commit cdd10409914184c7eee5ae3e11beb890c9c16c61 upstream.
The "dmas" cells for the designware DMA controller need to have only 3
properties apart from the phandle: request line, src master and
destination master. But the commit 6e8887f60f60 updated it incorrectly
while moving from platform code to DT. Fix it.
Cc: stable@vger.kernel.org # v3.10+
Fixes: 6e8887f60f60 ("ARM: SPEAr13xx: Pass generic DW DMAC platform data from DT")
Signed-off-by: Viresh Kumar <viresh.kumar@linaro.org>
commit 6ffb5b4f248fe53e0361b8cbc2a523b432566442 upstream.
The interrupt-parent of rtc was missing, add it.
Fixes: 8113ba917dfa ("ARM: SPEAr: DT: Update device nodes")
Cc: stable@vger.kernel.org # v3.8+
commit e8bfa0422469cdfc86be3f525f621b1d44d2481b upstream.
The clcd device is lacking an interrupt-parent property, which makes
the interrupt unusable and shows up as a warning with the latest
dtc version:
arch/arm/boot/dts/ste-nomadik-s8815.dtb: Warning (interrupts_property): Missing interrupt-parent for /amba/clcd@10120000
arch/arm/boot/dts/ste-nomadik-nhk15.dtb: Warning (interrupts_property): Missing interrupt-parent for /amba/clcd@10120000
I looked up the old board files and found that this interrupt has
the same irqchip as all the other on-chip device, it just needs one
extra line.
Fixes: 17470b7da11c ("ARM: dts: add the CLCD LCD display to the NHK15")
commit 7ac1f59c09a61e6af6622df6809e003b0af07f3d upstream.
The GPIO polarity is missing in the hdmi,hpd-gpio property, this
fixes the following DT warnings:
arch/arm/boot/dts/stih410-b2120.dtb: Warning (gpios_property): hdmi,hpd-gpio property
size (8) too small for cell size 2 in /soc/sti-display-subsystem/sti-hdmi@8d04000
arch/arm/boot/dts/stih407-b2120.dtb: Warning (gpios_property): hdmi,hpd-gpio property
arch/arm/boot/dts/stih410-b2260.dtb: Warning (gpios_property): hdmi,hpd-gpio property
[arnd: marked Cc:stable since this warning shows up with the latest dtc
by default, and is more likely to actually cause problems than the
other patches from this series]
Signed-off-by: Patrice Chotard <patrice.chotard@st.com>
commit ca32e0c4bf9ca4b87089c5a5ce945e5f2ec890da upstream.
dtc warns about obviously incorrect GPIO numbers for the audio codec
on both lpc32xx boards:
arch/arm/boot/dts/lpc3250-phy3250.dtb: Warning (gpios_property): reset-gpio property size (12) too small for cell size 3 in /ahb/apb/i2c@400A0000/uda1380@18
arch/arm/boot/dts/lpc3250-phy3250.dtb: Warning (gpios_property): power-gpio property size (12) too small for cell size 3 in /ahb/apb/i2c@400A0000/uda1380@18
arch/arm/boot/dts/lpc3250-ea3250.dtb: Warning (gpios_property): reset-gpio property size (12) too small for cell size 3 in /ahb/apb/i2c@400A0000/uda1380@18
arch/arm/boot/dts/lpc3250-ea3250.dtb: Warning (gpios_property): power-gpio property size (12) too small for cell size 3 in /ahb/apb/i2c@400A0000/uda1380@18
It looks like the nodes are written for a different binding that combines
the GPIO number into a single number rather than a bank/number pair.
I found the right numbers on stackexchange.com, so this patch fixes
the warning and has a reasonable chance of getting things to actually
work.
Link: https://unix.stackexchange.com/questions/59497/alsa-asoc-how-to-correctly-load-devices-drivers/62217#62217
[ Upstream commit 5f1aa51c7a1eef1c5a60b8334e32c89904964245 ]
Booting a kernel results in the kernel warning us about the following
PPI interrupts configuration:
[ 0.105127] smp: Bringing up secondary CPUs ...
[ 0.110545] GIC: PPI11 is secure or misconfigured
[ 0.110551] GIC: PPI13 is secure or misconfigured
Fix this by using the appropriate edge configuration for PPI11 and
PPI13, this is similar to what was fixed for Northstar (BCM5301X) in
commit 0e34079cd1f6 ("ARM: dts: BCM5301X: Correct GIC_PPI interrupt
flags").
Fixes: 7b2e987de207 ("ARM: NSP: add minimal Northstar Plus device tree")
Fixes: 1a9d53cabaf4 ("ARM: dts: NSP: Add TWD Support to DT")
Acked-by: Jon Mason <jon.mason@broadcom.com>
Signed-off-by: Florian Fainelli <f.fainelli@gmail.com>
This allows the usage of the alias instead of the full path as phandle when
using the ASoC simple-audio-card driver.
The SAI is currently not usable with the ASoC simple-audio-card using
the i.MX6ULL device tree.
Fix it by adding "#sound-dai-cells" to sai1, sai2, and sai3.
This is the 4.9.76 stable release
Resolved conflicts
drivers/clk/imx/clk-imx6q.c
drivers/net/ethernet/freescale/fec_main.c
commit 56aeb07c914a616ab84357d34f8414a69b140cdf upstream.
MPP7 is currently muxed as "gpio", but this function doesn't exist for
MPP7, only "gpo" is available. This causes the following error:
kirkwood-pinctrl f1010000.pin-controller: unsupported function gpio on pin mpp7
pinctrl core: failed to register map default (6): invalid type given
kirkwood-pinctrl f1010000.pin-controller: error claiming hogs: -22
kirkwood-pinctrl f1010000.pin-controller: could not claim hogs: -22
kirkwood-pinctrl f1010000.pin-controller: unable to register pinctrl driver
kirkwood-pinctrl: probe of f1010000.pin-controller failed with error -22
So the pinctrl driver is not probed, all device drivers (including the
UART driver) do a -EPROBE_DEFER, and therefore the system doesn't
really boot (well, it boots, but with no UART, and no devices that
require pin-muxing).
Back when the Device Tree file for this board was introduced, the
definition was already wrong. The pinctrl driver also always described
as "gpo" this function for MPP7. However, between Linux 4.10 and 4.11,
a hog pin failing to be muxed was turned from a simple warning to a
hard error that caused the entire pinctrl driver probe to bail
out. This is probably the result of commit 6118714275f0a ("pinctrl:
core: Fix pinctrl_register_and_init() with pinctrl_enable()").
This commit fixes the Device Tree to use the proper "gpo" function for
MPP7, which fixes the boot of OpenBlocks A7, which was broken since
Linux 4.11.
Fixes: f24b56cbcd9d ("ARM: kirkwood: add support for OpenBlocks A7 platform")
Signed-off-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com>
Reviewed-by: Andrew Lunn <andrew@lunn.ch>
Signed-off-by: Gregory CLEMENT <gregory.clement@free-electrons.com>
[ Upstream commit 9bcf53f34a2c1cebc45cc12e273dcd5f51fbc099 ]
mmc2 used for wl12xx was missing the keep-power-in suspend
parameter. As a result the board couldn't reach suspend state.
Signed-off-by: Eyal Reizer <eyalr@ti.com>
[ Upstream commit 7d79f6098d82f8c09914d7799bc96891ad9c3baf ]
dtc recently added PCI bus checks. Fix these warnings.
Signed-off-by: Rob Herring <robh@kernel.org>
Cc: "Benoît Cousson" <bcousson@baylibre.com>
Cc: Tony Lindgren <tony@atomide.com>
Cc: linux-omap@vger.kernel.org
There is no such thing as mpc258x but it is rather called mcp251x.
This is the 4.9.67 stable release
Resolved conflicts:
arch/arm/boot/dts/imx6sx-sdb.dts
drivers/dma/imx-sdma.c
drivers/mmc/core/host.c
drivers/usb/chipidea/otg.c
sound/soc/fsl/fsl_ssi.c
This merge also reverts commit 3a654a85932f ("dmaengine:
imx-sdma - correct the dma transfer residue calculation"). The
downstream kernel seems to use different structures and already
use buf_ptail in its calculation.
toradex_4.9-1.0.x-imx-next
All PWM clock instances have their clock gate. Add these consistently.
Fixes freezing the kernel when one of these instances is used with
IMX6UL_CLK_DUMMY as its clock source.
(cherry picked from commit 4bc835895a461a17387b52a8229a4b7a4a52d982)
Use common convention where label is using the device model number
and the node name is using a generic device type.
During temperature testing modules print the following error every
now and then:
[ 12.231006] mmc0: Timeout waiting for hardware interrupt. retries left=0 opcode=12
Often the SDHC controller/driver does not recover from the issue
which leads to a Kernel panic (e.g. during boot the kernel can not
mount the root fs).
Lowering the frequency to 100MHz proves to be stable and affects
effective bandwith by less than 5%.
(cherry picked from commit 166fb4842e780f63c31622af706335e7dcd48c24)
Add pinmuxing and do not specify voltage restrictions in the
module level device tree.
- don't group pingroups with an additional node inside iomuxc.
- only mux BL_ON once.
With commit 1e6580d1714b6686766f105bf9125537443eeea7 the phandle
referencing the digital audio interface has been renamed.
Follow that.
Forward port the device tree sources for the Apalis iMX6 / Ixora
module - carrier combination from the downstream toradex_4.1-2.0.x-imx branch.
Split the pinctrl property for usdhc1 into a 4bit SD interface
and an extension to 8bit. This is required to support the 8 bit
MMC interface on the Evaluation Board for usdhc1 and the 4 bit
SD interface on Ixora V1.1 for usdhc1.
Signed-off-by: Sanchayan Maity <maitysanchayan@gmail.com>
(cherry picked from commit 42f45b7516eb2ce24f122382c49c2f63a6763292)
arch/arm/boot/dts/imx6qdl-apalis.dtsi
Update #pwm-cells to 3 in order to support PWM signal polarity
control.
(cherry picked from commit 6863695b931ae31fe20171e75cf8a57c990873be)
The imx pwm driver now support output inversion with a 3rd parameter.
While at it move the backlight pwm settings into the carrier board
file were it belongs. Period and polarity are carrier board / display
dependent.
(cherry picked from commit d1c393ddcb6937b58fa3a9314c8b6f2382b346dc)
The High Speed SD interface requires a clock of 50MHz. Using a
base clock of 198MHz allows for a more accurate clock than using
132MHz base clock.
Add atmel mxt multitouch controller driver which is interfaced over I2C bus.
This controller is used by the Logic Technologies, Capacitive Touch Display
7" Parallel (LT161010-2NHC).
Signed-off-by: Bhuvanchandra DV <bhuvanchandra.dv@toradex.com>
(cherry picked from commit f5f290716a30ec627a90227a2864b6745fa78150)
Add new gpio hog group for atmel mxt ts GPIOs.
(cherry picked from commit e747c0e955869e5cb6d9ea4da9477895901dbc92)
Initial add of Colibri iMX6ULL device trees, copied and adopted
from the Toradex toradex_4.1-2.0.x-imx branch.
The file uses linux,keycode = <KEY_POWER>;, so include
the header which defines KEY_POWER.
(cherry picked from commit d96c255841fdb49adcb91ebc44a45a104cad7755)
Add support for the latest addition to the Colibri iMX7 familiy,
Colibri iMX7 Dual 1GB with eMMC storage.
(cherry picked from commit a2dcace21887235f2f0b397aca11c17c7762e22a)
Add support for Aster Carrier Board with Colibri iMX7.
(cherry picked from commit 46713ddc870f77064b5a05f522fc7e1fdb635fc7)
Some carrier boards use the USB VBUS regulator for both USB
DR controllers. Hence the reference to the OTG2 instance is
confusing. Rename the pinctrl and regulator to "usbh".
To access the keypad port registers the IPG clocks need to be on,
specify the clock accordingly.
(cherry picked from commit 36df4e26b4257eaaa194fb39c9b43d30efe9f9d0)
(cherry picked from commit 8262ee2e7e5866c8a1e22dff90ac96cc272b1103)
Commit 95c163471135 ("usb: chipidea: use of extcon framework to
work for non OTG case") requires both pins to be specified (ID and
VBUS pin) to work correctly.
gst-inspect mfw_v4lsrc
gst-launch mfw_v4lsrc capture-mode=5 device=/dev/video2 ! mfw_v4lsink
Signed-off-by: Wojciech Bieganski <wbieganski@antmicro.com>
(cherry picked from commit 4f4528cf031a4c6585bfcefd66607780de064de8)
(cherry picked from commit b34325c7f99d3f323214e8b0f121711330769646)
Merge of Apalis iMX6 module level device tree and initial
add of Apalis iMX6 Evaluation Board device tree. Copied
and adopted from the Toradex toradex_4.1-2.0.x-imx branch.
Initial add of Colibri iMX6 device tree, copied and adopted
The Cortex-M4 clock is used in the busfreq driver to determine
whether a high bus frequency is required for the Cortex-M4 core.
This follows the design used on i.MX 6SoloX.
(cherry picked from commit 0666dae4b839135b6441b773b7ec9a24b0fb93ad)
AIPS-3 has some peripherals connected via SPBA. Model the
bus accordingly.
The Colibri iMX7 Solo has only 256MB of memory. Specify the end
of 256MB of memory to be the location of the RPMSG vrings.
The pad SAI1_RX_DATA can be used as second chip select for dual-die
NAND. However, with an assembly option the pad is available as GPIO
on SODIMM 169. All current version of Colibri iMX7 modules have the
pad available as GPIO hence mux it as GPIO by default.
(cherry picked from commit 06f06382f10b425f6dfdee43b8dfc7f77f75a22b)
(cherry picked from commit 10e57f8296b8d98762882a196ce3e6c06af008d5)
Revisit default pinmux configuration, use pull-ups instead of
pull-downs where there is already an external pull-up by default.
(cherry picked from commit 315740d8fe6a0517219c0b479bad4a7db3e7ac30)
(cherry picked from commit d6eaed7ac1bf959732d160948042a05451b88847)
The PWM<A> and PWM<D> have multiplexed pins which by default have a
pull-up enabled. Take them into the same pinmux group as the PWM
pin and disable pull-ups.
This also makes sure that there is no conflicting usage of the same
pin...
(cherry picked from commit b4413e4426977aa88e2a712cb549104e792859d8)
(cherry picked from commit 7711ceeea050bf9f45add3f1a7f78607b13c034c)
The PWM driver has now capability to specify the PWM polarity
which is e.g. for backlight control. Allow to make use of PWM
polarity by specifying pwm-cells to be 3 in the base dt.
Signed-off-by: Stefan Agner <stefan@agner.ch>
Reviewed-by: Fabio Estevam <fabio.estevam@nxp.com>
(cherry picked from commit 9be48d2d98810ae723c229c05b078ca5a07e9561)
