There is a new property to work around the bug of PMIC PF0100.
This property turns the pmic into the standby mode on power down the
system, that leads to turn off all power rails. In this mode the power
consumption is around 2 mA.
Related-to: ELB-3580
Signed-off-by: Oleksandr Suvorov <oleksandr.suvorov@toradex.com>
(cherry-picked from commit 36c91bbb3ff44beccc48a6e833d2b61e89affeb5)
toradex_4.14-2.3.x-imx
The dts file for WIFI support on i.MX6ULZ Lite is missed, so add it.
Signed-off-by: Jacky Bai <ping.bai@nxp.com>
Reviewed-by: Anson Huang <Anson.Huang@nxp.com>
Add btwifi dts support for i.MX6ULZ Lite.
The i.MX6ULZ Lite is full compatible with i.MX6ULL/ULZ, and
only support 9x9 package.
Add GPIO line names on module level. Those are all GPIOs which a user
might use on his custom carrier board. If more meaningful names are
available on the carrier board, the user can overwrite the line names
in the carrier board level device tree.
Related-to: ELB-2794
Related-to: ELB-2525
(cherry picked from commit 5ca35c3842c88bed48fdbf79dbaa326c5c085af1)
Related-to: ELB-2524
(cherry picked from commit d6133247f87fc07ca917df7dcf12bbd33f9bdafd)
squashed fixup:
(cherry picked from commit 0e0c71ae67dab11b0acdf19529420c65043c30b0)
arch/arm/boot/dts/imx6qdl-colibri.dtsi
Add Colibri SODIMM numbers as GPIO line names on module level. The GPIO
lines with a name are all available on the SODIMM edge connector of the
Colibri iMX7 module and therefore a customer might use it as a GPIO. The
Toradex Evaluation Board has the SODIMM numbers printed on the silk-
screen. This allows a customer to quickly control a GPIO on a pin-header
by using the name printed next to it.
Putting the GPIO line name on module level makes sure that a customer
gets a reasonable default. If more meaningful names are available on a
custom carrier board, the user can overwrite the line names in a carrier
The eMMC based modules share all GPIO names except two GPIOs on bank 6
which are not available on the raw NAND devices. Hence overwrite GPIO
line names of bank 6 in the eMMC specific device tree file.
Reviewed-by: Philippe Schenker <philippe.schenker@toradex.com>
(cherry picked from commit 119c98f16e704e4c85522f6e22c9c819c21c4128)
Related-to: ELB-2309
Implicitly disable HDMI audio on the module level as it is disabled by
default in imx6qdl.dtsi. It can be enabled on the carrier board level
(e.g. imx6q-apalis-eval.dts, imx6q-apalis-ixora.dts,
imx6q-apalis-ixora-v1.1.dts or imx6q-apalis-ixora-v1.2.dts) if required.
As suggested by the reference manual in a note in chapter 13.2
this commit disables the keeper and enables a 100k pull-down on the
adc pins.
Related-to: ELB-2690
The driver mwifiex_sdio stucks after the wifi firmware crash.
Enabling asynchronous interrupts processing in sdio driver
fixes this issue and allows the mwifiex_sdio driver to be reloaded
and continue operates successfully.
Works better with the driver from the backported-5.4 package.
Related-to: ELB-2596
Until now a PHY-fixup in mach-imx set our rgmii timing correctly. For
the PHY KSZ9131 there is no PHY-fixup in mach-imx. To support this PHY
too, use rgmii-id.
For the now used KSZ9031 nothing will change, as rgmii-id is only
implemented and supported by the KSZ9131.
(cherry picked from commit 1b68480b945e51ba879496d3f9ff5a5addd82007)
We have a PHY-fixup in our downstream Linux. However this patch makes
anyway sense to apply as it documents the rgmii mode properly and
won't brake anything.
Related-to: ELB-2581
Out-of-the-box the analogue camera adapter fails detecting with the
following error:
[ 6.503046] adv7280 2-0021: adv7280_probe:Analog Device adv7280 not detected -6!
Unfortunately, the camera seems to be held in reset due to the BL_ON pin
not being serviced.
Fix this by hogging the camera_nreset aka BL_ON pin to output high.
Related-to: ELB-2580
Commit 833f2cbf7091 ("ARM: dts: imx6: change the core clock of spdif")
changed many more clocks than only the SPDIF core clock as stated in
the commit message.
The MLB clock has been added and this causes SPDIF regression as
reported by Xavi Drudis Ferran and also in this forum post:
https://forum.digikey.com/thread/34240
The MX6Q Reference Manual does not mention that MLB is a clock related
to SPDIF, so change it back to a dummy clock to restore SPDIF
functionality.
Thanks to Ambika for providing the fix at:
https://community.nxp.com/thread/387131
Fixes: 833f2cbf7091 ("ARM: dts: imx6: change the core clock of spdif")
Cc: <stable@vger.kernel.org> # 4.4.x
Reported-by: Xavi Drudis Ferran <xdrudis@tinet.cat>
Signed-off-by: Fabio Estevam <fabio.estevam@nxp.com>
Tested-by: Xavi Drudis Ferran <xdrudis@tinet.cat>
(cherry picked from commit f065e9e4addd75c21bb976bb2558648bf4f61de6)
This fix was correct, but overwritten by commit 833f2cbf7091099baee28136dc68678e974c0ac5.
MLB (Media Local Bus) Clock is in fact not related to SPDIF according to the MX6Q Reference
Manual. Tested playback and record on pulseaudio with 44.1kHz samples.
Signed-off-by: Gerard Salvatella <gerard.salvatella@toradex.com>
(cherry picked from commit 58e5313d36b969029d76b1ef45d3224c8557af75)
eMMC, used in Colibri iMX7D eMMC modules, supports
200Mhz mode with vccq=1.8v.
Remove the max-frequency limit, it increases the performance significantly:
== before fix ====
root@colibri-imx7-emmc:~# hdparm -t /dev/mmcblk1
/dev/mmcblk1:
Timing buffered disk reads: `^H252 MB in 3.02 seconds = 83.54 MB/sec
=== after fix ====
root@colibri-imx7-emmc:~# hdparm -t /dev/mmcblk0
/dev/mmcblk0:
Timing buffered disk reads: 408 MB in 3.00 seconds = 135.94 MB/sec
Related-to: ELB-1442
Fixes: f928a4a377e4 ("ARM: dts: imx7: add Toradex Colibri iMX7D
1GB (eMMC) support")
The interface of Apalis modules is MXM3, not SODIMM.
Just fix the name of the reset touch pin.
Fixes: 96458caa3562 ("ARM: dts: imx6: Add touchscreens used
on Toradex eval boards")
arch/arm64/boot/dts/freescale/Makefile
arch/arm64/boot/dts/freescale/fsl-imx8qm-device.dtsi
This is the 4.14.170 stable release
drivers/net/phy/phy_device.c
drivers/tty/serial/imx.c
include/linux/platform_data/dma-imx-sdma.h
net/wireless/util.c
There is now a mainline variant for a regulator-fixed to be enabled
by a clock. Make use of this newly cherry-picked mainline feature.
Some pinmuxings are obviously wrong, originating from a copy/paste
error. This patch corrects that with the following strategy:
- Set all reserved bits to zero
- Leave drive strength and slew rate as is
- Add sensible pull and hysteresis depending on the function of the pin
- Not used pins are muxed to their reset-value defined by the SoC
Cosmetic change: Rename the reg_sd1_vmmc to reg_sd1_vqmmc as it is
used for vqmmc.
The mmc pins sleep state has been added for the UHS1 speed case only,
add it also to the regular case.
The correct spelling for the property is gpios, otherwise the regulator
will neither reserve nor control any gpio(s).
Thus any SD/MMC card which can use UHS 1 modes will fail.
Related-to: #46566
Commit f014b5b3b3ab added an additional clock to ahci_imx.c used
on i.MX8. Add a dummy clock to imx6q.dtsi so that i.MX6 which doesn't
need the clock the driver keeps working.
Fixes:
[ 2.053942] ahci-imx 2200000.sata: can't get sata_ext clock.
[ 2.053962] ahci-imx: probe of 2200000.sata failed with error -2
Fixes: commit: 5d2a26667010640e33ca0a52c73310f158179711
This commit unifys the backlight settings. All displays sold by Toradex
are now supporting 150Hz as a PWM backlight typical frequency.
Use this value for all SoM's and put also some better default values
for different brightness.
According to manual of I2C bus, both signals sda/scl are "open drain".
Fix flags for all affected Toradex boards.
scl-gpios should be (GPIO_ACTIVE_HIGH | GPIO_OPEN_DRAIN) since
commit d2d0ad2aec4a ("i2c: imx: use open drain for recovery GPIO")
Fix on-boot warning:
"enforced open drain please flag it properly in DT/ACPI DSDT/board file"
Usdhc1 had wrong stuff in it due to the merge request. Fix that
In order for the otg ports, that these modules support, it is needed
that dr_mode is on otg. Switch to use that feature.
Avoid the following spew:
[ 2.083946] imx7d-pinctrl 302c0000.iomuxc-lpsr: pin MX7D_PAD_GPIO1_IO01
already requested by 302c0000.iomuxc-lpsr; cannot claim for gpio-keys
[ 2.099682] imx7d-pinctrl 302c0000.iomuxc-lpsr: pin-1 (gpio-keys) status -22
[ 2.108272] imx7d-pinctrl 302c0000.iomuxc-lpsr: could not request pin 1
(MX7D_PAD_GPIO1_IO01) from group gpiokeysgrp on device 302c0000.iomuxc-lpsr
[ 2.124626] gpio-keys gpio-keys: Error applying setting, reverse things back
[ 2.133420] gpio-keys: probe of gpio-keys failed with error -22
While at it also fix some missing new lines.
Further clean-up Apalis iMX6 device trees.
While at it, add the dtbs for Aster Carrier Board to the Makefile.
In 4.14 devicetress are based on the mainline DT's and only necessary
stuff for downstream is put into those devicetrees.
This commit holds the changes for imx6ull*colibri* from 4.9.
This commit holds the changes for imx6*(colibri|apalis)* from 4.9.
This commit adds the mipi_csi node to Toradex's evalboard as found
on the mezzanine connector
Those devices are used in conjunction with Toradex's carrier boards.
This commit adds the touchscreens from Toradex so one can enable it.
- fix the name of pinctrl set for i2c2 recovery mode;
- add recovery mode for applicable i2c buses for
Apalis/Colibri iMX6Q/D/DL modules.
Related to: #49059
(cherry picked from commit 1501883b4682178e38afc3f08b221f9477fcd7ae)
This patch prepares the devicetree for the new Ixora V1.2 where we are
able to turn off the supply of the can transceiver. This implies to use
a sleep state on transmission pins in order to prevent backfeeding.
(cherry picked from commit c1016f5da0dbb8291575949e7f4a417c6306d70a)
Provide proper configuration for VGEN3, to make sure it's is always powered
which allows that rail to be automatically switched to 1.8 volts
for proper UHS-I operation. By default it's disabled.
With UHS-I enabled:
[ 104.153898] mmc1: new ultra high speed SDR104 SDHC card at address 59b4
[ 104.166202] mmcblk1: mmc1:59b4 USD00 15.0 GiB
[ 104.173923] mmcblk1: p1
root@colibri-imx6:~# hdparm -t /dev/mmcblk1
/dev/mmcblk1:
Timing buffered disk reads: 226 MB in 3.01 seconds = 75.01 MB/sec
Signed-off-by: Igor Opaniuk <igor.opaniuk@toradex.com>
(cherry-picked from 7ffa92d64cc7a6331faaae3e2507458461ab90f3)
Add the phy-node and mdio bus to the fec-node, represented as is on
hardware.
This commit includes micrel,led-mode that is set to the default
value, prepared for someone who wants to change this.
(cherry-picked from 03ff3610434d89fc8e20b280e1219ce0ebb08935)
This adds the muxing for the optional pins usb-oc (overcurrent) and
usb-id.
