path: root/arch/arm/common/mcpm_head.S
2015-05-08ARM: replace BSYM() with badr assembly macroRussell King
BSYM() was invented to allow us to work around a problem with the assembler, where local symbols resolved by the assembler for the 'adr' instruction did not take account of their ISA. Since we don't want BSYM() used elsewhere, replace BSYM() with a new macro 'badr', which is like the 'adr' pseudo-op, but with the BSYM() mechanics integrated into it. This ensures that the BSYM()-ification is only used in conjunction with 'adr'. Acked-by: Dave Martin <Dave.Martin@arm.com> Acked-by: Nicolas Pitre <nico@linaro.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2013-10-30Merge branch 'baserock/bjdooks/312-rc4/be/core-v3' of ↵Russell King
git://git.baserock.org/delta/linux into devel-stable Conflicts: arch/arm/kernel/head.S This series has been well tested and it would be great to get this merged now. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2013-10-19ARM: mcpm: fix big endian issue in mcpm startup codeVictor Kamensky
In big endian mode mcpm_entry_point is first function that called on secondaries CPU. First it should switch CPU into big endian code. [ben.dooks@codethink.co.uk: merge fix patch from Victor into this] Signed-off-by: Victor Kamensky <victor.kamensky@linaro.org> Acked-by: Nicolas Pitre <nico@linaro.org> Reviewed-by: Dave Martin <Dave.Martin@arm.com> Signed-off-by: Ben Dooks <ben.dooks@codethink.co.uk>
2013-09-23ARM: mcpm: add a simple poke mechanism to the early entry codeNicolas Pitre
This allows to poke a predetermined value into a specific address upon entering the early boot code in bL_head.S. Signed-off-by: Nicolas Pitre <nico@linaro.org>
2013-08-12ARM: mcpm: use -st dsb option prior to sev instructionsWill Deacon
In a similar manner to our spinlock implementation, mcpm uses sev to wake up cores waiting on a lock when the lock is unlocked. In order to ensure that the final write unlocking the lock is visible, a dsb instruction is executed immediately prior to the sev. This patch changes these dsbs to use the -st option, since we only require that the store unlocking the lock is made visible. Acked-by: Nicolas Pitre <nico@linaro.org> Reviewed-by: Dave Martin <dave.martin@arm.com> Reviewed-by: Catalin Marinas <catalin.marinas@arm.com> Signed-off-by: Will Deacon <will.deacon@arm.com>
2013-06-05ARM: 7740/1: MCPM: prettify debug outputNicolas Pitre
The CPU and cluster numbers (MPIDR affinity levels 0 and 1) may have at most 8 bits each. Signed-off-by: Nicolas Pitre <nico@linaro.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2013-04-24ARM: mcpm_head.S: vlock-based first man electionDave Martin
Instead of requiring the first man to be elected in advance (which can be suboptimal in some situations), this patch uses a per- cluster mutex to co-ordinate selection of the first man. This should also make it more feasible to reuse this code path for asynchronous cluster resume (as in CPUidle scenarios). We must ensure that the vlock data doesn't share a cacheline with anything else, or dirty cache eviction could corrupt it. Signed-off-by: Dave Martin <dave.martin@linaro.org> Signed-off-by: Nicolas Pitre <nicolas.pitre@linaro.org> Reviewed-by: Santosh Shilimkar <santosh.shilimkar@ti.com> Reviewed-by: Will Deacon <will.deacon@arm.com>
2013-04-24ARM: mcpm: introduce helpers for platform coherency exit/setupDave Martin
This provides helper methods to coordinate between CPUs coming down and CPUs going up, as well as documentation on the used algorithms, so that cluster teardown and setup operations are not done for a cluster simultaneously. For use in the power_down() implementation: * __mcpm_cpu_going_down(unsigned int cluster, unsigned int cpu) * __mcpm_outbound_enter_critical(unsigned int cluster) * __mcpm_outbound_leave_critical(unsigned int cluster) * __mcpm_cpu_down(unsigned int cluster, unsigned int cpu) The power_up_setup() helper should do platform-specific setup in preparation for turning the CPU on, such as invalidating local caches or entering coherency. It must be assembler for now, since it must run before the MMU can be switched on. It is passed the affinity level for which initialization should be performed. Because the mcpm_sync_struct content is looked-up and modified with the cache enabled or disabled depending on the code path, it is crucial to always ensure proper cache maintenance to update main memory right away. The sync_cache_*() helpers are used to that end. Also, in order to prevent a cached writer from interfering with an adjacent non-cached writer, we ensure each state variable is located to a separate cache line. Thanks to Nicolas Pitre and Achin Gupta for the help with this patch. Signed-off-by: Dave Martin <dave.martin@linaro.org> Signed-off-by: Nicolas Pitre <nico@linaro.org> Reviewed-by: Will Deacon <will.deacon@arm.com>
2013-04-24ARM: multi-cluster PM: secondary kernel entry codeNicolas Pitre
CPUs in cluster based systems, such as big.LITTLE, have special needs when entering the kernel due to a hotplug event, or when resuming from a deep sleep mode. This is vectorized so multiple CPUs can enter the kernel in parallel without serialization. The mcpm prefix stands for "multi cluster power management", however this is usable on single cluster systems as well. Only the basic structure is introduced here. This will be extended with later patches. In order not to complexify things more than they currently have to, the planned work to make runtime adjusted MPIDR based indexing and dynamic memory allocation for cluster states is postponed to a later cycle. The MAX_NR_CLUSTERS and MAX_CPUS_PER_CLUSTER static definitions should be sufficient for those systems expected to be available in the near future. Signed-off-by: Nicolas Pitre <nico@linaro.org> Reviewed-by: Santosh Shilimkar <santosh.shilimkar@ti.com> Reviewed-by: Will Deacon <will.deacon@arm.com>
