Accidentally booting Collie on Assabet reveals that the locomo driver
incorrectly overwrites gpio-sa1100's chip data for its parent interrupt,
leading to oops in sa1100_gpio_unmask() and sa1100_update_edge_regs()
when "gpio: sa1100: convert to use IO accessors" is applied. Fix locomo
to use the handler data rather than chip data for its parent interrupt.
Signed-off-by: Russell King <rmk+kernel@armlinux.org.uk>
Most interrupt flow handlers do not use the irq argument. Those few
which use it can retrieve the irq number from the irq descriptor.
Remove the argument.
Search and replace was done with coccinelle and some extra helper
scripts around it. Thanks to Julia for her help!
Cc: Julia Lawall <Julia.Lawall@lip6.fr>
Cc: Jiang Liu <jiang.liu@linux.intel.com>
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip into next/cleanup
Merge "ARM: Interrupt cleanups and API change preparation" from Thomas
Gleixner:
The following patch series contains the following changes:
- Consolidation of chained interrupt handler setup/removal
- Switch to functions which avoid a redundant interrupt
descriptor lookup
- Preparation of interrupt flow handlers for the 'irq' argument
removal
* 'queue/irq/arm' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
ARM/orion/gpio: Prepare gpio_irq_handler for irq argument removal
ARM/pxa: Prepare balloon3_irq_handler for irq argument removal
ARM/pxa: Prepare *_irq_handler for irq argument removal
ARM/dove: Prepare pmu_irq_handler for irq argument removal
ARM/sa1111: Prepare sa1111_irq_handler for irq argument removal
ARM/locomo: Prepare locomo_handler for irq argument removal
ARM, irq: Use irq_desc_get_xxx() to avoid redundant lookup of irq_desc
ARM/LPC32xx: Use irq_set_handler_locked()
ARM/irq: Use access helper irq_data_get_affinity_mask()
ARM/locomo: Consolidate chained IRQ handler install/remove
ARM/orion: Consolidate chained IRQ handler install/remove
set_irq_flags is ARM specific with custom flags which have genirq
equivalents. Convert drivers to use the genirq interfaces directly, so we
can kill off set_irq_flags. The translation of flags is as follows:
IRQF_VALID -> !IRQ_NOREQUEST
IRQF_PROBE -> !IRQ_NOPROBE
IRQF_NOAUTOEN -> IRQ_NOAUTOEN
For IRQs managed by an irqdomain, the irqdomain core code handles clearing
and setting IRQ_NOREQUEST already, so there is no need to do this in
.map() functions and we can simply remove the set_irq_flags calls. Some
users also modify IRQ_NOPROBE and this has been maintained although it
is not clear that is really needed. There appears to be a great deal of
blind copy and paste of this code.
Signed-off-by: Rob Herring <robh@kernel.org>
Cc: Sekhar Nori <nsekhar@ti.com>
Cc: Kevin Hilman <khilman@deeprootsystems.com>
Cc: Jason Cooper <jason@lakedaemon.net>
Cc: Andrew Lunn <andrew@lunn.ch>
Cc: Sebastian Hesselbarth <sebastian.hesselbarth@gmail.com>
Cc: Gregory Clement <gregory.clement@free-electrons.com>
Acked-by: Hans Ulli Kroll <ulli.kroll@googlemail.com>
Acked-by: Shawn Guo <shawnguo@kernel.org>
Cc: Sascha Hauer <kernel@pengutronix.de>
Cc: Imre Kaloz <kaloz@openwrt.org>
Acked-by: Krzysztof Halasa <khalasa@piap.pl>
Cc: Greg Ungerer <gerg@uclinux.org>
Cc: Roland Stigge <stigge@antcom.de>
Cc: Tony Lindgren <tony@atomide.com>
Cc: Daniel Mack <daniel@zonque.org>
Cc: Haojian Zhuang <haojian.zhuang@gmail.com>
Cc: Robert Jarzmik <robert.jarzmik@free.fr>
Cc: Simtec Linux Team <linux@simtec.co.uk>
Cc: Kukjin Kim <kgene@kernel.org>
Cc: Krzysztof Kozlowski <k.kozlowski@samsung.com>
Acked-by: Wan ZongShun <mcuos.com@gmail.com>
Cc: linux-omap@vger.kernel.org
Cc: linux-samsung-soc@vger.kernel.org
Tested-by: Kevin Hilman <khilman@linaro.org>
The irq argument of most interrupt flow handlers is unused or merily
used instead of a local variable. The handlers which need the irq
argument can retrieve the irq number from the irq descriptor.
Search and update was done with coccinelle and the invaluable help of
Julia Lawall.
Cc: Russell King <linux+kernel@arm.linux.org.uk>
Use irq_desc_get_xxx() to avoid redundant lookup of irq_desc while we
already have a pointer to corresponding irq_desc.
Signed-off-by: Jiang Liu <jiang.liu@linux.intel.com>
Cc: Russell King <rmk+kernel@arm.linux.org.uk>
Chained irq handlers usually set up handler data as well. We now have
a function to set both under irq_desc->lock. Replace the two calls
with one.
Search and conversion was done with coccinelle.
Reported-by: Russell King <rmk+kernel@arm.linux.org.uk>
Use irq_set_chip_and_handler() instead. Converted with coccinelle.
Reorder
irq_set_chip()
irq_set_chip_data()
irq_set_handler()
to
irq_set_chip()
irq_set_handler()
irq_set_chip_data()
so the next patch can combine irq_set_chip() and irq_set_handler() to
irq_set_chip_and_handler().
Automated conversion with coccinelle.
Convert to the new function names. Automated with coccinelle.
Signed-off-by: Lennert Buytenhek <buytenh@secretlab.ca>
The function locomo_m62332_senddata sends a three byte i2c message to
a M62332 DAC. This entire function is guarded with a spin_lock_irqsave
at the start of the function and a spin_unlock_irqrestore at the end.
As each byte is transferred, the i2c ACK from the DAC is checked.
Currently, if the ACK is missing the function simply returns without
the unlock. It also leaves the i2c bus in an invalid state since the
last byte transferred did not have a "stop" condition and leave the
bus idle.
Fix this by adding an exit path using goto.
Signed-off-by: Eric Miao <eric.y.miao@gmail.com>
The locomo spi registers are all defined in locomo.h as offsets
from the first spi register LOCOMO_SPI (0x60), which is itself
an offset from the locomo base address. To correctly access
these registers LOCOMO_SPI must always be included in the
address calculation.
There are two places in locomo.c where this is not done. The
first one, in locomo_suspend, actually results in a write to
LOCOMO_ST instead of LOCOMO_SPICT. The second is in __locomo_probe
and results in a write to LOCOMO_MCSX2 instead of LOCOMO_SPIIE.
Fix these by including LOCOMO_SPI in the calculation.
IRQ_LOCOMO_* are never used elsewhere, remove these definitions. As well
as the cascade of these IRQs. IRQ_LOCOMO_*_BASE changed to IRQ_LOCOMO_*.
IRQ_LOCOMO_LT and IRQ_LOCOMO_SPI are likely to be used in a same way as
IRQ_LOCOMO_KEY.
IRQ_LOCOMO_GPIO and the demultiplex handler should really be living
somewhere else.
It is not necessary and is over-complicated for IRQ_LOCOMO_KEY to
be a cascaded IRQ of IRQ_LOCOMO_KEY_BASE. Removed and introduced
locomokbd_{open,close} for masking/unmasking of the keyboard IRQ.
EXPORT* macros should follow immediately after the closing function
brace line.
The prototype for locomo_chip_driver() is not needed since the static
(inline) function is located earlier in the file.
This symbol is required by locomo backlight driver, exporting this
allows the driver to be built as a module.
Signed-off-by: Eric Miao <eric.miao@marvell.com>
arch/arm/mach-pxa/Kconfig
arch/arm/mach-pxa/corgi.c
arch/arm/mach-pxa/include/mach/hardware.h
arch/arm/mach-pxa/spitz.c
desc_handle_irq() was declared as obsolete since long ago.
Replace it with generic_handle_irq()
Signed-off-by: Dmitry Baryshkov <dbaryshkov@gmail.com>
This just leaves include/asm-arm/plat-* to deal with.
Remove includes of asm/hardware.h in addition to asm/arch/hardware.h.
Then, since asm/hardware.h only exists to include asm/arch/hardware.h,
update everything to directly include asm/arch/hardware.h and remove
asm/hardware.h.
IRQT_* and __IRQT_* were obsoleted long ago by patch [3692/1].
Remove them completely. Sed script for the reference:
s/__IRQT_RISEDGE/IRQ_TYPE_EDGE_RISING/g
s/__IRQT_FALEDGE/IRQ_TYPE_EDGE_FALLING/g
s/__IRQT_LOWLVL/IRQ_TYPE_LEVEL_LOW/g
s/__IRQT_HIGHLVL/IRQ_TYPE_LEVEL_HIGH/g
s/IRQT_RISING/IRQ_TYPE_EDGE_RISING/g
s/IRQT_FALLING/IRQ_TYPE_EDGE_FALLING/g
s/IRQT_BOTHEDGE/IRQ_TYPE_EDGE_BOTH/g
s/IRQT_LOW/IRQ_TYPE_LEVEL_LOW/g
s/IRQT_HIGH/IRQ_TYPE_LEVEL_HIGH/g
s/IRQT_PROBE/IRQ_TYPE_PROBE/g
s/IRQT_NOEDGE/IRQ_TYPE_NONE/g
Signed-off-by: Kay Sievers <kay.sievers@vrfy.org>
irqs.h:
* rename IRQ_LOCOMO_SPI_OVRN to IRQ_LOCOMO_SPI_REND
locomo.h:
* add some definition for locomo spi controller
* correct some errors
locomo.c:
* add set_type for locomo gpio irq chip
Signed-off-by: Thomas Kunze <thommycheck@gmx.de>
The saved_state member of 'struct dev_pm_info' that's going to be removed
is used in arch/arm/common/locomo.c, arch/arm/common/sa1111.c and
arch/arm/mach-sa1100/neponset.c. Change the code in there to use local
variables for saving the state of devices during suspend.
Cc: Greg KH <greg@kroah.com>
Cc: David Brownell <david-b@pacbell.net>
Acked-by: Russell King <rmk+kernel@arm.linux.org.uk>
set_irq_chipdata -> set_irq_chip_data
get_irq_chipdata -> get_irq_chip_data
do_level_IRQ -> handle_level_irq
do_edge_IRQ -> handle_edge_irq
do_simple_IRQ -> handle_simple_irq
irqdesc -> irq_desc
irqchip -> irq_chip
Untested, but this should fix up the bulk of the totally mechanical
issues, and should make the actual detail fixing easier.
The Locomo chip has a SPI interface which is used for SD/MMC cards (only collie).
This patch adds the definition for the SPI device inside the Locomo chip.
Signed-off-by: Dirk Opfer <Dirk@Opfer-Online.de>
Convert LOMOMO to use struct device * for GPIOs instead of struct
locomo_dev. This enables access to the GPIOs from code which is not
a locomo device itself (such as audio). Access for gpio 31 is removed
for error handling (no such hardware exists).
Signed-off-by: Richard Purdie <rpurdie@rpsys.net>
Patch from David Brownell
ARM genirq cleanups/updates:
- Start switching platforms to newer APIs
* use "irq_chip" name, not "irqchip"
* providing irq_chip.name
- Show irq_chip.name in /proc/interrupts, like on x86.
This update a bit more than half of the ARM code. The irq_chip.name
values were chosen to match docs (if I have them) or be otherwise
obvious ("FPGA", "CPLD", or matching the code).
Signed-off-by: David Brownell <dbrownell@users.sourceforge.net>
Patch from Pavel Machek
Cleanup locomo.c.
Signed-off-by: Pavel Machek <pavel@suse.cz>
Signed-off-by: Jörn Engel <joern@wohnheim.fh-wedel.de>
Add backlight intensity control to the LOCOMO lcd/backlight driver using the
backlight class and add basic power management support.
This is a reimplementation and improvement of patches by John Lenz and Pavel
Machek
Signed-off-by: Antonino Daplas <adaplas@pol.net>
Cc: Pavel Machek <pavel@ucw.cz>
Convert all uses of kmalloc followed by memset to use kzalloc instead.
In all current use cases, "chipdata" is used to store an iomem address.
Mark it with __iomem, and rename it to 'base'. Leave the accessor macros
alone.
platform_get_irq*() now returns on -ENXIO when the resource cannot be
found. Ensure all users of platform_get_irq*() handle this error
appropriately.
Signed-off-by: David Vrabel <dvrabel@arcom.com>
Enable frontlight during collie bootup, so that display is actually
readable in anything other than bright sunlight.
This fixes compilation for collie after -rc1 platform_device
changes. And yes, it even boots.
This allows us to eliminate the casts in the drivers, and eventually
remove the use of the device_driver function pointer methods for
platform device drivers.
Convert everyone who uses platform_bus_type to include
linux/platform_device.h.
In PM v1, all devices were called at SUSPEND_DISABLE level. Then
all devices were called at SUSPEND_SAVE_STATE level, and finally
SUSPEND_POWER_DOWN level. However, with PM v2, to maintain
compatibility for platform devices, I arranged for the PM v2
suspend/resume callbacks to call the old PM v1 suspend/resume
callbacks three times with each level in order so that existing
drivers continued to work.
Since this is obsolete infrastructure which is no longer necessary,
we can remove it. Here's an (untested) patch to do exactly that.
It's pointless to include mach-types.h if you're not going to use
anything from it. These references were removed as a result of:
grep -lr 'asm/mach-types\.h' . | xargs grep -L 'machine_is_\|MACH_TYPE_\|MACHINE_START\|machine_type'
Fix up some pm_message_t types
Signed-Off-By: Richard Purdie <rpurdie@rpsys.net>
This adds low-level suspend/resume support to locomo.c.
This is part of Thomas Gleixner's generic IRQ patch, which converts
ARM to use the generic IRQ subsystem. Here, we wrap calls to
desc->handler() in an inline function, desc_handle_irq(). This
reduces the size of Thomas' patch since the changes become more
localised.
Do not access children in struct device directly, use
device_for_each_child helper instead. It fixes compilation.
infrastructure for it.
Let it rip!
