colibri.dtsi and imx7-colibri-eval-v3.dtsi respectively.
(cherry picked from commit f928a4a377e476525298a552185dfd92d2780319)
The Colibri Evaluation Carrier Board provides a MCP2515 CAN
controller connected via SPI. Note that the i.MX 7 provides
an internal CAN controller which is much better suited for CAN
operations. Using the MCP2515 with a Colibri iMX7 module is
mainly useful to test the SPI interface.
(cherry picked from commit 66d59b678a87152f85dd327ba6aa024df2896b37)
The Colibri standard defines SODIMM 71 as backlight enable
GPIO. Assign the GPIO to the backlight node in the module
level device tree.
(cherry picked from commit 6deb2260b2138154ab25922ffb0e1a67a9aa3ea4)
The usdhc1 controller instance is used to provide the default
SD/MMC capabilities of the Colibri standard. The IO pins are
supplied to the SoC on the module whereas the SD-card is powered
by the Carrier Board supply.
(cherry picked from commit 49e6ce614b456a4456f9ef8770797f9bc885a247)
Specify CPU supply using the "cpu-supply" property instead of
the invalid "arm-supply" property.
(cherry picked from commit 5dc2dcf58a87ba74f06a9aba5c7248991aa65ece)
All Colibri iMX7 SKUs use either single-die NAND or eMMC, hence
NAND_CE1 is not used on the module and can be used as a GPIO by
carrier boards.
(cherry picked from commit c2e70bbb616d8605b86b3344ccc03d122b5d8494)
Use pull-ups instead of pull-downs for the pins which are already
pulled-up externally.
(cherry picked from commit ffb2e259c462b38f4cccf742d6d9856429725ed0)
The Colibri pins PWM<A> and <D> are multiplexed on the module, make
sure the secondary SoC pin is not active.
(cherry picked from commit e95723b5ecaa21b30de3c786d3e8a34e15632beb)
The Colibri default which enables USB Host power is not necessarily
tied to the OTG2 controller, some carrier board use the pin to
control USB power for both controllers. Hence name the pinctrl
group more generic.
Also move the regulator to the generic eval-v3 device tree since
the regulator is always on the carrier board. In the Colibri iMX7S
case the regulator is just not used. This allows to reuse the
regulator in a upcoming SKU Colibri iMX7D 1GB with eMMC.
(cherry picked from commit 7e81cb3d9cf5a7cc56606a63ca6f100bb3f1f5de)
All Toradex Carrier Boards use a st,m41t0 compatible RTC. Compared
to a st,m41t00 this RTC has also an oscillator fail bit which allows
to detect when the RTC lost track of time.
Cc: Sanchayan Maity <maitysanchayan@gmail.com>
Cc: Marcel Ziswiler <marcel.ziswiler@toradex.com>
(cherry picked from commit c53bec16b150a84f6b5395af1bc45335293d3c64)
As described in
Documentation/devicetree/bindings/input/touchscreen/stmpe.txt
there is no 'reg' property under stmpe_touchscreen, so remove it
to fix the following build warning with W=1:
arch/arm/boot/dts/imx6dl-colibri-eval-v3.dtb: Warning (unit_address_vs_reg): Node /soc/aips-bus@2100000/i2c@21a4000/stmpe811@41/stmpe_touchscreen has a reg or ranges property, but no unit name
(cherry picked from commit 0fe9c347c138dc8f2c7bd3d90875d1e72b039fd8)
As described in
arch/arm/boot/dts/imx6q-apalis-eval.dtb: Warning (unit_address_vs_reg): Node /soc/aips-bus@2100000/i2c@21a4000/stmpe811@41/stmpe_touchscreen has a reg or ranges property, but no unit name
(cherry picked from commit 89277e8e2679932e34b5f85674c12de4b6352da0)
This is the 4.14.164 stable release
arch/arm/Kconfig.debug
arch/arm/boot/dts/imx7s.dtsi
arch/arm/mach-imx/cpuidle-imx6q.c
arch/arm/mach-imx/cpuidle-imx6sx.c
arch/arm64/kernel/cpu_errata.c
arch/arm64/kvm/hyp/tlb.c
drivers/crypto/caam/caamalg.c
drivers/crypto/mxs-dcp.c
drivers/dma/imx-sdma.c
drivers/gpio/gpio-vf610.c
drivers/gpu/drm/bridge/adv7511/adv7511_drv.c
drivers/input/keyboard/imx_keypad.c
drivers/input/keyboard/snvs_pwrkey.c
drivers/mmc/core/block.c
drivers/mmc/core/queue.h
drivers/mmc/host/sdhci-esdhc-imx.c
drivers/net/can/flexcan.c
drivers/net/can/rx-offload.c
drivers/net/ethernet/freescale/fec_main.c
drivers/net/wireless/ath/ath10k/pci.c
drivers/net/wireless/broadcom/brcm80211/brcmfmac/cfg80211.c
drivers/pci/dwc/pci-imx6.c
drivers/spi/spi-fsl-lpspi.c
drivers/usb/dwc3/gadget.c
include/net/tcp.h
sound/soc/fsl/Kconfig
sound/soc/fsl/fsl_esai.c
[ Upstream commit 5abd45ea0fc3060f7805e131753fdcbafd6c6618 ]
BeagleBone Black series is equipped with 512MB RAM
whereas only 256MB is included from am335x-bone-common.dtsi
This leads to an issue with unusual setups when devicetree
is loaded by GRUB2 directly.
Signed-off-by: Matwey V. Kornilov <matwey@sai.msu.ru>
[ Upstream commit e17e7c498d4f734df93c300441e100818ed58168 ]
On am57xx-beagle-x15, 5V0 is connected to P16, P17, P18 and P19
connectors. On am57xx-evm, 5V0 regulator is used to get 3V6 regulator
which is connected to the COMQ port. Model 5V0 regulator here in order
for it to be used in am57xx-evm to model 3V6 regulator.
Signed-off-by: Kishon Vijay Abraham I <kishon@ti.com>
[ Upstream commit 1c226017d3ec93547b58082bdf778d9db7401c95 ]
Current USB3503 driver ignores GPIO polarity and always operates as if the
GPIO lines were flagged as ACTIVE_HIGH. Fix the polarity for the existing
USB3503 chip applications to match the chip specification and common
convention for naming the pins. The only pin, which has to be ACTIVE_LOW
is the reset pin. The remaining are ACTIVE_HIGH. This change allows later
to fix the USB3503 driver to properly use generic GPIO bindings and read
polarity from DT.
Signed-off-by: Maxime Ripard <maxime@cerno.tech>
[ Upstream commit 493e84c5dc4d703d976b5875f5db22dae08a0782 ]
Add missing vdda-supply required by STM32 ADC.
Fixes: 090992a9ca54 ("ARM: dts: stm32: enable ADC on stm32h743i-eval
board")
Signed-off-by: Fabrice Gasnier <fabrice.gasnier@st.com>
Signed-off-by: Alexandre Torgue <alexandre.torgue@st.com>
[ Upstream commit ca0961011db57e39880df0b5708df8aa3339dc6f ]
mmc1 node where wifi module is connected doesn't have properly defined
power supplies so wifi module is never powered up. Fix that by
specifying additional power supplies.
Additionally, this STB may have either Realtek or Broadcom based wifi
module. One based on Broadcom module also needs external clock to work
properly. Fix that by adding clock property to wifi_pwrseq node.
Fixes: e582b47a9252 ("ARM: dts: sun8i-h3: Add dts for the Beelink X2 STB")
Signed-off-by: Jernej Skrabec <jernej.skrabec@siol.net>
Signed-off-by: Maxime Ripard <maxime.ripard@bootlin.com>
[ Upstream commit c7861adbe37f576931650ad8ef805e0c47564b9a ]
Each eTSEC MAC has its own TBI (SGMII) PCS and private MDIO bus.
But due to a DTS oversight, both SGMII-compatible MACs of the LS1021 SoC
are pointing towards the same internal PCS. Therefore nobody is
controlling the internal PCS of eTSEC0.
Upon initial ndo_open, the SGMII link is ok by virtue of U-boot
initialization. But upon an ifdown/ifup sequence, the code path from
ndo_open -> init_phy -> gfar_configure_serdes does not get executed for
the PCS of eTSEC0 (and is executed twice for MAC eTSEC1). So the SGMII
link remains down for eTSEC0. On the LS1021A-TWR board, to signal this
failure condition, the PHY driver keeps printing
'803x_aneg_done: SGMII link is not ok'.
Also, it changes compatible of mdio0 to "fsl,etsec2-mdio" to match
mdio1 device.
Fixes: 055223d4d22d ("ARM: dts: ls1021a: Enable the eTSEC ports on QDS and TWR")
Signed-off-by: Vladimir Oltean <olteanv@gmail.com>
Reviewed-by: Claudiu Manoil <claudiu.manoil@nxp.com>
Acked-by: Li Yang <leoyang.li@nxp.com>
[ Upstream commit dc141b99fc36cf910a1d8d5ee30f43f2442fd1bd ]
The fixed voltage regulator on Phytec phyCORE-LPC3250 board, which
supplies SD/MMC card's power, has a constant output voltage level
of either 3.15V or 3.3V, the actual value depends on JP4 position,
the power rail is referenced as VCC_SDIO in the board hardware manual.
Fixes: d06670e96267 ("arm: dts: phy3250: add SD fixed regulator")
Signed-off-by: Vladimir Zapolskiy <vz@mleia.com>
[ Upstream commit 30fc01bae3cda747e7d9c352b1aa51ca113c8a9d ]
The originally added ARM PrimeCell PL111 clocks property misses
the required "clcdclk" clock, which is the same as a clock to enable
the LCD controller on NXP LPC3230 and NXP LPC3250 SoCs.
Fixes: 93898eb775e5 ("arm: dts: lpc32xx: add clock properties to device nodes")
[ Upstream commit 7a0790a4121cbcd111cc537cdc801c46ccb789ee ]
ARM PrimeCell PL111 LCD controller is found on On NXP LPC3230
and LPC3250 SoCs variants, the original reference in compatible
property to an older one ARM PrimeCell PL110 is invalid.
Fixes: e04920d9efcb3 ("ARM: LPC32xx: DTS files for device tree conversion")
[ Upstream commit 489261c45f0ebbc1c2813f337bbdf858267f5033 ]
After switching to a new interrupt controller scheme by separating SIC1
and SIC2 from MIC interrupt controller just one SoC keypad controller
was not taken into account, fix it now:
WARNING: CPU: 0 PID: 1 at kernel/irq/irqdomain.c:524 irq_domain_associate+0x50/0x1b0
error: hwirq 0x36 is too large for interrupt-controller@40008000
lpc32xx_keys 40050000.key: failed to get platform irq
lpc32xx_keys: probe of 40050000.key failed with error -22
Fixes: 9b8ad3fb81ae ("ARM: dts: lpc32xx: reparent SIC1 and SIC2 interrupts from MIC")
[ Upstream commit 3e88bc38b9f6fe4b69cecf81badd3c19fde97f97 ]
NXP LPC32xx keypad controller requires a clock property to be defined.
The change fixes the driver initialization problem:
lpc32xx_keys 40050000.key: failed to get clock
commit 0c4eb2a6b3c6b0facd0a3bccda5db22e7b3b6f96 upstream.
commit d23f3839fe97d8dce03d ("ARM: dts: DRA7: Add pcie1 dt node for
EP mode") while adding the dt node for EP mode for DRA7 platform,
added rc node for am571x-idk and populated gpios property with
"gpio3 23". However the GPIO_PCIE_SWRST line is actually connected
to "gpio5 18". Fix it here. (The patch adding "gpio3 23" was tested
with another am57x board in EP mode which doesn't rely on reset from
host).
Cc: stable <stable@vger.kernel.org> # 4.14+
Fixes: d23f3839fe97d8dce03d ("ARM: dts: DRA7: Add pcie1 dt node for EP mode")
[ Upstream commit c6b16761c6908d3dc167a0a566578b4b0b972905 ]
The LCD panel on AM4 GP EVMs and ePOS boards seems to be
osd070t1718-19ts. The current dts files say osd057T0559-34ts. Possibly
the panel has changed since the early EVMs, or there has been a mistake
with the panel type.
Update the DT files accordingly.
Acked-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com>
Signed-off-by: Tomi Valkeinen <tomi.valkeinen@ti.com>
[ Upstream commit 30e647a764d446723a7e0fb08d209e0104f16173 ]
During definition of the CPU thermal zone of BCM283x SoC family there
was a misunderstanding of the meaning "criticial trip point" and the
thermal throttling range of the VideoCore firmware. The latter one takes
effect when the core temperature is at least 85 degree celsius or higher
So the current critical trip point doesn't make sense, because the
thermal shutdown appears before the firmware has a chance to throttle
the ARM core(s).
Fix these unwanted shutdowns by increasing the critical trip point
to a value which shouldn't be reached with working thermal throttling.
Fixes: 0fe4d2181cc4 ("ARM: dts: bcm283x: Add CPU thermal zone with 1 trip point")
Signed-off-by: Stefan Wahren <wahrenst@gmx.net>
Signed-off-by: Florian Fainelli <f.fainelli@gmail.com>
[ Upstream commit fac2c2da3596d77c343988bb0d41a8c533b2e73c ]
The MDIO node on Cygnus had an reversed #address-cells and
#size-cells properties, correct those.
Fixes: 40c26d3af60a ("ARM: dts: Cygnus: Add the ethernet switch and ethernet PHY")
Reported-by: Simon Horman <simon.horman@netronome.com>
Reviewed-by: Ray Jui <ray.jui@broadcom.com>
Reviewed-by: Simon Horman <simon.horman@netronome.com>
commit d60d0cff4ab01255b25375425745c3cff69558ad upstream.
fin_pll is the parent of clock-controller@7e00f000, specify
the dependency to ensure proper initialization order of clock
providers.
without this patch:
[ 0.000000] S3C6410 clocks: apll = 0, mpll = 0
[ 0.000000] epll = 0, arm_clk = 0
with this patch:
[ 0.000000] S3C6410 clocks: apll = 532000000, mpll = 532000000
[ 0.000000] epll = 24000000, arm_clk = 532000000
Cc: <stable@vger.kernel.org>
Fixes: 3f6d439f2022 ("clk: reverse default clk provider initialization order in of_clk_init()")
Signed-off-by: Lihua Yao <ylhuajnu@outlook.com>
Reviewed-by: Sylwester Nawrocki <s.nawrocki@samsung.com>
Signed-off-by: Krzysztof Kozlowski <krzk@kernel.org>
commit 287897f9aaa2ad1c923d9875914f57c4dc9159c8 upstream.
The MMC card detection GPIO polarity is active low on TAO3530, like in many
other similar boards. Now the card is not detected and it is unable to
mount rootfs from an SD card.
Fix this by using the correct polarity.
This incorrect polarity was defined already in the commit 30d95c6d7092
("ARM: dts: omap3: Add Technexion TAO3530 SOM omap3-tao3530.dtsi") in v3.18
kernel and later changed to use defined GPIO constants in v4.4 kernel by
the commit 3a637e008e54 ("ARM: dts: Use defined GPIO constants in flags
cell for OMAP2+ boards").
While the latter commit did not introduce the issue I'm marking it with
Fixes tag due the v4.4 kernels still being maintained.
Fixes: 3a637e008e54 ("ARM: dts: Use defined GPIO constants in flags cell for OMAP2+ boards")
Cc: linux-stable <stable@vger.kernel.org> # 4.4+
Signed-off-by: Jarkko Nikula <jarkko.nikula@bitmer.com>
commit 4f9007d692017cef38baf2a9b82b7879d5b2407b upstream.
Since v4.7 the dma initialization requires that there is a
device tree property for "rx" and "tx" channels which is
not provided by the pdata-quirks initialization.
By conversion of the mmc3 setup to device tree this will
finally allows to remove the OpenPandora wlan specific omap3
data-quirks.
Fixes: 81eef6ca9201 ("mmc: omap_hsmmc: Use dma_request_chan() for requesting DMA channel")
Signed-off-by: H. Nikolaus Schaller <hns@goldelico.com>
Cc: <stable@vger.kernel.org> # v4.7+
Signed-off-by: Ulf Hansson <ulf.hansson@linaro.org>
[ Upstream commit 5719ac19fc32d892434939c1756c2f9a8322e6ef ]
"arm,cortex-a15-pmu" is not a valid fallback compatible string for an
Cortex-A7 PMU, so drop it.
Cc: Maxime Ripard <maxime.ripard@bootlin.com>
Cc: Chen-Yu Tsai <wens@csie.org>
Signed-off-by: Rob Herring <robh@kernel.org>
Acked-by: Will Deacon <will.deacon@arm.com>
[ Upstream commit f3b2f758ec1e6cdb13c925647cbd8ad4938b78fb ]
There's a bug in dtc in checking for duplicate node names when there's
another section (e.g. "/ { };"). In this case, skeleton.dtsi provides
another section. Upon removal of skeleton.dtsi, the dtb fails to build
due to a duplicate node 'fixedregulator@0'. As both nodes were pretty
much the same 3.3V fixed regulator, it hasn't really mattered. Fix this
by renaming the nodes to something unique. In the process, drop the
unit-address which shouldn't be present wtihout reg property.
[ Upstream commit c40ad24254f1dbd54f2df5f5f524130dc1862122 ]
PXA25xx SoCs don't have a USB controller, so drop the node from the
common pxa2xx.dtsi base file. Both pxa27x and pxa3xx have a dedicated
node already anyway.
While at it, unify the names for the nodes across all pxa platforms.
Signed-off-by: Daniel Mack <daniel@zonque.org>
Reported-by: Sergey Yanovich <ynvich@gmail.com>
Link: https://patchwork.kernel.org/patch/8375421/
Signed-off-by: Robert Jarzmik <robert.jarzmik@free.fr>
[ Upstream commit 7f4b001b7f6e0480b5bdab9cd8ce1711e43e5cb5 ]
Cc: Linus Walleij <linus.walleij@linaro.org>
[ Upstream commit 400583983f8a8e95ec02c9c9e2b50188753a87fb ]
gpio-pxa uses two cell to encode the interrupt source: the pin number
and the trigger type. Adjust the device node accordingly.
Signed-off-by: Lubomir Rintel <lkundrak@v3.sk>
Acked-by: Pavel Machek <pavel@ucw.cz>
[ Upstream commit 438a44ce7e51ce571f942433c6c7cb87c4c0effd ]
All our pinctrl nodes were using a node name convention with a unit-address
to differentiate the different muxing options. However, since those nodes
didn't have a reg property, they were generating warnings in DTC.
In order to accomodate for this, convert the old nodes to the syntax we've
been using for the new SoCs, including removing the letter suffix of the
node labels to the bank of those pins to make things more readable.
Acked-by: Chen-Yu Tsai <wens@csie.org>
[ Upstream commit ed5fc60b909427be6ca93d3e07a0a5f296d7000a ]
Our HDMI output endpoint on the A10s DTSI has a warning under DTC: "graph
node has single child node 'endpoint', #address-cells/#size-cells are not
necessary". Fix this by removing those properties.
[ Upstream commit efc2e0bd9594060915696a418564aefd0270b1d6 ]
It is not correct to assign the 24MHz clock oscillator to the GPIO
ports.
Fix it by assigning the proper GPIO clocks instead.
Signed-off-by: Otavio Salvador <otavio@ossystems.com.br>
Tested-by: Fabio Berton <fabio.berton@ossystems.com.br>
Signed-off-by: Heiko Stuebner <heiko@sntech.de>
[ Upstream commit c955b7aec510145129ca7aaea6ecbf6d748f5ebf ]
According to the Rockchip vendor tree the PMU interrupt number is
76, so fix it accordingly.
[ Upstream commit 6035cbcceb069f87296b3cd0bc4736ad5618bf47 ]
DWC2 hardware module integrated in Samsung SoCs requires some quirks to
operate properly, so use Samsung SoC specific compatible to notify driver
to apply respective fixes.
[ Upstream commit 03d9f8fa2bfdc791865624d3adc29070cf67814e ]
There is no functional change from this, but it is confusing to find two
copies of vcc_sys and no vcc_flash when looking in
/sys/class/regulator/*/name.
Signed-off-by: John Keeping <john@metanate.com>
[ Upstream commit 998a84c27a7f3f9133d32af64e19c05cec161a1a ]
imx53-voipac-dmm-668 has two memory nodes, but the correct representation
would be to use a single one with two reg entries - one for each RAM chip
select, so fix it accordingly.
Reported-by: Marco Franchi <marco.franchi@nxp.com>
Signed-off-by: Fabio Estevam <festevam@gmail.com>
Signed-off-by: Marco Franchi <marco.franchi@nxp.com>
[ Upstream commit d88b11ef91b15d0af9c0676cbf4f441a0dff0c56 ]
This sets the partition information on the SQ201 to be read
out from the RedBoot partition table, removes the static
partition table and sets our boot options to mount root from
/dev/mtdblock2 where the squashfs+JFFS2 resides.
[ Upstream commit a763ecc15d0e37c3a15ff6825183061209832685 ]
OMAP5's Super-Speed USB port has a software mailbox register
that needs to be fed with VBUS and ID events from an external
VBUS/ID comparator.
Without this, Host role will not work correctly.
Fixes: 656c1a65ab55 ("ARM: dts: omap5: enable OTG role for DWC3 controller")
Reported-by: H. Nikolaus Schaller <hns@goldelico.com>
Signed-off-by: Roger Quadros <rogerq@ti.com>
